The Bonneville Shop
CaptainPugwash
CaptainPugwash
Conisbrough,Yorkshire, UK
22 registered members (Alan_nc), 204 guests, and 434 spiders.
10528 Registered Users
franko 90
NickL 66
785,121 mail-order LSR
Topics69,220
Posts674,261
Members10,528
Commando Head Steady Upgrade #62389
04/15/04 12:33 pm
04/15/04 12:33 pm
Anonymous OP
Unregistered
Anonymous OP
Unregistered
Is anybody out there using the upgraded head steady from either Norvil or OldBritts? I'm considering upgrading and would like some impressions on each one.
I prefer the look of the OldBritts one but I'm not sure what to make of it having only ONE isolastic bush inside of it. The Norvil uses two bushes, but The overall constuction doesn't look as nice/solid. It also appears as if it may weigh a bit more than the OldBritts version.
Any thoughts?
Re: Commando Head Steady Upgrade #62390
04/15/04 1:19 pm
04/15/04 1:19 pm
Flint,Mich
norbsa48503 Offline
norbsa48503  Offline
Flint,Mich
Putting the up grade on sometimes makes the bike shake harder. I have seen people put them on and take them off again.Befofe you buy invest some time and read this article to fully understand what this can do for you. http://www.vintagenet.com/phantom/wsc.html The stage one mods are minimal and well worth the time. The steel one as opposed to the stainless one is easyer to machine. Many people here in Michigan have modified these head steadys at the iso on the top to make them work right. norbsa
norbsa
1960 TR6
1963 Super Rocket
1965 650 Star
1966 441
1968 Thunderbolt
1969 Twinkle 250
1972 Fastback
1974 Roadster
1970 S.S
Way too many BSA's not named
http://decentcycles.com
Re: Commando Head Steady Upgrade #62391
04/15/04 10:28 pm
04/15/04 10:28 pm
Hamilton, Mass. USA
Dave Comeau Offline
Crew Chief
Dave Comeau  Offline
Crew Chief
Hamilton, Mass. USA
I have the Fairspares (now Norvil-england) headsteadies on my 72 combat and 75 E-start.
My combat is very smooth with all vibrations gone by 1800 rpm. The 75 E-start is another thing. It is horrible.
I think that there is much more to this solastic thing than most people realize. The early rubbers were small and very compliant, while the later ones are harder.
http://www.gis.net/~dynodave/images/frontiso.jpg
I am going to study this area more in the future. In the mean time I am going to stay away from the new "magic" adjustable ISO's. We have locally tried to drill 3/8" holes through them to soften them back up, more similar to the early deflection rate. The results will be in later this year.
dynodave
BSA 3 1961-1963
Ducati 3 1992-2002
Norton many 1951-1975
Re: Commando Head Steady Upgrade #62392
04/20/04 12:44 am
04/20/04 12:44 am
Anonymous OP
Unregistered
Anonymous OP
Unregistered
Hey guys tanks for the info. Norbsa, I think I went cross-eyed reading all that. Incredible stuff-I don't thin I'll have the energy to go through all of that, but you've given me some good things to look for.
Dave, when I rebuilt my isolastics I got rubbers from two sources - and I see what you mean. One set was completely softer than the other. Right or wrong I ended up putting in the stiffer ones only because I kept the orginal 69 spacer in the rear (which only allowed for two instead of three bushes) I'm sure I'll get chastised for that but it seems to working ok. I looked all over for the "Metalastik" ones but didn't have any luck.
Being a machinist by trade I'm contemplating building something of my own. Maybe a cross between the Norvil and Oldbritts type. Or maybe I'll get lazy and just settle for smuggling a Norvil one back from the UK when I'm over there in a couple weeks....I hate paying all that shipping! laugh
Re: Commando Head Steady Upgrade #62393
04/25/04 2:08 am
04/25/04 2:08 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
This was a new area for me. Even as a Norton mechanic in the early 70s I never did anything but check the end gap. They remained a complete mystery until recently.
I installed one of the stainless units on a rebuild going on in our shop. It was very well made and a breeze to install. However, it struck me that the entire unit has to be replaced if it goes bad. I also found that the front unit supplied to me was about .060" too long to fit in the frame. I'm not sure if this was the powder coat paint job or what. Sure was a pain having to lift the engine back out to rectify.
On my personal bike I opted for stock units. More pieces, but simpler to work with overall I thought.
BTW, they suggested the Lucas rubber lube for installation, then charged a heafty price. I just used Pam vegtable cooking spray.
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Commando Head Steady Upgrade #62394
12/27/04 1:04 pm
12/27/04 1:04 pm
Mediterranean coast of France
Geoff3 Offline
Geoff3  Offline
Have you had a look at the "Taylor" headsteady marketed by http://www.clubmanracing.com? seems a logical idea, allow movement up and down but not laterally.
