DC
DC
195 registered members (1xfatboy), 2,145 guests, and 542 spiders.
Jerry Dahlinger, RoyalSpares.com, GabrielSoren, JoshP, spikey45
10079 Registered Users
koan58 85
NickL 84
Lannis 81
504,784 mail-order LSR
Topics66,041
Posts639,260
Members10,079
T100 cylinder base nuts, 17/32" across flats? #615443
09/01/15 3:02 pm
09/01/15 3:02 pm
Dibnah Online content OP
Dibnah  Online Content OP
Engine oil leaking out of the base of the barrel on my T100-engined scrambler, having problems finding the right ring spanner (wrench!), 1/2" AF is too small, 9/16" AF is too big. 14mm is slightly too big, are these nuts 17/32" across flats?
There are double ring spanners available in 1/2" and 7/16" AF specifically for the cylinder base nuts on Triumph twin, assume these must be later than 1960?
17/32" across flats must be close to 1/4" Whitworth and 5/16" BSF
Re: T100 cylinder base nuts, 17/32" across flats? [Re: Dibnah] #615444
09/01/15 3:15 pm
09/01/15 3:15 pm
This is a good resource, scroll to the bottom
http://www.sat.dundee.ac.uk/psc/spanner_jaw.html
Diff mm mm inch Spanner
0.11 11.11 0.438 7/16 AF 1/4 UNF
0.19 11.30 0.445 3/16 W; 1/4 BSF
0.70 12.00 0.472 12mm
Re: T100 cylinder base nuts, 17/32" across flats? [Re: Dibnah] #615468
09/01/15 5:31 pm
09/01/15 5:31 pm
Stuart Offline
Stuart  Offline
As it's a '60 'C'-range Triumph, the nuts must be (British Standard) Cycle thread, all British Standard threads use the same spanner hexs. so it's the same as BSF - 0.52"AF in this case. Then, although the studs are 3/8"-dia., the nuts are small-hex, hence the 5/16" rather than the 3/8" spanner.
When BSA, including Triumph, went to Unified threads in the late 1960's, and barrel base studs became UNC/UNF, the 6-sided small-hex. nuts available off-the-shelf in Imperial threads weren't available in Unified, there wasn't enough barrel wall thickness to the liner or bore to machine away clearance for a standard 9/16"AF 6-sided nut and spanner so, certainly in the case of the 3/8"-dia. studs, the 1/2"AF (3/8"UNF) 12-point nut was used.
Re: T100 cylinder base nuts, 17/32" across flats? [Re: kommando] #618281
09/20/15 11:02 am
09/20/15 11:02 am
Thanks Kommando, a very useful link. I found reference to 17/32 across flats here http://wiki.diyfaq.org.uk/index.php?title=Size_conversion
Re: T100 cylinder base nuts, 17/32" across flats? [Re: Stuart] #618282
09/20/15 11:05 am
09/20/15 11:05 am
Thanks Stuart, a 1/4" whitworth ring spanner/wrench is a good fit. I had a couple of spanners with deep offsets, couldn't get them in. Have spent some mmmmoney on a couple of flat 1/4" whit spanners found on eBay. Torqued up by feel and the leakage has stopped. Several nuts were only just more than finger tight.
Page Time: 0.070s Queries: 15 (0.008s) Memory: 1.0191 MB (Peak: 1.1624 MB) Zlib disabled. Server Time: 2018-02-24 00:31:18 UTC
