CafeTbird
CafeTbird
Raleigh, NC
Bigmac, Dexter67, jimmiejag, LAGONAS, TJohn
10995 Registered Users
franko 106
DavidP 61
koan58 54
1,126,499 mail-order LSR
Topics68,718
Posts689,032
Members10,995
59 registered members (Al Eckstadt), 3,318 guests, and 856 spiders.
Center stand spring #618106 09/19/15 7:07 am
Ger B Offline OP
Is there a special tool to install the centre stand spring?
Or is it just brute force and a lot of luck?
I have it horizontal so the distance between the frame eye and the stand eye is as short as possible.
I should have never removed that stand in the first place mad
Re: Center stand spring [Re: Ger B] #618107 09/19/15 7:20 am
Bend the spring from side to side, held in a vice and insert washers between the coils, to lengthen it.
Pull the washers out, once the spring is in place on the stand.
Or- sit behind the rear wheel and pull the spring with a long wire, while an assistant pokes the spring end into position with tools. It is inadvisable for him to use his fingers.
Re: Center stand spring [Re: Ger B] #618108 09/19/15 7:21 am
Swan Offline
I use a Snap On brake spring tool. Springs slide on and off easily.
1966 Triton
1962 BSA DBD34 Gold Star
1966 Triumph Bonneville
Re: Center stand spring [Re: Ger B] #618109 09/19/15 8:02 am
Peter R Offline
Although the stand on the Norton and Triumph is a bit different from your bike, I use to remove both mounting bolts of the stand, and hook up the spring first.
Next pull the center stand, and install a pin trough one of the holes of the stand and mounting hole on the frame.
Then pull the center stand and install the bolt on the other mounting point.
Next remove the pin and install the last bolt. Job done.
Trying to stetch the spring by hand usually results in a lot of @#&*<##!
Re: Center stand spring [Re: Ger B] #618111 09/19/15 8:55 am
Ger B Offline OP
Not good for his ivory either I think laughing
Thanks you all chaps.
Swans tool is more for a workshop I think. I never saw it and
would not know where to get one.
Also: I do not think I will remove a pulling spring for the next ten years.
Did you buy it or make it?
Peter I tried to install the spring first and bolt the stand up
after that, but that resulted in a lot of @#&*<##! (Funny... do we speak the same language?)
The simple solution solved the problem.
The "why did I not think of that" trick with the washers.
With the washers the spring was 11 [mm] longer.
Thanks again. Case closed (for me that is) smile .
Re: Center stand spring [Re: Ger B] #618117 09/19/15 9:38 am
Ger,
I was going to suggest brake spring pliers;
https://jet.com/product/product/70cf110312e14ff7978665b2d7a5c4e8?jcmp=pla:ggl:vehicles_parts_a3:vehicles_parts_vehicle_parts_accessories_a3_other:na:na:na:na:na:2&code=PLA15&k_clickid=b16b1441-e188-488b-9af5-1e172fcd50de&kpid=70cf110312e14ff7978665b2d7a5c4e8&gclid=Cj0KEQjwj_SvBRC7k4DfkLHiuMABEiQAvPOaqZTxkssX3y7bAe164FUmJky_kfiOATumCEJ-pBEqdv0aAh6L8P8HAQ
[Mine happen to be flat black... Made by Proto tools...]
They were made sometime far back, and are mostly used for drum brake applications.
But, as now seen, have many other fine uses. Mostly as a spring installer for many other applications.
..... I don't know if they can be used as a spring dismounter though... Never tried that...
One end is cupped, with a... "shelf" made on the underside, so the tool will not slip easily off the end of the slip-over spring mount. Usually, the 'top' of the tool that the spring slides off of, is rounded to promote the springs' easy travel off the tool, once the effort to overcome the spring's shortness/tension is made.
DON'T try to get in the way of the spring's travel!
Re: Center stand spring [Re: Ger B] #618147 09/19/15 12:29 pm
Ger B Offline OP
Thank you Rickman.
Silly thing happened later this afternoon.
An hour or two after I installed the spring with the washer trick, I discussed
this with my neighbours son. He works on his 1984 Corvette two garages away from mine.
He said he once helped another neighbour who owns a 19 sixties Ford Mustang;
and he remembered the mustang guy had spring pliers for drum brakes... his own or borrowed? We don't know.
Since that neighbour lost his last battle less than three weeks ago - he does not have a head stone yet, we say here - we are not going to ask his wife yet.
Re: Center stand spring [Re: Ger B] #618189 09/19/15 4:48 pm
Stuart Online Content
Hi Ger,
Originally Posted by Ger B
Swans tool is more for a workshop I think. I never saw it and would not know where to get one.
Snap-On supply mechanics; certainly here in GB, Snap-On is a franchise so the local franchisee tours the local garages regularly; any garage or spares dealer with one or more mechanics will tell me when the 'Snap-On Man' is due; I meet him and buy direct from him.
