Triless
Triless
OZ
28 registered members (AML), 198 guests, and 65 spiders.
10383 Registered Users
NickL 96
Mori55 88
Stuart 77
reverb 75
DavidP 72
Triless 71
Rohan 69
btour 66
689,531 mail-order LSR
Topics68,028
Posts661,829
Members10,383
Stripping down an old Tr6 engine - had it seized? #622331
10/18/15 9:34 pm
10/18/15 9:34 pm
Geneva, Switzerland
BrettF Offline OP
BrettF  Offline OP
Geneva, Switzerland
Hi Folks,
Finding some nasty damage while stripping down an old engine I got a year ago.
The primamry chain had snapped which chewed up a number of the primary cover screw areas as well as the tensioner aduster screw area. Tacho mounting threads stripped etc etc.
Most of it seems repairable though. The crank looks good also.
There was some colouting on one of the small ends. Im not too experienced with these engines so would like your advice if you beleive the small end seized/ran way too hot(lean?) or is that normal colouring?
the first pic is form the good piston
[img:left][/img]
these next two are from the suspect piston
[img:left][/img]
[img:left][/img]
I'm guessing new con rods are in order?
Thanks folks
Brett
Bikes:
'69 T120 on average (1967 rolling frame and 1971 Bonnie engine)
'56 1/2 T110 on average (58 rolling frame - with 55 iron head engine)
Re: Stripping down an old Tr6 engine - had it seized? [Re: BrettF] #622340
10/19/15 1:17 am
10/19/15 1:17 am
That looks pretty common. Best have a look at the piston pins. That will tell the story.
Also, give us a look at the piston sides and tops. There's a lot to be learned there.
Re: Stripping down an old Tr6 engine - had it seized? [Re: BrettF] #622342
10/19/15 2:02 am
10/19/15 2:02 am
Florida PanHandle
Zombie Offline
Zombie  Offline
Florida PanHandle
I agree that looks normal if not pretty clean for most any engine.
Once you have the pins out, take a look at the bottom of the piston dome. That will tell more about the running conditions of the engine.
There should be an even color inside the dome area. Black ash or shiny areas surrounded by black ash mean it was run too lean or to far advanced on the timing.
Back to the pins... They should press out pretty easily. Almost by hand pressure. If needed a large "C" clamp, a socket the same size (slightly smaller) than the pin, and I use a plastic piece from a cutting board as a backer on the opposite side with a piece of pipe the pin can pass into.
Re: Stripping down an old Tr6 engine - had it seized? [Re: BrettF] #622349
10/19/15 5:06 am
10/19/15 5:06 am
triton thrasher Offline
Were there signs of the big or small ends seizing, then new rods would be in order.
In fact, a rod would probably have broken already.
Looks normal to me.
Re: Stripping down an old Tr6 engine - had it seized? [Re: BrettF] #622361
10/19/15 9:32 am
10/19/15 9:32 am
JubeePrince Offline
JubeePrince  Offline
If the wrist pin(s) look like this, it's not good....
