old-grizz
old-grizz
the wilderness
16 registered members (Allan Gill), 195 guests, and 392 spiders.
Mom1, flyntone, RNORTON, Gregg's Atv, T160vUK
10446 Registered Users
NickL 66
Jeff K. 59
DavidP 58
732,008 mail-order LSR
Topics68,565
Posts667,707
Members10,446
Powder Coating a Brazed Frame #619013
09/25/15 7:23 am
09/25/15 7:23 am
Georgia USA
Joel Greene Offline OP
Georgia USA
I'm getting started on my Velocette restoration and thinking about powder coating the frame. I've read that the heat from the powder coating (around 375F) can damage the brazed joints on a frame,in some cases actually causing them to fall apart! 375F doesn't seem like it would be hot enough to cause this. Thoughts? Experiences? Thanks
Re: Powder Coating a Brazed Frame [Re: Joel Greene] #619019
09/25/15 8:17 am
09/25/15 8:17 am
Irish Swede Offline
Irish Swede  Offline
Then don't powder coat it. Do what the factory did: paint it.
After all, you are doing a RESTORATION, correct?
Re: Powder Coating a Brazed Frame [Re: Joel Greene] #619029
09/25/15 9:21 am
09/25/15 9:21 am
UK Berks
AngloBike Offline
AngloBike  Offline
UK Berks
I have hear the stories but doubt the truth
I have seen the parts go into a powder coater's oven, which is like a big storage container.
The guys just walk in and ( wearing gloves) move the stuff on rails or wheeled trollies.
the ovens do not get switched on, heat up, switched off and cool down, they just "bung them in" for a given period, or use a long slow moving production line if doing lots of parts
I doubt if it is anyway near melting brass,
Just ask the guys how hot it is
Re: Powder Coating a Brazed Frame [Re: Joel Greene] #619031
09/25/15 9:26 am
09/25/15 9:26 am
kommando Offline
kommando  Offline
If the heat cannot affect rubber suspension sleeves its not going to affect brazing, the temp is not that high and its not for long either, just long enough for the powder to melt fuze and flow.
Re: Powder Coating a Brazed Frame [Re: Joel Greene] #619050
09/25/15 11:04 am
09/25/15 11:04 am
Florida PanHandle
Zombie Offline
Zombie  Offline
Florida PanHandle
The rumors were centered around the differing expansion rates of the metals.
While I am not a fan of powder coating I have no need to support rumor. 375*f is NOT enough heat to expand metals to the fatigue point. Given a margin for error of +75* you are still in a safe zone.
I wouldn't worry until you were above 500*f for an extended period. I can say that I have never heard or read about a bike frame failure (welded or brazed) due to the powder coating process.
Welding or frame straightening... yes but not powder coating.
Re: Powder Coating a Brazed Frame [Re: Joel Greene] #619053
09/25/15 11:11 am
09/25/15 11:11 am
triton thrasher Offline
It's Velocette forks that fall to bits when heated. The ends are soldered to the sliders.
Re: Powder Coating a Brazed Frame [Re: triton thrasher] #619066
09/25/15 12:12 pm
09/25/15 12:12 pm
Georgia USA
Georgia USA
Ah! This I believe is the answer. I did read in 2 different British publications to avoid "stove enameling" of the forks. Now I know why. Thanks
Re: Powder Coating a Brazed Frame [Re: Joel Greene] #620308
10/03/15 1:05 pm
10/03/15 1:05 pm
Dawsonville,Ga. USA
Marc Offline
Marc  Offline
Dawsonville,Ga. USA
I am a professional powder coater and can tell you the heat required for coating in no way will negatively effect the brazed frame. The temp of the part metal (PMT, part metal temp) needs to get to 400*f (not the oven temp) for 10 minutes to cure properly. The melting point of brass/bronze is 1600-1660*F, much higher than the powder curing temps.
