Todd Porter
Todd Porter
Georgetown, Kentucky
51 registered members (Andy Haldeman), 319 guests, and 458 spiders.
eberhard, Norman Woollons, LandoLando, MikeA, Jay Gilling
10255 Registered Users
Stuart 75
Lannis 70
607,571 mail-order LSR
Topics67,091
Posts651,065
Members10,255
66 500cc triumph nor enough thread on adjusters to #648570
04/13/16 8:05 pm
04/13/16 8:05 pm
albion New York
charlie akey Offline OP
albion New York
valve adjuster wont go in far enough .to much play . cam look ok push rods length ok new adj pins and nuts .Charlie
Re: 66 500cc triumph nor enough thread on adjusters to [Re: charlie akey] #648571
04/13/16 8:08 pm
04/13/16 8:08 pm
John Healy Online content
John Healy  Online Content
Do you have the proper head gasket for the year bike. The late 500 uses a very thin head gasket. If you you use the earlier thin one you can have this problem.
Re: 66 500cc triumph nor enough thread on adjusters to [Re: John Healy] #648591
04/13/16 10:45 pm
04/13/16 10:45 pm
albion New York
albion New York
will check . came in gasket for that year . lot more gap in adjustment
.030 or more
Re: 66 500cc triumph nor enough thread on adjusters to [Re: charlie akey] #648595
04/13/16 11:50 pm
04/13/16 11:50 pm
Montreal, Qc
rusjack Offline
rusjack  Offline
Montreal, Qc
I had the same thing. Same pushrods used in the same position before I did a top end job, so I knew something was wrong.
Make sure the pushrods are seated properly in the cam follower (use a lot of grease to feel them stick) and use a tool (zip tie, popsicle stick or something) to make sure the rockers sit exactly in the pushrods. I thought I was okay about 3 times before I got it right.
I repeatedly had three out of four valves adjust properly and the fourth be too loose. Best to pull the rocket box up a little bit and try to re-set the pushrods.
Re: 66 500cc triumph nor enough thread on adjusters to [Re: charlie akey] #648605
04/14/16 2:31 am
04/14/16 2:31 am
Qld, Aust and Otago,NZ
Ginge Offline
Ginge  Offline
What's the big picture Charlie?
Is this a new head, new valves etc. or is it just new adjusters?
Thinking the valve stems might be hanging in the guides or maybe the wrong length.
Ginge
Re: 66 500cc triumph nor enough thread on adjusters to [Re: Ginge] #648614
04/14/16 5:42 am
04/14/16 5:42 am
albion New York
albion New York
Hi used head . valve may be the problem . will check that . push rod open and close valve ok . don't have much information on engine thanks Charlie
Re: 66 500cc triumph nor enough thread on adjusters to [Re: charlie akey] #648826
04/16/16 3:43 am
04/16/16 3:43 am
Out There!
Nick Offline
Nick  Offline
Out There!
Measure valve heights from spring cup to top of valve stem, they should all be about the same.
Most likely a pushrod came unseated.
