Steve m
Steve m
Billings,Mt
196 registered members (1xfatboy), 1,886 guests, and 557 spiders.
10070 Registered Users
koan58 86
Lannis 82
NickL 75
Stuart 67
501,277 mail-order LSR
Topics65,995
Posts638,657
Members10,070
Rating: 3
Page 4 of 4 1 2 3 4
Re: T150 common sense engine mods [Re: bon] #483383
03/28/13 11:24 am
03/28/13 11:24 am
terra Australis
Pre Unit Offline
Pre Unit  Offline
terra Australis
just found this on U Tube .
http://www.youtube.com/watch?v=tR7RuheaXl4
Cooel Exhaust . Sounds like all the pieces are there .
Re: T150 common sense engine mods [Re: Pre Unit] #483469
03/28/13 10:37 pm
03/28/13 10:37 pm
bon Online content OP
bon  Online Content OP
Yes i seen that vid pre unit and its just the sort of machine that i want to build, i asked the guy to come on here and tell us about it as its a real piece of motorcycle art.
Re: T150 common sense engine mods [Re: bon] #514182
11/10/13 9:55 am
11/10/13 9:55 am
terra Australis
Pre Unit Offline
Pre Unit  Offline
terra Australis
Re: T150 common sense engine mods [Re: bon] #550226
06/26/14 7:13 pm
06/26/14 7:13 pm
USA
OneEyedGiant Offline
USA
Hey guys. Where does one buy the Bob Newby clutch converstion kit to include the primary cover? Any idea on how much these kits cost?
Re: T150 common sense engine mods [Re: OneEyedGiant] #550256
06/27/14 2:45 am
06/27/14 2:45 am
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
Re: T150 common sense engine mods [Re: L.A.B.] #550266
06/27/14 7:29 am
06/27/14 7:29 am
USA
USA
Thank LAB, I contacted Bob and he sells just the belt drive but not all the components needed for the entire Kit to include the Quaife 5 speed gearbox. Bob Newby said it's available possibly from P&M Cycles in the UK but I've not had an opportunity to call them yet. Thanks.
Re: T150 common sense engine mods [Re: bon] #550490
06/29/14 1:11 am
06/29/14 1:11 am
ca, us
DMadigan Online content
DMadigan  Online Content
ca, us
The belt drive needs a drilled mainshaft for the clutch pushrod (actuated by a twin lifter in the gearbox cover). I am not sure but presume the Newby clutch fits on a standard mainshaft. You may be able to have the shaft drilled.
Re: T150 common sense engine mods [Re: bon] #664933
08/22/16 10:14 pm
08/22/16 10:14 pm
Great Southern Land
tridentt150v Offline
Great Southern Land
One thing I like to do is extend the oil return dowels from the head through the barrels. I usually use an inch/25mm of tube for this.
I then counter drill the barrels and head to account for this increase. But I also run a NH 1000cc kit and the head sits a little bit higher on the lip of the bores.
Doing this - in my opinion - means that there is less chance of the oilway being affected by piston vacuum and pressure. It also means that, if you are using a sealant, the chances of any sealant flowing into the oilway when you tension the head down is negated.
I am not saying everyone needs to do this, I just saw benefit in it and the room was there to do it.
Re: T150 common sense engine mods [Re: bon] #664988
08/23/16 11:08 am
08/23/16 11:08 am
Mississauga, Ontario.
Adam M. Online content
Adam M.  Online Content
Really common sens engine mode I did was doweling the rocker boxes.
It'll keep rocker box gaskets in place.
Re: T150 common sense engine mods [Re: Adam M.] #665007
08/23/16 2:54 pm
08/23/16 2:54 pm
Peter R Online content
Peter R  Online Content
Adam, can you please elaborate on how you did this ?
I have a persistent (small) oil leak from a rockerbox gasket.
Replacement of the gasket only cured the leak for a short while.
Page 4 of 4 1 2 3 4
Page Time: 1.089s Queries: 16 (0.013s) Memory: 1.0750 MB (Peak: 1.2687 MB) Zlib disabled. Server Time: 2018-02-18 06:45:20 UTC
