T100Mark
T100Mark
Southern California
50 registered members (Adam M.), 221 guests, and 373 spiders.
10478 Registered Users
NickL 89
franko 78
Triless 69
748,659 mail-order LSR
Topics68,846
Posts670,617
Members10,478
C15 chainguard question #662229
07/30/16 3:50 am
07/30/16 3:50 am
Luton Bedfordshire UK
Seamus Offline OP
Seamus  Offline OP
Are there two types of chainguard for the C15. (1964 SS80) Chainguard I have has a solid support between the two sides of the guard, but my swing arm has a solid lug that fits between the two sides of the guard, so obviously it will not fit. Hard to see in the parts book.
Re: C15 chainguard question [Re: Seamus] #662236
07/30/16 5:48 am
07/30/16 5:48 am
BSA_WM20 Offline
BSA_WM20  Offline
C 15's & B 40's shared a frames and tinwear.
There were quite a few different frames and variations, competition , trials SS and then the late all welded frame.
By now there is absolutely no reason to think that any 2 parts on any C15 left the factory on the same machine.
40-7701 or the cometition models and 40- 7712 for street models.
Re: C15 chainguard question [Re: Seamus] #662256
07/30/16 9:48 am
07/30/16 9:48 am
Seamus Offline OP
Seamus  Offline OP
Thanks Trevor. Looks like I just haveto look a bit harder for a guard
Re: C15 chainguard question [Re: Seamus] #662320
07/30/16 4:29 pm
07/30/16 4:29 pm
Jaffrey, NH, USA
Peter Quick Offline
Peter Quick  Offline
Jaffrey, NH, USA
Seamus, It is highly likely that you have the correct chainguard. The C15 road bike frame used the chainguard as you describe with a solid tube at the rear (closest to the shocks) mount lug. Just the guard mounts to the inside of the swingarm against the lug, not straddling it. Thus the tube so it doesn't crush when the mounting bolt is tightened. Try it on and you will see how it works.
Peter
Re: C15 chainguard question [Re: Seamus] #662372
07/31/16 3:58 am
07/31/16 3:58 am
Seamus Offline OP
Seamus  Offline OP
Thanks Peter. Never occured to me aasit came without one and it took a long time to source.
Don't suppose you know how the rotary brake light switch fits?
Re: C15 chainguard question [Re: Seamus] #662395
07/31/16 8:02 am
07/31/16 8:02 am
Jaffrey, NH, USA
Peter Quick Offline
Peter Quick  Offline
Jaffrey, NH, USA
Rear brake light switch mounts on the bolt that holds the swingarm pivot pin and rear subframe section together. That is if you have the correct switch.
Re: C15 chainguard question [Re: Peter Quick] #662420
07/31/16 1:30 pm
07/31/16 1:30 pm
Seamus Offline OP
Seamus  Offline OP
Thanks Peter. Bought the switch from Autocycle Engineering so expect it to be correct. Will have a look tomorrow.
Another part that was not present on original purchase.
Appreciate the help