BSA C15
BSA A65 Lightning 1966
Honda CB250
Vincent Rapide 1948
Norton Commando 750 Roadster 1971
Yamaha 250XT
MZ 250
Re: Commando Head Steady Upgrade #62395
01/24/05 4:59 pm
01/24/05 4:59 pm
Washington DC
W
Weathermann Offline
Weathermann  Offline
W
Washington DC
I am using a Norvil (Les Emery) stainless head steady on my '74 850.
Norvil Head Steady
I have not ridden enough other Commandos to offer any comparison but I can speak to a couple of issues with my head steady.
The transverse isolastic tube is welded to the head mounting plate (via two brackets) at the front bottom side only. This uneven welding around the circumference of the tube caused the tube to shrink slightly at the welded side, bowing the tube into a slight banana shape. Thus, the two ends of the tube were not parallel to each other and the length of the tube at the upper rear was longer than the length of the tube at the lower front. If the clearance was set by measuring the gap at the upper rear, the lower front clearance was too large. Conversely, setting the gap from the lower front would result in no clearance, or too small of a clearance, at the upper rear.
I ended up making a small sanding jig to sand the ends of the tube until they were parallel to each other so that the clearance around the circumference of the tube would be consistent. I now have a small lathe and would probably use that to true the tube ends if the situation presented itself today.
Did it make a difference? I don't honestly know if the head steady would have worked just as well in the real world even if the desired clearance was established at less than a third of the circumference of the tube and the clearance at the other two thirds was larger than desired. I also do not know if this was unique to my head steady or common to this Norvil part. It certainly would have been nice if the tube ends had been parallel before the head steady was shipped to me.
Use this as you wish. I only note that if your head steady is like mine was, when setting the isolastic clearance, be sure to measure the clearance at multiple points around the circumference of the tube. Otherwise, you could end up in a situation where there is no clearance at one circumferential portion of the tube and the head steady is essentially "locked", even though your clearance measured at another circumferential portion of the tube was exactly as desired.
Also, with this head steady, there is very little clearance to reach the third (center) head mounting bolt because of the transverse isolastic tube. I had to grind down the short end of the appropriate allen wrench to be able insert the wrench into the head of the bolt and to tighten this bolt.
One last note. This head steady uses a clamp that mounts to the small longitudinal frame brace tube. Two side plates mount between this frame clamp and the isolastics. Be sure to check the clearance between the gas tank and the two transverse bolts that mount the plates to the frame clamp. My Roadster tank tunnel was narrow in that area and I had to grind down the heads of the transverse bolts to provide clearance between the bolts and the tank.
Safe riding.
Weathermann
Re: Commando Head Steady Upgrade #62396
01/25/05 1:27 am
01/25/05 1:27 am
Springfield Nebraska
Richrd Offline
Richrd  Offline
If you went over to the yahoo/ inoa elist, in the archives you would find plenty on this subject.
including pics and info on how to make a rod end (taylor type) and a simpler puck type head steady as well as a comparison of the four types.
if you can't find that, email me of list and I'll try to copy them to you.
Rich
rlstone1@prodigy.net
75 commando interstate
06 Suzu..Suzu.. uh appliance
couple of beesas a ducati
and the Snake Bike
and a Honda?
Re: Commando Head Steady Upgrade #62397
01/25/05 11:13 am
01/25/05 11:13 am
Orlando fla/ shady valley Tn
bill50cal Offline
bill50cal  Offline
I was waiting to figure out the cost of making a rod end head steady and have come with a sale price of $100.00 us. I looked at all of the others out there and did not like any of them except the rod end style. after looking at the dave taylor I was not happy with it either. the top piece was just clamped around the one frame tube and could rotate along with the part on the head with its tall stand off could flex. mine is all aluminuim and is a bolt on ass. it uses the two holes that the origanal rubbers screwed into (cant rotate) and 3/8 rod ends (40,000psi tensel) I also have a BOLT ON KIT for the front mount so you no longer have to keep the mount properly adjusted (also $100.00)and found that it has tightend up the handling.
bill
windy
72 combat
switchbackcreek.com
Re: Commando Head Steady Upgrade #62398
01/28/05 10:56 pm
01/28/05 10:56 pm
E
Ed Wood Offline
Ed Wood  Offline
E
I have one of the Taylor headsteadies on my MK2. It doesn't add any vibration and one of the good side effects is that it frees up a lot of space under the tank for wires and cables and such. I think it's the way to go.
Re: Commando Head Steady Upgrade #62399
01/28/05 11:01 pm
01/28/05 11:01 pm
British Columbia
hh Offline
hh  Offline
British Columbia
bill50cal: I'm interested in a picture or more description of your front mount if you could, and also maybe a picture of your top mount. Thanks, hh.
