sprung hub
sprung hub
Sacramento, CA
31 registered members (998John), 289 guests, and 408 spiders.
vietnammotorbike, Lennart Liljedah, Mal Wood, FireGuyKC, spuggy
10288 Registered Users
Stuart 94
Lannis 65
Mori55 60
636,022 mail-order LSR
Topics67,365
Posts654,052
Members10,288
C'do jumping out of first gear?? #62693
02/18/05 9:06 pm
02/18/05 9:06 pm
Saint Petersburg,Florida,USA
John Gough Offline OP
I recently inherited a 1972 Combat Commando. On stiff acceleration the bike jumps out of first gear. I replaced the first gear layshaft bushing.( suggested by the Norton INOA list) This did not solve the problem. Any suggestions on what I should look for next? Thanks in advance for your kind consideration of my problem.
John R. Gough II
'65 Velocette MSS
'55 BSA Super Rocket
70 Triumph TR6
Re: C'do jumping out of first gear?? #62694
02/18/05 11:59 pm
02/18/05 11:59 pm
Orlando fla/ shady valley Tn
bill50cal Offline
bill50cal  Offline
the dog's on layshaft second. the holes in layshaft 1st that the dog's engage in. shift fork on layshaft. endplay in layshaft.
bill
windy
72 combat
switchbackcreek.com
Re: C'do jumping out of first gear?? #62695
02/19/05 4:18 pm
02/19/05 4:18 pm
Seattle, WA USA
Dr_Hiller Offline
Dr_Hiller  Offline
Seattle, WA USA
John:
Though I can't, here's a couple 'o links that might help....
Fred at Old Britts recently put up a detailed Tech series on the Commando Transmission on the Build & Restore page - scroll down to #8, on this page: http://www.oldbritts.com/ob_new_bike.html
The direct link to his "how it works" article is here: http://www.oldbritts.com/gearbox_info.html and the dissasembly/inspection guide is here: http://www.oldbritts.com/gearbox_info.html
Take care,
David
Ride safe,
David
1971 Norton Commando (parts bucket mongrel)
Re: C'do jumping out of first gear?? #62696
02/20/05 10:27 am
02/20/05 10:27 am
belgium
ludwig Offline
ludwig  Offline
belgium
can you see the kickstart move outwards a bit when shifting in first ?
Lateral play of kickstart shaft should be minimum .
put shims between kick mech. and steel bushing in primary cover .
Re: C'do jumping out of first gear?? #62697
02/20/05 12:59 pm
02/20/05 12:59 pm
Thanks very much to all of you for your kind help with my problem. I now know where to start. Thanks again John G.
John R. Gough II
'65 Velocette MSS
70 Triumph TR6
Re: C'do jumping out of first gear?? #62698
02/20/05 6:01 pm
02/20/05 6:01 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
John G -
Although the cause might be lay shaft end play, all the damaged parts should be replaced or at least seriously inspected and compared to new parts when the shaft is fixed.
This would include the shifter cam, shifter fork, first gear and the mating dogs (2nd gear lay?). If you fix half of it you'll have to pay all over again when and if the jumping begins again.
Hope this helps. bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: C'do jumping out of first gear?? #62699
02/21/05 12:37 pm
02/21/05 12:37 pm
Annapolis, MD
Dennis B, R.I.P. Offline
Annapolis, MD
Before you take apart your gearbox, it's a good idea to check the play
in the sleeve bearing. That's the big one on the drive side.
first remove the primary inspection plug (middle plug) and move the chain
up & down (hard). With your other hand feel the gearbox sprocket.
A little bit of motion of the drive chain is normal, but the sprocket should not
have any noticeable fore and aft movement. Or clunk-clunk feel.
When these bearings go bad, they spin in the case.
The repair for this would depend on just how much damage was done.
If the bearing is loose, you will need to take apart the primary also to gain access to it.
Hope this helps
Dennis B
P.S.
The article that Fred Eaton at Old Britts did is excellent. However he said to use Loctite Red for a loose sleeve bearing, I would suggest using Loctite Sleeve Retainer 640.
Member # 182
'73 750 Commando
'72 Combat Commando
'71 Triumph Blazer
'69 Victors
'68 Starfire
'51 Royal Enfield 250 'S'
Re: C'do jumping out of first gear?? #62700
02/21/05 3:11 pm
02/21/05 3:11 pm
Seattle, WA USA
Dr_Hiller Offline
Dr_Hiller  Offline
Seattle, WA USA
Dennis:
I'll see Fred today and pass on your suggestion. He's always open to "better" approaches - and genuinely appreciative to boot.
(See the BAD gears in his cutaway tranny? They're out of my bike. Ughh.)
Take care,
David
Ride safe,
David
Moderated by  Dave Comeau