But, for pulling springs, I've one of these. :bigt
My spring puller also pulls up the drain gratings in front of the garage doors ... smile
Re: Center stand spring [Re: Ger B] #618279 09/20/15 11:00 am
shel Offline
Snap On is a bit overpriced for the home mechanic, any auto parts store will have that tool at a reasonable price.
Re: Center stand spring [Re: Ger B] #618364 09/21/15 2:09 am
Pete C Offline
Hi Ger
I made one of These to solve this Problem. Not my idea , I stole it from the WM20 site http://www.wdbsa.nl/download/Spring%20puller.pdf
Took a bit of fiddling to get it to fit but it is very easy to use now.
I'll be passing Close to your place on 30th of the month heading for the overnight Ferry to Hull if you want to borrow it...of if I can bring you a few bottles of "Alt"
Pete
Pete
Re: Center stand spring [Re: Ger B] #618369 09/21/15 3:56 am
Ger B Offline OP
Hi Pete.
This inspires me to fabricate one, so I'll be settled for the next time... whenever.
I have an 8[mm] threaded rod in the shed plus sheet material.
The 30-th will be next week Wednesday.
What time will you be around here?
You know you are welcome, but beware the council has been working the roads again. The village is a labyrinth now. sick
Re: Center stand spring [Re: Ger B] #618516 09/22/15 1:52 am
Pete C Offline
Hi Ger
It all depends on when I manage to start off in Germany and the traffic. If I have time to spare I'l call you ( I have your number somewhere!) and maybe see if my new SatNav can defeat your council's evil plans grin
Pete
Pete
Re: Center stand spring [Re: Ger B] #618520 09/22/15 3:57 am
Ger B Offline OP
If you have my mobile number... it does not work any longer.
And I do not have a new handy yet.
Maybe after this weekend.
My children are now in a meeting and I was sent out of the room... grin
Re: Center stand spring [Re: Ger B] #618575 09/22/15 9:09 am
Pete C Offline
Got a birthday coming up? Or are the Kids plotting to make sure you are always contactable , ie. "on call" frown laughing
The number I have for you ends in 836, don't know if that is a Handy or landline.
Pete
Re: Center stand spring [Re: Ger B] #618586 09/22/15 10:24 am
Ger B Offline OP
Yes, I'm afraid so... frown
I hate birthdays.. Sit straight, give paw, wag tail...
mad
The number ending 836 is the land line. That's still valid.
I'll be seeing you.
Re: Center stand spring [Re: Ger B] #618632 09/22/15 2:46 pm
gunner Online Content
I have found the easiest way to install the centre stand spring is to use the method described in the original BSA A65 workshop manual.
The BSA method is to use a large cross head screw driver placed through the spring eye and engage one of the cross head slots in the stand hook and then lever the screwdriver down over the hook, see extract and diagram below:-
Re: Center stand spring [Re: Ger B] #618642 09/22/15 3:31 pm
No Name Man Online Content
That's the way I do er.
Bill E
69 A65T
71 B50T
85 K100RS
54/59 A10SR
69 B44VS
71 A65FS
95 Trident
Re: Center stand spring [Re: No Name Man] #618973 09/24/15 8:32 pm
I also have done this, but all too often, the 'cross-head' slips off...
Re: Center stand spring [Re: Ger B] #619015 09/25/15 7:42 am
Dave T Offline
I have always had success using a length of strong cord (para cord) and pulling the spring into place. Once in place the cord can just be pulled through.
Re: Center stand spring [Re: Dave T] #619018 09/25/15 8:05 am
Triless Offline
TT's washer method......... best of all. What I've always used, and never caused invention of new swear words!
Re: Center stand spring [Re: Ger B] #619033 09/25/15 9:30 am
Ger B Offline OP
It worked for me, but I was warned less than an hour ago: Do not use washers which are to high (thick).
This may spoil the spring / cause irreversable gaps so the spring becomes too long in it's unloaded state.
Re: Center stand spring [Re: Ger B] #619483 09/28/15 6:53 am
H
henryanthony Offline
H
Best method I have found is using a bench vise. Drill and tap 1/4" hole at the top of each jaw. Install long set/grub screws. Slip the spring on and easily pull it apart to appropriate length. Insert spacers - I used dimes (U.S. coins).
Re: Center stand spring [Re: Ger B] #619485 09/28/15 7:30 am
Ger B Offline OP
So you pull it and don't bend it.
Re: Center stand spring [Re: Ger B] #619493 09/28/15 11:03 am
I found an automotive spring puller to also be handy when fitting centre/side stand springs, see This Example
Re: Center stand spring [Re: Ger B] #619536 09/28/15 5:35 pm
htown Offline
I've tried the coin trick and found it time consuming and didn't work too well. The spring pullers kept getting caught under the spring eye. Here's how I do it now. Get a couple of heavy zip ties and make loops out of them. Hook the loops under the spring eye. Get under the bike and brace it with one foot. Pull the loops til you can hook the spring. Then cut the zip ties and pull them out. Five minute job.
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
1973 Norton Commando
1974 Norton Commando
2018 Kawasaki Z900RS