Re: Commando Head Steady Upgrade #62400
01/29/05 1:41 pm
01/29/05 1:41 pm
Norway, just south of Oslo
jangg Offline
jangg  Offline
Me too am very interested in this, as I just now have the motor unmounted from the frame, going round wondering what solutions I want for my isolastics. Mod/Upgrade or not, - just renew the rubber...
regards
jangg
'73 Commando Basket - new aluminium cyl
'93 Ducati 900 SS
"Better lit a light than cursing the darkness"
(Confucius)
Re: Commando Head Steady Upgrade #62401
01/09/07 3:36 am
01/09/07 3:36 am
Somewhere in New Jersey
blimey-bill Offline
blimey-bill  Offline
I have the Norvil unit on my fastback. It works as intended. It will allow a lot of vibes through at low RPM, but everything smooths out at cruising speeds. One trait that I did notice though is that if the bike is up on the centerstand with the engine running, when you blip the throttle you'll hear a sort of shuddering vibration sound that's not there with a stock head steady.
'67 BSA Spitfire
'68 Commando Fastback
'75 T160 Trident
'02 Moto Guzzi LeMans
Re: Commando Head Steady Upgrade #62402
01/09/07 4:32 pm
01/09/07 4:32 pm
sugarloaf ny
injunmort Offline
injunmort  Offline
sugarloaf ny
my taylor also incorporates the spring tensioner. i have installed one on my rebuild but have not ridden yet. i did try one on my brothers and liked the result very much. also alleviated problem of frame mounts that were bunged up before i got the bike.
1948 indian chief
1937, 1939, 1962 norton es2
1950 triumph trw
1970 triumph bonneville
1975 norton commando
1972 bmw r75/5
various projects
Re: Commando Head Steady Upgrade #62403
01/09/07 4:59 pm
01/09/07 4:59 pm
belgium
ludwig Offline
ludwig  Offline
belgium
my headsteady .
same principle as taylor , but no arc movement .
simple , light and easy to make
Re: Commando Head Steady Upgrade #62404
01/10/07 12:33 pm
01/10/07 12:33 pm
belgium
ludwig Offline
ludwig  Offline
belgium
Panic ,
This thread is about head steady upgrade , right ?
Some use a norvil type , other a taylor type .
Your explanation of the lateral movement in the taylor head steady is correct , but purely theorethical .
(Sadly , as usual , you deleted your post ). The movement of the cyl.head in the vertical plane is about 1 mm max. when riding . This makes the lateral movement induced by the arc effect inmesurably small . certainly only a fraction of the lateral movement due to normal frame flex .
When I suggest a 3rd solution , with no moving parts , cheap ad easy to make for anybody with basic metal working skills , it is not to boost my ego . Maybe some fellow Norton rider could see something in it .
Do you have a problem with that ?
I thought this forum is about exchanging ideas and helping each other finding solutions .
Suggesting I have no knowledge of motorcycles or physics is insulting .
It is also incorrect , although , unlike some , I claim no guru status .
(It will be a long time before I get over 2000 posts ).
If I am wrong I'll be happy to admit it , but I'm not going to apologise , kneel before the Wise One , or delete my posts .
Re: Commando Head Steady Upgrade #62405
01/10/07 1:03 pm
01/10/07 1:03 pm
beltdriveman Offline
The word you are looking for is ...
RAMIFICATIONS.
I.E. If you alter one thing it will have an effect elsewhere.An effect that may or may not improve things.
As the Commando was only a stop gap model thrown together to keep them in business while new models to compete with the Japs were designed developed and put into production I doubt much development went into the isolastics.
Mr Hayward is probably selling various different ones so owners can play with and 'tune' them ...just as he did/does Triumph shock absorber 'rubbers'..as if any owner has got the test gear or facilities to determine the effects of changing them.....
MIND you mind over matter is a wonderful thing..I remember a gent bringing in to a well known 'tuner' his Goldy crank for balancing. It was going to cost 12..thats how long ago it was. The 'tuner took the crank, shoved it up between centres, clocked it, dropped it on a lump of wood, clocked it again and then drilled two holes in the flywheel opposite each other The owner picked it up the following Saturday and a week later came in saying how wonderful it was.
Wonderful stuff stainless steel, especially where vibration is present and hasnt been allowed for!!
Re: Commando Head Steady Upgrade #62406
01/10/07 3:55 pm
01/10/07 3:55 pm
new jersey usa
John RGS Offline
John RGS  Offline
new jersey usa
,_o
_ -\_<,
NOPGS #2
Re: Commando Head Steady Upgrade #62407
01/10/07 4:14 pm
01/10/07 4:14 pm
belgium
ludwig Offline
ludwig  Offline
belgium
Yes, you're wrong.
No, I'm not going to explain it
(dixit panic)
last time I heard this was from a 9 year old girl .
of course you are not going to explain it .
But you are shure going to delete it .
(so I saved it )
Moderated by  Dave Comeau
