Mike Austin
Mike Austin
Murrieta California
201 registered members (79T140E), 2,144 guests, and 556 spiders.
GabrielSoren, JoshP, spikey45, trevor's, myshootingstar68
10077 Registered Users
NickL 86
koan58 85
Lannis 81
504,269 mail-order LSR
Topics66,036
Posts639,165
Members10,077
Things to do before starting old Norton up! #667335
09/12/16 5:38 am
09/12/16 5:38 am
Denmark
André C Offline OP
André C  Offline OP
Denmark
Hi Forum.
I recently bought a Norton Commando 750 Roadster from 1971. The bike is in okay condition, but has not been started since 2011! So my question is, what should I do before I step on the kick starter for the first time?
1. Change oil
2. Replace the oil filter
3. Empty the old fuel from the fuel system and fill with new fuel
4. Replace spark plugs
5. Replace the battery (fully charged)
Anything else?
What about old solidified oil in the system, do I need to get red of that before starting up?
Thanks.
Best regard
André Daniel Christensen
Denmark
- 1968 BSA B40 WD
- 1971 Norton Commando
- 2006 Kawasaki Z 750
Re: Things to do before starting old Norton up! [Re: André C] #667337
09/12/16 6:28 am
09/12/16 6:28 am
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
Originally Posted By André C
Anything else?
Remove both exhaust rocker inspection covers and pour a small amount of engine oil into the head on each side which will help to lubricate the tappets/lifters and cam lobes on the initial start-up.
I wouldn't expect the oil to have solidified if it was last run in 2011.
Re: Things to do before starting old Norton up! [Re: André C] #667338
09/12/16 6:32 am
09/12/16 6:32 am
Annapolis, MD
Dennis B Offline
Dennis B  Offline
Annapolis, MD
1. Drain the sump of oil(don't kick it until you do)
2. (fuel) if it has a fiberglass tank, don't put ANY fuel that has
alcohol (methanol) in it.
3. ("What about old solidified oil in the system")
not sure what you mean, but if this is crud in the bottom of the oil tank,
remove the tank and wash it out with hot soapy water.
hope this helps
Dennis B
Member # 182
'73 750 Commando
'72 Combat Commando
'71 Triumph Blazer
'69 Victors
'68 Starfire
'51 Royal Enfield 250 'S'
Re: Things to do before starting old Norton up! [Re: André C] #667339
09/12/16 6:33 am
09/12/16 6:33 am
Only Castrol R solidifies, would have to be a racing bike for Castrol R to be used.
Re: Things to do before starting old Norton up! [Re: L.A.B.] #667340
09/12/16 7:07 am
09/12/16 7:07 am
New Zealand
johnm Offline
johnm  Offline
New Zealand
Originally Posted By L.A.B.
[quote=André C]Anything else?
+ 1 very important.
You will also need to change the gearbox oil, fork oil, primary chain, swinging arm oil. And check and oil all cables including speedo.
Plus clean the carbs with carb clean.
Unglue the clutch because the plates are probably stuck together !!!
Probable also clean and check for corrosion on electrical connections especially if you have electronic ignition.
The tyres and tubes are also probably had it.
Re: Things to do before starting old Norton up! [Re: L.A.B.] #667441
09/13/16 4:55 am
09/13/16 4:55 am
Stuart Online content
Stuart  Online Content
Hi André,
Much of what has been advised here is in Waking The Sleeping Beast. The original article was written by a long-time Brit. bike owner, builder, racer and dealer and - although primarily aimed at Triumph/BSA triple owners - much of his advice applies to any engine, as you can see. smile
One thing you might want to consider is being generous with the "amount of engine oil into the head". The oil will drain to the sump; as soon as the engine starts, the crank can immediately start flinging around any it touches to splash-lubricate bearings that require it and the oil pump can immediately start scavenging the oil back to the tank ... which reduces the heart-stopping period between starting the engine and returned oil appearing back in the tank! grin
Hope this helps.
Re: Things to do before starting old Norton up! [Re: kommando] #667477
09/13/16 1:52 pm
09/13/16 1:52 pm
Yes, or a road bike with Castrol R in it.
Re: Things to do before starting old Norton up! [Re: André C] #667478
09/13/16 1:55 pm
09/13/16 1:55 pm
I think a more meaningful heart-stopper is any doubt about pressure feed to the big ends.
Moderated by  Dave Comeau
Page Time: 0.078s Queries: 15 (0.005s) Memory: 1.0442 MB (Peak: 1.2147 MB) Zlib disabled. Server Time: 2018-02-23 06:04:05 UTC
