Keane Lucas
Keane Lucas
New Jersey
36 registered members (998John), 280 guests, and 403 spiders.
vietnammotorbike, Lennart Liljedah, Mal Wood, FireGuyKC, spuggy
10288 Registered Users
Stuart 94
Lannis 65
Mori55 60
636,061 mail-order LSR
Topics67,365
Posts654,057
Members10,288
Norton Commando timing cover removal #65983
08/07/06 8:48 pm
08/07/06 8:48 pm
Connecticut
tdthehandyman Offline OP
Connecticut
Help! I want to remove the timing cover on a '75 Interstate. It is loose (1/4 inch gap) but something is keeping it from coming off and I don't want to break anything. Anyone ever run into this?
Re: Norton Commando timing cover removal #65984
08/07/06 10:04 pm
08/07/06 10:04 pm
Reidsville, NC
michael friesen Offline
Reidsville, NC
are the points wires still in place? they can be a tight fit.
Re: Norton Commando timing cover removal #65985
08/07/06 10:17 pm
08/07/06 10:17 pm
Connecticut
Connecticut
Let me be clear...my Haynes Commando manual refers to the complete piece, held on by 12 bolts, as the "timing cover". Thanks
Re: Norton Commando timing cover removal #65986
08/07/06 10:31 pm
08/07/06 10:31 pm
Reidsville, NC
Reidsville, NC
yes, and you have to remove the auto advance unit (or rotor in case of Boyer, etc.) first, then the wires will still be going through a hole in the back of the timing cover, and through the right-hand crankcase.
Other than that, there are a couple of oil seal which should already be free if you have 1/4 inch gap, and the rocker oil feed pipe.
if you have removed the oil feed pipe and the wires that enter the timing cavity from the back, then my apologies for posting.
Re: Norton Commando timing cover removal #65987
08/08/06 3:06 pm
08/08/06 3:06 pm
Connecticut
Connecticut
Hey, that got it mj, thanks so much. I fix pc's, if you need anything let me know ok?
Re: Norton Commando timing cover removal #65988
08/08/06 5:24 pm
08/08/06 5:24 pm
Reidsville, NC
Reidsville, NC
glad to hear you got it off.
i manage servers and (used to) build pc's too, but thanks for the offer!
Moderated by  Dave Comeau
