markandrew
markandrew
orlando,florida
34 registered members (AndyB), 202 guests, and 467 spiders.
10256 Registered Users
Stuart 74
Lannis 67
608,341 mail-order LSR
Topics67,108
Posts651,199
Members10,256
Spring hub help #622078
10/16/15 9:12 pm
10/16/15 9:12 pm
Ontario Canada
Les Binnell Offline OP
Ontario Canada
I'm trying to remove the brake plate from a mark 2 spring hub. The wheels been sitting a long time, I imagine, and after removing the parts described in the manual, there is now nothing preventing it coming off, except it is stuck solid to the aluminum hub. If I remember correctly, the plate has about a 1/4" wall that slides over the hub, and I suspect there is some kind of reaction gone on between the steel plate, and the aluminum hub. I've tried some heat, and right now it's soaking in WD40, but I suspect it's not going to work.
Any suggestions?
Les
Re: Spring hub help [Re: Les Binnell] #622087
10/16/15 11:44 pm
10/16/15 11:44 pm
Ontario Canada
Bob Buchanan Online content
Bob Buchanan  Online Content
Ontario Canada
Hi Les:
Does the brake plate thread onto the spring box? No threads are shown in parts book like the Mark 1 pictures.Its been a while since I had one apart . Don't open spring box without longer bolts and spring compressor as in Nicholsons book or the old manuals.
Re: Spring hub help [Re: Bob Buchanan] #622121
10/17/15 9:18 am
10/17/15 9:18 am
Ontario Canada
Ontario Canada
Hi Bob, no threads, its a mark 2 hub, and it was the mark 1 that threaded on. I know this because of the hours I spent many years ago, trying to remove a mark 1 brake plate by pulling at it. I am not touching the spring box, I heard the horror stories.
Les
Re: Spring hub help [Re: Les Binnell] #622231
10/18/15 6:01 am
10/18/15 6:01 am
Pt Augusta, Australia
Mossy Offline
Mossy  Offline
You may just have to be patient and persevere with the heat and WD40
Cheers Mossy
1960 TR6B
1954 based Thunderbird Salt Lake Racer
1979 T140E
1951 6T Thunderbird Project
1981 T140E
1948 Speed Twin project
1976 Bonneville/Tiger Trail replica
2015 Bonneville T100
1949 Excelsior 197 Roadmaster project
1950 Excelsior 250 Talisman project
Re: Spring hub help [Re: Mossy] #622318
10/18/15 6:35 pm
10/18/15 6:35 pm
Ontario Canada
Ontario Canada
Thanks for all input. Patience and perseverance did win out in the end, aided by brute force and ignorance. The drive side of the axle has flats on it, which I clamped in the big vice I have, placed an extension tube over the brake plate bracing arm, added heat, WD40, and a little persuasion from a large hammer, and it moved. After that, it was just a matter of forcing it back and forwards till it slid off.
Les
