57nortonmodel77
57nortonmodel77
Concord Township, Ohio
48 registered members (Al Eckstadt), 293 guests, and 402 spiders.
10256 Registered Users
Lannis 62
608,687 mail-order LSR
Topics67,112
Posts651,274
Members10,256
Page 2 of 2 1 2
Re: Timing a mag? [Re: 6T] #653830
05/22/16 7:12 pm
05/22/16 7:12 pm
Queensland, Australia
Tiger100 Offline
Tiger100  Offline
Did you actually have success 6T?
Grant
Re: Timing a mag? [Re: 6T] #653866
05/23/16 7:08 am
05/23/16 7:08 am
back down the 'smoke',England
6T Offline OP
6T  Offline OP
....well,I looked at the parts book & on the alternator model(6T) there's a key to locate the alternator to the crank.I'm getting one so when I get her up & running I can use a large drill to spin the engine forwards to check the timing in the future with a large 1/2" socket on said alternator spacer.I have ordered a small metal protractor which I'm going to fix permanently to the engine sprocket...photo's will explain better when I post next time...There WAS a spark a few days ago but it seems to have walked off! So Im going to hold the HT cable against the head with mole(?) grips to see if its the plugs/caps...Cheers!
BMW R1100rt
6T 1965
T110 1958
Re: Timing a mag? [Re: 6T] #654930
05/31/16 8:10 am
05/31/16 8:10 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
If you can't fire a plug with the outer electrode ripped off, then it will never fire inside the cylinder under compression. Ignitions should be able to jump 1/8" or more in free air.
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Timing a mag? [Re: Andy Higham] #654931
05/31/16 8:13 am
05/31/16 8:13 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
Originally Posted By Andy Higham
I wonder how many people are slavishly following the original timing and carburettor settings in old bikes?
I wonder how much performance they are losing?
I wonder how much fuel they are wasting?
I wonder how much more enjoyable their bikes would be after a day on a dyno?
I wonder why people add these arcane and self-promoting comments when the OP is simply trying to get the bike to crank and run ?
RF Whatley
Cornelia, GA
Re: Timing a mag? [Re: 6T] #654933
05/31/16 8:46 am
05/31/16 8:46 am
Turning the engine forwards with the alternator nut is likely to loosen the nut.
Good luck, but what I do is set timing static, at full advance, then check with a strobe, running the engine up to reasonable rpm, to check on timing behaviour.
If the timing is going to get erratic because of free play in the points pivot or similar fault, it will probably do it before you reach 4,000 rpm.
Having a spark and then not having a spark is strange. Retarding with the hand lever can make the spark very weak. Or the points may be oily- clean them by dragging dry paper through them.
Re: Timing a mag? [Re: 6T] #655000
05/31/16 5:01 pm
05/31/16 5:01 pm
6T Offline OP
6T  Offline OP
...I will post some more 'photo's TT but I ordered the key for the alternator nut but got this instead.... With the crank locked with the correct one it'd be possible to turn the crank forwards with this nut...more to follow......
BMW R1100rt
6T 1965
T110 1958
Page 2 of 2 1 2
