wbabojo
wbabojo
Ipswich England
26 registered members (Andrew Dunham), 199 guests, and 364 spiders.
MackenzieBM, Metisseguy, Justintimeclark, Tim Pedder, blayde54
10481 Registered Users
NickL 100
franko 86
Triless 69
751,679 mail-order LSR
Topics68,883
Posts670,980
Members10,481
Page 8 of 10 1 2 6 7 8 9 10
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #635828
01/19/16 10:49 am
01/19/16 10:49 am
GrandPaul Offline OP
Installing the inner primary case; need to first do a test-fit with gasket and bolt up the 3 bolts at the crankcase, while checking the gap to the stand-off stud. This is fully nipped up, and there is a 1/16" gap. While doing this step, keep checking this gap! If it closes fully before the 3 bolts are tight, you COULD crack the case by tightening further.
This washer is a little thicker than 1/16
This washer is just right
Inner case now fully tightened with zero deflection and no possibility of cracking the case when I tighten the outer cover.
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #635830
01/19/16 10:52 am
01/19/16 10:52 am
I don't care for the long alternator stand-offs, they leave too much of the rotor/stator interface unused.
That's over 1/4" gap on a part that is only 1-1/4" wide; that's basically 20% inefficient.
I sorted (3) 1/4" spacers and get almost full interface between the alternator components, for maximum effect.
Plenty of chain clearance to the stator.
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #635831
01/19/16 10:54 am
01/19/16 10:54 am
Primary system done after having to add 2 thin shims behind the clutch basket to properly align the primary chain with the front edge of the primary case.
Finally looking like a motorcycle instead of a pile of parts...
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #635973
01/19/16 10:45 pm
01/19/16 10:45 pm
Assembled the brake caliper, installed & bled it; both brakes are done.
Slides are 3-1/2 cutaway
Main jets are 220s
Needle jets are 106s
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #635974
01/19/16 10:47 pm
01/19/16 10:47 pm
Carb parts swimming in 50/50 pine oil cleaner & hot water.
Quick rattle-can spray job on the left sidecover 'till the final decision is made as to what parts the painter will deal with.
I only had 40 minutes for the carbs to soak before I had to shut down for the evening. I'll heat up the mix tomorrow and give 'em another hour with each part getting hit with a toothbrush while they soak. 40 minutes made a difference, but not as much as Berrymean's Chem-Dip does (at 3x the price).
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #636087
01/20/16 5:02 pm
01/20/16 5:02 pm
Carbs got 4 more hours of soaking, then a soft brass wire brushing.. Nice, but not as good as Berryman's Chem-Dip. Oh well, it was worth the attempt.
Spiffy carbs ready to bolt back on.
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #636139
01/21/16 12:05 am
01/21/16 12:05 am
Valve lapping time!
First the coarse, then the fine.
Hand lapping tool works great. Using a drill on the stem end is not recommended.
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #636141
01/21/16 12:10 am
01/21/16 12:10 am
Closeup of intake valve lapped face also came out blurry so hard to clearly see the thin gray band of mating face.
Done with lapping valves. I'm going to polish up the combustion chambers tomorrow.
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #636250
01/21/16 4:17 pm
01/21/16 4:17 pm
Engine mocked up in preparation to have the bike serial numbers inspected by the local Police Dept.
Took some 0000 steel wool and Simple Green degreaser to the pipes; not too bad! There are 2 or 3 scratches, mostly covered by the bodywork.
Pipes, tank and temporary seat in place.
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #636251
01/21/16 4:19 pm
01/21/16 4:19 pm
Bodywork in place FINALLY. It's only mocked up, but it's looking pretty close to what it will look like when it's done. Now to book the P.D. inspection.
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #636279
01/21/16 7:30 pm
01/21/16 7:30 pm
Headlights installed but not wired. (front lower mount installed, but you can't see it)
Tail light temporarily installed with previously installed (incorrect) license plate back, (chrome bit)). Mufflers wil be aligned after final assembly.
Right side beauty shot, front fender not drilled or mounted yet.
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #636281
01/21/16 7:32 pm
01/21/16 7:32 pm
I need the proper original layout of the indicator lights (red, blue & amber)
Cockpit looking almost complete. Clutch pull is a little heavy, I'm going to install a stuffer plate to bring the stack height up.
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #636295
01/21/16 8:19 pm
01/21/16 8:19 pm
Florida PanHandle
Zombie Offline
Zombie  Offline
Florida PanHandle
What a GREAT looking machine Mr. GrandPaul!
