Kenacu
Kenacu
RED BANK NJ
202 registered members (1xfatboy), 2,157 guests, and 545 spiders.
koan58 89
Lannis 82
505,158 mail-order LSR
Topics66,049
Posts639,308
more piston ring problems #653456
05/19/16 6:05 pm
05/19/16 6:05 pm
florida but from Australia
mark ozzie Offline OP
so today I again tried to install the barrels and broke another ring here's what I found
according to what I can work out I have std a50 pistons so I ordered std a50 rings after breaking another ring I started doing test fits inside the barrels and found every ring is to big?
so can I simply (carefully) grind some off the ends until they fit or have I got bigger problems?
Re: more piston ring problems [Re: mark ozzie] #653485
05/19/16 11:15 pm
05/19/16 11:15 pm
kevin roberts Online content
fefsa
kevin roberts  Online Content
fefsa
i bought a ring-end grinder a while back to use in adjusting rings on a machine i'm building. i wanted to use the old triumph figure of 10 to 14 thousandths.
put them in yesterday and all the rings were in spec-- 10 to 14 thousandsths, without me having to do anything. so now i have this really cool little ring grinder i still haven't been able to use.
on the other hand i have more faith in the piston maker and the man who bored my cylinders to match them.
live every day.
die once.
Re: more piston ring problems [Re: mark ozzie] #653500
05/20/16 5:40 am
05/20/16 5:40 am
BSA_WM20 Online content
BSA_WM20  Online Content
No.
You have been supplied with the wrong sized rings
What you end up with is an egg shaped ring .
It will seal . sort of for a while then wear rapidly where the uneven shape applies too much pressure on the bore witch you can also wear a groove into.
It was a nasty cheap bodgers trick to flog off a bike with a stuffed bore.
grind down an oversized ring till it just fits then sell the bike quick.
Don't even think of doing it.
Now to fit your rings get some dowel big enough to cut a hole to go over the cylinder stud and pot a hole in the other end for a short bolt.
Four will usually do the job about 2" to 3" long so you can get your fingers to the bottom of the bore spigots.
Position the pistons with rings just entering the spigotts then hang a big stilsons wrench on the crank nut so it is trying to rotate the crank into the barrels.
You now have both hands free, barrels suppored and the crank trying to wind the pistons into the barrels.
All you need to do is to squeeze the rings together and the piston will slide up all by itself.
Not too dissimilar the the method used at the factory.
Re: more piston ring problems [Re: mark ozzie] #653744
05/22/16 12:27 am
05/22/16 12:27 am
well then I have a problem as the supplier ordered std rings and this is what I got if I cant get std rings then the engine is done
Re: more piston ring problems [Re: mark ozzie] #653745
05/22/16 12:31 am
05/22/16 12:31 am
will a7 rings fit my a50?
Re: more piston ring problems [Re: mark ozzie] #653746
05/22/16 12:55 am
05/22/16 12:55 am
OZ
Triless Online content
Triless  Online Content
OZ
Std A7 bore,66mm ( 2.598" ). Std A50 bore,65.5 (2.579" ).
Re: more piston ring problems [Re: mark ozzie] #653758
05/22/16 5:41 am
05/22/16 5:41 am
No the problem is A 50's are a small market and you are assuming that the shop actually checked what they sent you .
Some one tossd the A50 rings in the wrong bin and blind Billy the illeterate store man went to row 3 level 5 bin 9 and grabbed whatever was in there then sent it to you.
A lot of the supposed BSA retailers would not know a real BSA part from a pigs bum. You have to check everything.
Trojan are Triumph & BMW people so just order BSA parts from a catalogue and put them in a bin, sometimes even the correct one.
British Spares are Notrun people , they know Notrun parts but they sell BSA parts as well but would be hard pressed to tell one wrong part from another.
Modak are great for anything made before 1930.
Bob at Classic All Parts ( Jim Eades) has no idea at all so if a pert is not labled he is stuffed, can't even count the number of wrong parts he has tried to sell me which is why I don't buy anything from him anymore as I can't walk into the shop and say" NO that is wrong" .
Draganfly are somewhat the same. From memory they were Douglass specialists and have over time kept on acquiring stock for shops that close down so now sell everything British.
Re: more piston ring problems [Re: mark ozzie] #653796
05/22/16 1:06 pm
05/22/16 1:06 pm
so is there a supplier out there that anyone recommends will sell me the correct part ?
Re: more piston ring problems [Re: mark ozzie] #653797
05/22/16 1:34 pm
05/22/16 1:34 pm
Even the best have problems sometimes. And they can only sell what they can get.
Seems like I remember a discussion from a while back that A50 rings were scarce.......and standard maybe almost nonexistent. I'd call Baxter's for sure. I checked Draganfly's site, they don't have them.
If you search for a while with no luck, you could always put that project aside and then collect an A65 top end for it- basically bolts right on.
