gREgg-K
gREgg-K
Ottawa, Canada
213 registered members (1xfatboy), 1,852 guests, and 554 spiders.
Gus1956, Henry74, Benny, Lou Quirch, Mark Masa
10045 Registered Users
Lannis 152
kommando 112
480,787 mail-order LSR
Topics65,767
Posts635,801
Members10,045
Testing Norton Commando MKIII headlight switches #662765
08/03/16 2:33 pm
08/03/16 2:33 pm
Penna
Dnaj11 Offline OP
Dnaj11  Offline OP
Penna
I've got a 75 Norton MKIII which had a leaking master cylinder. I've rebuilt the master cylinder but had to take apart and clean the switches on that side which had become contaminated with brake fluid and crud. I took care not to loose the flat tabs and springs inside the plastic switches and believe I did put it together correctly. Unfortunately, I did not test to see if they worked before I started this and the bike has not been run in years. Is there a way to test the switch for the headlight. I'm not sure which wire should have voltage in the various switch positions. I'd like to rule out all other possibilities before taking the small switches apart again. They are not fun to get together with old fingers like mine. Thank you.
Re: Testing Norton Commando MKIII headlight switches [Re: Dnaj11] #662767
08/03/16 2:52 pm
08/03/16 2:52 pm
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
There are only two positions for the Mk3 headlamp selector switch, HEAD and PILOT.
With the sliding switch set at the HEAD position, there should be continuity between the blue [U] and the blue/yellow [UY] wires of the switch cluster.
At PILOT, the switch should be 'open'.
If checking by voltage, the blue should show volts with the switch at HEAD, and 0.V at PILOT.
Re: Testing Norton Commando MKIII headlight switches [Re: L.A.B.] #662771
08/03/16 4:03 pm
08/03/16 4:03 pm
Penna
Dnaj11 Offline OP
Dnaj11  Offline OP
Penna
Thank you. My ohm readings between the blue and blue and yellow correspond, but I have no lights whatsoever, and no tail light either. Is there something else common to both? Does the run/kill switch have any bearing? I do not have an owners manual for this bike. Thanks
Re: Testing Norton Commando MKIII headlight switches [Re: Dnaj11] #662774
08/03/16 4:20 pm
08/03/16 4:20 pm
Norfolk, UK
Norfolk, UK
The feed to headlamp switch (blue/yellow) comes from the master/ignition switch terminal 4.
All other lights (pilot, tail, instruments) are fed from master switch terminal 3 (brown/green) so I suggest you check the wiring back to the master switch and also check you have power reaching the switch from the battery (brown/blue, terminal 1).
No.
Mk3 manual:
http://britmoto.com/manuals/Manuals/850_man.pdf
Wiring diagram, Section J.
Re: Testing Norton Commando MKIII headlight switches [Re: L.A.B.] #662803
08/03/16 7:40 pm
08/03/16 7:40 pm
Penna
Dnaj11 Offline OP
Dnaj11  Offline OP
Penna
Thank you. Looks like the switch is flakey. Other than that, I think its ready to start!
Moderated by  Dave Comeau