I haven't read the entire thread yet but I am in awe of how cool it looks.
What gets me the most about it is, I remember those bikes zooming around the television, and seeing the model kits in the stores.
It's almost hard to believe that something from my childhood comes back to remind me of how frickin old I'm getting.
For the fellas in their 70's-80's, I cant imagine it. It must have been insane watching the chariot races, and being constantly on guard for T-Rex-s, and Pterodactyl-s.
Very cool bike Mr. Paul!
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #636313
01/21/16 9:46 pm
01/21/16 9:46 pm
Really nice to see a proper narrative and photos of "how to assemble", with the right shims and all. This is going to be a great bike, and the build info is much appreciated!
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #636320
01/21/16 10:48 pm
01/21/16 10:48 pm
I have been getting one heck of an education about the medium-rare John Player Norton from people on the various forums, facebook, and vendors including Phil Radford of Fair Spares America who is a recognized authority on the subject.
This thread brings everything I've learned into one place (not to say there isn't a lot more to know "out there", I'm still searching for details).
The back story on this bike is definitely unique to me. "One of the ones that got away" came back (at a price). Even though I've acquired the taste for it, I knew I was going to be selling it before I ever bought it.
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #637078
01/25/16 7:29 pm
01/25/16 7:29 pm
Zener diodes, "before & after"
Spiffy clean underside; centerstand installed.
Just a mock-up. I sure love timing side shots of Commandos and Bonnevilles.
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #637079
01/25/16 7:32 pm
01/25/16 7:32 pm
One of these two tanks will be for sale; still haven't decided which one.
"Stable mates", sans bodywork. Waiting for rings for the JPN and title for the 880 Special...
(2) Replica OEM solo seats ordered for the JPN today. I made a deal to send them my fairing and they'll send me a brand new one after they model it and start making new ones. So, I will have a FULL JPN bodywork set for sale soon (fairing, mounts, windscreen, tank shroud, tank & seat), plus one spare rough fairing.
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #637433
01/28/16 2:07 pm
01/28/16 2:07 pm
Shipped out my new JPN fairing on FedEx insured for full replacement cost, to Airtech. They'll make a mould to reproduce it, then send it back to me. I'll get the first clean copy they produce at no charge (other than the cost to send it to them, which wasn't cheap).
So, will soon have one complete JPN bodywork set for sale, ready to bolt on (with extended gas tank)
I'm going to have them copy my Tracy 2000 & 2001 quarter fairings, on the same terms. I've searched high and low for those...
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #637621
01/29/16 8:55 pm
01/29/16 8:55 pm
Just got done reverse engineering the JPN fairing brackets and ordering all the materials to build a few sets for myself & Airtech. I love playing with AutoCAD.
I may be the only source for the brackets once they're done (other than onsie-twosies stashed in people's sheds and garages) I haven't found any after searching pretty extensively.
Really itching to get in my rings and get the engine done. Less than a day's work left to fire it up...
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #637666
01/30/16 8:34 am
01/30/16 8:34 am
you've moved really fast on this paul.
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #637668
01/30/16 8:50 am
01/30/16 8:50 am
Originally Posted by GrandPaul
The back end on yours looks a little lower than the auction photo, are there different spring lengths for the JPS compared to the normal commando?
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #637669
01/30/16 9:10 am
01/30/16 9:10 am
kommando Offline
kommando  Offline
Allan, look at the relationship between the rear tyre and the mudguard and the bottom shock nut and the silencer on both, they are very similar. What you are picking up on is the seats being different and GP's is not as high has the lower extension for the racing number and that makes his look like its riding lower but if it is its only by mm's.
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #637679
01/30/16 10:23 am
01/30/16 10:23 am
I think your right John. The number board also makes it look closer to the back tyre
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #637680
01/30/16 10:25 am
01/30/16 10:25 am
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
The seat looks "droopy"
BSA B31 500cc "Stargazer"
Greeves 200cc "Blue Meanie"
Greeves 360 Challenger
Jawa 500cc "Llareggub"
'35 OK Supreme
'36 OK Supreme
Re: 1974 John Player Special Norton Commando 850 resto [Re: GrandPaul] #637685
01/30/16 11:26 am
01/30/16 11:26 am
Correct seat is winging it's way from the west coast.
I'll have it upholstered and installed in a week or two at the most.