Did you ever put a parts wanted ad here on the classifieds? That works pretty good....doesn't always look like it because guys use personal messages.
Re: more piston ring problems [Re: mark ozzie] #653798
05/22/16 1:39 pm
05/22/16 1:39 pm
I also looked at Draganfly in the case maybe you could bore to next size up. Looks like you might find oversize pistons and rings for A50, but it was $$$$. That's what made me think of the A65 top end. You'd need head, barrel, pushrods, pistons and rings. Not much else.
Re: more piston ring problems [Re: mark ozzie] #653815
05/22/16 4:19 pm
05/22/16 4:19 pm
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
dhill@hastingsmfg.com
Dawn Hill at Hastings is someone who can probably help .
Drop her an email with particulars ....
https://www.hastingspistonrings.com/ring-finder
1962-70 500cc Eng. Royal Star
Std piston size ... 2.579"
Cyl. 2
Hasting Piston ring set ... 6940
Quantity , comp rings ... 4 - 1/16
.................... oil rings ... 2 - 1/8
Re: more piston ring problems [Re: mark ozzie] #653819
05/22/16 5:31 pm
05/22/16 5:31 pm
V
VicCyclone Online content
VicCyclone  Online Content
V
Look on UK e Bay - http://www.ebay.co.uk/itm/BSA-A50-PISTON-RINGS-JOB-LOT-/361261415518
They've been on there for several months. The only reason I haven't bought them is that they are all STD. Some are apparently NOS.
Good luck
VicCyclone
1965 A50 Cyclone Clubman
1966 Victor GP
1967 Victor Special
1968 Victor Special
1968 A65L
2009 HD FXDC
Re: more piston ring problems [Re: mark ozzie] #653820
05/22/16 5:36 pm
05/22/16 5:36 pm
V
V
I've used A7 STD rings on A50 +20 pistons I should think that A7 +20 will fit A50 +40.
VicCyclone
1966 Victor GP
1967 Victor Special
1968 Victor Special
1968 A65L
2009 HD FXDC
Re: more piston ring problems [Re: mark ozzie] #653822
05/22/16 6:17 pm
05/22/16 6:17 pm
thanks guys those are what I need but he doesn't ship to usa
Re: more piston ring problems [Re: mark ozzie] #653832
05/22/16 7:42 pm
05/22/16 7:42 pm
V
V
Have you asked him? Sometimes they will even if they say UK only on the listing.
VicCyclone
1966 Victor GP
1967 Victor Special
1968 Victor Special
1968 A65L
2009 HD FXDC
Re: more piston ring problems [Re: mark ozzie] #653839
05/22/16 9:06 pm
05/22/16 9:06 pm
all sorted thanks guys my brother inlaw in uk got them for me and is sending them over I also found a listing for hastings rings with the correct measurements so bought them to
Re: more piston ring problems [Re: mark ozzie] #653842
05/22/16 10:01 pm
05/22/16 10:01 pm
And when they arrive, check them in the bore, every ring before you try to install
Re: more piston ring problems [Re: mark ozzie] #653846
05/22/16 10:40 pm
05/22/16 10:40 pm
melbourne florida
bodine031 Online content
bodine031  Online Content
melbourne florida
So you are in Florida and did not call MAP Cycles in St Pete???
Re: more piston ring problems [Re: mark ozzie] #653852
05/23/16 12:51 am
05/23/16 12:51 am
no one told me of map and did not know about them so no I didn't if I had known I would have
Re: more piston ring problems [Re: BSA_WM20] #653853
05/23/16 12:52 am
05/23/16 12:52 am
I will thanks
Re: more piston ring problems [Re: mark ozzie] #654591
05/28/16 8:43 am
05/28/16 8:43 am
Cleveland, Ohio
Jack D Offline
Jack D  Offline
Cleveland, Ohio
Might not be great advice, but I got rings by bringing my piston and jug into a local race shop that builds high performance auto engines. He was the one who did the valve job, cleaned and honed the bore and jug and piston (out of pity). After measuring, he pulled out a paper catalog (yes the old kind from years ago) and found ones that fit and ordered them. Not NOS BSA but I can stand on my Kickstarter on compression and she doesn't move. Maybe go that route and compare what you get with somebody like that. They have always given me good advice. I know not close to you but maybe you have a shop nearby.
K & B Engine and Machine, North Olmsted, Ohio
Re: more piston ring problems [Re: mark ozzie] #654660
05/28/16 9:56 pm
05/28/16 9:56 pm
Those places are few & far between.
Try and find any retailer who can find a part without a vin number off a cumputer file with more transcription errors than I care to imagine.
Even the ring catalogues themselves rarely give you dimensions, just applications which is not very helpful in our case.
Page Time: 0.071s Queries: 15 (0.006s) Memory: 1.1611 MB (Peak: 1.4670 MB) Zlib disabled. Server Time: 2018-02-24 14:18:56 UTC
