lincolntbird
lincolntbird
Caveside, Tasmania, Australia
192 registered members (68 royalstar tony), 1,661 guests, and 517 spiders.
10036 Registered Users
Lannis 148
kommando 113
478,672 mail-order LSR
Topics65,743
Posts635,554
Members10,036
1958 B33 Speedometer. #639224
02/08/16 7:51 pm
02/08/16 7:51 pm
Tridentman Online content OP
Tridentman  Online Content OP
The speedometer fitted to the B33 I am working on does not work so I am going to get it refurbished.
Before I do this I just want to confirm that it is the correct speedometer.
The markings on the face are "SC 1302/04 1000"
It is driven off the gearbox.
Can anyone with a Smiths Chronometric listing please confirm or otherwise that this is the correct head?
Many thanks in advance for info.
Re: 1958 B33 Speedometer. [Re: Tridentman] #639279
02/09/16 2:51 am
02/09/16 2:51 am
The 54-58 chart I have does not agree with your numbers. It shows the 58 B33 with 3305/04 for solo and sidecar. The 58 B33 Special uses 3305/08. Ratios are not shown but I would be surprised if 1000 was the correct ratio for a STD gearbox and normal sprockets.
Re: 1958 B33 Speedometer. [Re: Tridentman] #639330
02/09/16 11:36 am
02/09/16 11:36 am
Gordo--many thanks for the info.
I rather suspected that the speedo was not correct---I bought the bike as a non running bitsa so this sort of thing is not unexpected.
I guess the fact that the same speedo is specced for solo and sidecar use is that the difference between the two is the number of teeth on the engine sprocket---so the speedo is not affected.
Any idea what my unit was originally used on?
All info gratefully received.
Re: 1958 B33 Speedometer. [Re: Tridentman] #639386
02/09/16 3:58 pm
02/09/16 3:58 pm
Tridentman: I have limited charts and I am on not sure how unique the codes are between brands of bikes. In the Matchless section of one of my charts there are some 1302 speedos ie G80 1959- 1302/01, G12CS (yr?)1302/01. That is as close as I can get.
As for ratio on the face for a STD box, 19T gearbox sprocket and 42 rear sprocket I would expect to see something around 1450 depending on the exact tyre you have. An 80 inches rolling circumference tyre would be need 1459 and the smaller tyres would need a larger number.
