MikeTRP
MikeTRP
Melbourne, Australia
190 registered members (1xfatboy), 1,751 guests, and 605 spiders.
Lannis 144
kommando 105
Stuart 67
476,705 mail-order LSR
Topics65,721
Posts635,225
A is a Megacycle 510-65 too much for street? #643884
03/11/16 11:14 pm
03/11/16 11:14 pm
Santa Barbara, California
KC in S.B. Online content OP
KC in S.B.  Online Content OP
I have a set of new cams I bought years ago, and was thinking maybe I could use them. Megacycle cams # 510-65. Has anyone here used them? From the site:
For 650 or 750. Best all around street and road cam. Broad power band, mid-range and
top-end. TT style performance. Use modified pistons and springs. (Recommended by Motorcyclist Magazine)
510-65 .355" .355"292101 104.5 .163" in .150" exR45 btc/67 abc 72 bbc/43 atc
295 TDC LIFT
Looks like the lift is enough to require piston / valve relief and springs. That makes me wonder if this would be too much of a hotrod cam. Not 20 yr's old anymore........
Down to 1 BSA, 2 Triumphs, 2 '56 Chevys
Re: A is a Megacycle 510-65 too much for street? [Re: KC in S.B.] #643889
03/11/16 11:55 pm
03/11/16 11:55 pm
Bishop, Calif.
desco Online content
desco  Online Content
Bishop, Calif.
I've got the same spec sheet.Given todays shity gas it would not be as hot as it was in the day.
But, the hot rod is in the control of your right hand. Make the mods and go for it.
My 68 has the 510-05. It's a hoot to run it up to 7,000 rpm. Don't do it often but it's nice to know you can. I'm 71. When you quit living, you start dying.
Re: A is a Megacycle 510-65 too much for street? [Re: desco] #643997
03/12/16 5:14 pm
03/12/16 5:14 pm
Running from demons in WNY
Hillbilly bike Online content
How does the fuel make the cam not as "hot"?
Re: A is a Megacycle 510-65 too much for street? [Re: KC in S.B.] #644026
03/12/16 7:59 pm
03/12/16 7:59 pm
Edgewater, Md
Blown Income Offline
Edgewater, Md
I have these cams in my dads 68 Bonnie with a 750 Routt Kit and 10:1 pistons. These cams are great in a Triumph!
1955 BSA Bantam D1 Plunger
1961 BSA C15S
1966 BSA spitfire
1969 Triumph T100C
1970 Triumph TR6R
1972 BSA Lightning LSR Bike
1974 Triumph T150V
Re: A is a Megacycle 510-65 too much for street? [Re: Hillbilly bike] #644043
03/12/16 10:15 pm
03/12/16 10:15 pm
Bishop, Calif.
Bishop, Calif.
"hot" Poor choice of word for a short explanation. The cams would still do what they do but without the high octane leaded gas to produce whatever it does the performance would probably be somewhat reduced. Not as much need to be worried about a hotrod effect.
The Megacycle cams improved my 68 noticeably but the few tanks of av gas I ran through made it better still.
Re: A is a Megacycle 510-65 too much for street? [Re: desco] #644112
03/13/16 10:45 am
03/13/16 10:45 am
According to specs on fuel company websites , aviation gas is actually slightly less BTU's than pump gas and a bit less dense....So power improvements not directly related to detonation might mean your bike engine is jetted a bit rich for pump gas....If longer duration cams are fitted to an engine with no other changes this will lessen the likelihood of detonation at low to moderate RPM's...
I ran my T120/750 on both non ethanol 91 octane pump gas and the same pump gas blended 50/50 with 107 MON octane leaded race gas...There was no difference in performance I could feel on the road...Of course the engine would detonate on the 91 non ethanol with too little rpm under load...
There's a lot of variables here and your experience may differ from mine..
Re: A is a Megacycle 510-65 too much for street? [Re: KC in S.B.] #644185
03/13/16 10:59 pm
03/13/16 10:59 pm
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
I've been running those specs. on the street since the '90's. As usual,it is all in the combo. Jack
Re: A is a Megacycle 510-65 too much for street? [Re: KC in S.B.] #644470
03/15/16 11:06 pm
03/15/16 11:06 pm
Out There!
Nick Offline
Nick  Offline
Out There!
Be sure to check cam-to-crank clearance. When building my street 750 I ordered what, according to Megacycle's catalog, was one of their milder cams. However, when installed in the cases there was frighteningly little clearance between the cam and the crank, so I sent it back and exchanged it for their mildest cam, which I mated to 'R' followers. Very happy with the performance.
