Blapper
Blapper
Kent UK
22 registered members (Alan_nc), 219 guests, and 434 spiders.
10419 Registered Users
btour 85
Rohan 77
Triless 70
reverb 68
713,648 mail-order LSR
Topics68,327
Posts665,185
Members10,419
drain plug gearbox 750 commando #65106
05/01/06 4:34 pm
05/01/06 4:34 pm
belgium
manxman88 Offline OP
belgium
can anybody help me with the size of the drainplug of a norton commando 750.
The thread in the case is gone, so helicoil will be called in for help, but what size???
Re: drain plug gearbox 750 commando #65107
05/01/06 4:58 pm
05/01/06 4:58 pm
Hamilton, Mass. USA
Dave Comeau Offline
Crew Chief
Dave Comeau  Offline
Crew Chief
Hamilton, Mass. USA
From the norvil website
040138SS BOLT - GEARBOX DRAIN - 3/8" BSF - 0.525"A/F HEXAGON C D L S 3.90
dynodave
BSA 3 1961-1963
Ducati 3 1992-2002
Norton many 1951-1975
Re: drain plug gearbox 750 commando #65108
05/02/06 7:18 pm
05/02/06 7:18 pm
belgium
belgium
Thanks for the information! The partnumber 040138 is correct,but when I measure the bolt, the outside thread diameter is 12.55mm. This should be 1/2" (=12.70mm) or 31/64" (=12.30mm). TPI is 20. In the old-britt they refer to 040138 NORTON, Bolt, 3/8 x 20, 1/2", Gearbox Drain Bolt.
So is the bolt I have still the original one?
The bolt has a magnet in the core on top.
Re: drain plug gearbox 750 commando #65109
05/02/06 8:31 pm
05/02/06 8:31 pm
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
1/2" x 20 is UNF, so it looks as if the gearbox drain has already been drilled and tapped oversize.
The original drain plug thread stayed at 3/8" x 20(BSF) right up to the end of production I believe, as my 1975 850 plug is the same, also there is no magnet on it.
The original drain bolts (that I have seen) are distinctive as the flats of the hexagon are slightly thinner than a normal bolt head as the face of the hexagon is machined to a shallow dome shape.
Re: drain plug gearbox 750 commando #65110
05/03/06 4:42 am
05/03/06 4:42 am
belgium
belgium
Thanks for the replies, it will be helicoil and I will use an original bolt.
Moderated by  Dave Comeau
