coopers
coopers
australia
195 registered members (1xfatboy), 1,788 guests, and 605 spiders.
Lightning Sim, Simon.Holyfield, Bushcreature, Gary Shackleton, Doug Valley
10034 Registered Users
Lannis 144
kommando 103
Stuart 67
476,618 mail-order LSR
Topics65,721
Posts635,216
Members10,032
Lucas E3l Dynamo to timing cover - HOW? #667814
09/16/16 4:15 pm
09/16/16 4:15 pm
Geneva, Switzerland
BrettF Online content OP
BrettF  Online Content OP
Geneva, Switzerland
Hi folks,
On the T110 that I am working on I am a bit confused as to how the Dynamo should correctly mount to the timing cover. Part of the confusion is the following: I have two drive covers. One seems to be original with the stud protruding and the other seems to have a larger central mounting hole, I am not sure of this was drilled by a later owner or is an alternative.
The manual shows this picture below which seems to show the smaller stud with a shouldered/domed nut (of which I can find no reference number)
Does this mounting below look correct (diameter of the hole in the timing cover(5/16) is much larger than the dynamo stud diameter 3/16)).
If so does anyone know the part number for the nut that fits over the end of the stud and secures the dynamo from the timing cover side? Is there a spacer that fits over the stud to take up the space around the stud in the timing cover?
The following two pictures show the timing cover with the dynamo drive end cover with the larger (drilled out?) hole. Looking at these two pictures, it seems as though the hole in the dynamo drive end matches the hole size in the timing cover.
Is is possible that the dynamo drive end cover AND the timing case hole have been enlarged?
Is there possible just a larger 5/16 square headed bolt that fits through from the magneto end with a dome nut on the timing cover?
Any insights greatly appreciated.
Brett
Bikes:
69 T120 on average (1967 rolling frame and 1971 Bonnie engine)
57 T110 on average (58 rolling frame - with 55 iron head engine)
Re: Lucas E3l Dynamo to timing cover - HOW? [Re: BrettF] #667848
09/16/16 8:07 pm
09/16/16 8:07 pm
Jon W. Whitley Online content
The nut that you need is a 2BA nut part number E2228. Yes, it is small.
From the British Only website:
01-70-2228
NUT,2BA,DOME,DYNAMO
Suggested Price - $8.27 Web Price - $6.20 Used - $4.96
And the stud:
01-70-2414
STUD,2BA X 1-3/4 ,DYNAMO FIXING
$4.47 $3.35 NA
Re: Lucas E3l Dynamo to timing cover - HOW? [Re: BrettF] #667851
09/16/16 8:52 pm
09/16/16 8:52 pm
newcastle australia
trevinoz Online content
trevinoz  Online Content
newcastle australia
Brett, when you fit the generator, don't over tighten the dome nut or you will end up with an end plate with a large hole.
Re: Lucas E3l Dynamo to timing cover - HOW? [Re: trevinoz] #667870
09/17/16 3:40 am
09/17/16 3:40 am
Geneva, Switzerland
Geneva, Switzerland
DOH, there the nut is on the engine parts diagram!!!!
Thanks folks.
It would appear as though the previous owner not only drilled ou the dynamo drive end cover but also the primary case. see picture below.
Can anyone measure a good case and let me know what the diameter of the hole should be. I am thinking of pressing in a tube to close up that hole where it is broken through to the inside of the primary case, which looks like a oil leak waiting to happen.
Any other ideas? has anyone else had to deal with this before?
Brett
Bikes:
Re: Lucas E3l Dynamo to timing cover - HOW? [Re: BrettF] #667873
09/17/16 4:35 am
09/17/16 4:35 am
Tasmania - Gateway to Antarcti...
Tasman Online content
Tasman  Online Content
My dynamo and crankcase are the same with a 1/4" UNC bolt with modified head used in place of the 2BA bolt and nut. It isn't pretty but it works although it does let a little oil through to the inside of the dynamo. I just live with it as it doesn't sem to affect the charging at all.
"Live the life you love, find a god you trust and don't take it all too seriously"
Pre-units rule!
Mid fifties Triumph T100
Re: Lucas E3l Dynamo to timing cover - HOW? [Re: BrettF] #668016
09/18/16 9:51 am
09/18/16 9:51 am
Kent, UK
Nick_Smith Offline
Nick_Smith  Offline
Kent, UK
The hole in the timing cover is 1/4".
The small domed nut (3/8" A/F) has a section which is just under 1/4" diameter and 3/16" long which goes into the timing cover, to locate the dynamo via the stud on the end cover.
If you can get an original or repro nut (no idea of the part number), you could add a tube into the timing cover as you state, with a hole drilled to suit the small extension on the nut. Or - make both items if you're able to.
"1967 TR6R"
Re: Lucas E3l Dynamo to timing cover - HOW? [Re: BrettF] #668086
09/18/16 10:31 pm
09/18/16 10:31 pm
South cone
reverb Offline
reverb  Offline
South cone
...that system is not a good design. No matter what hole or nut do you have there if you crank up the rpms the dynamo cannot hold it. I loosed the dynamo several times, falling parts down the road etc then one day I decided to get rid of the dynamo and just blank there; so now I rely only in the battery; but I disconnected the voltage regulator and put a 12V battery and just that in my older 500cc.
Re: Lucas E3l Dynamo to timing cover - HOW? [Re: BrettF] #668090
09/18/16 10:52 pm
09/18/16 10:52 pm
Queensland, Australia
Tiger100 Online content
Tiger100  Online Content
Did you have the dynamo strap in place as well mate?
Grant
Re: Lucas E3l Dynamo to timing cover - HOW? [Re: Tiger100] #668098
09/19/16 1:39 am
09/19/16 1:39 am
Yes- that stud and nut only pulls the dynamo onto the gasket.
The steel strap over the dynamo holds it onto the engine.
Re: Lucas E3l Dynamo to timing cover - HOW? [Re: Tiger100] #668182
09/19/16 8:41 pm
09/19/16 8:41 pm
Re: Lucas E3l Dynamo to timing cover - HOW? [Re: BrettF] #668276
09/20/16 4:49 pm
09/20/16 4:49 pm
Hey Jon, yeah ask me how I know eh ☺️.
Grant
Re: Lucas E3l Dynamo to timing cover - HOW? [Re: Tiger100] #668298
09/20/16 8:26 pm
09/20/16 8:26 pm
Ha ha ha Grant....I already know !
Re: Lucas E3l Dynamo to timing cover - HOW? [Re: Jon W. Whitley] #668343
09/21/16 7:52 am
09/21/16 7:52 am
blush beerchug
Grant
