jimmymckenna
jimmymckenna
Scotland, UK
207 registered members (68 royalstar tony), 1,856 guests, and 516 spiders.
Gus1956, Henry74, Benny, Lou Quirch, Mark Masa
10045 Registered Users
Lannis 152
kommando 111
Stuart 60
480,517 mail-order LSR
Topics65,765
Posts635,757
Members10,045
Parts, good and bad #603309
06/07/15 4:03 am
06/07/15 4:03 am
Christchurch NZ
R Moulding Online content OP
R Moulding  Online Content OP
Christchurch NZ
I mentioned this in an other thread and thought I would try starting something off. Kind of a Good, Bad and Ugly thread for spare parts.
So these are a few of my own experiences with my 66 650's, feel free to add more.
New production Lucas.
I have a stator and rotor fitted to my TR6 7 years ago. Only problem has been the wire insulation becoming brittle and cracking.
I have to rear lamps a 564 and a 679. Both exceed the quality of the cheaper alternatives and are very nicely made.
I have a 2 position ignition switch. Has a very nice positive feel (yet to be used on the road).
Exhausts and Silencers
Armours exhausts. Nice finish. Pipes exit head at wrong angle and brackets are flat tabs instead of L shaped. Had lots of grief with silencers breaking off. Could the bends be wrong?
Armours silencers. Only had the long type. Nice finish and good sound. Not to Harleyish. Inlet pipe to big to fit on Armours exhaust without using a Beer can shim. Inlets broke off and required repairs.
Brituro silencers. Again long type. Nice finish. Wrong shape, too pointed towards the outlet. Way to loud almost offensive Harley like sound. Perfect fit onto Armours exhaust but broke off within 100 miles.
LF Harris exhausts. Nice finish. Pipes exit head at correct angle and have an expanded section rather than a welded sleeve to fit over stub. Brackets are correct L shape. Yet to try them with silencers. Will update when able.
Twist Grips. Forget all the cheap alternatives. Get an AMAL unit. Very nice cast Alloy body polished to resemble chrome. Good smooth action and both the throttle stop and friction adjuster actually work.
Wiring harness. TMS (Autosparks) fitted perfectly. Not much else to say.
Mudguards. Front stainless guard in Wassel packaging. Made in Taiwan. Came pre drilled with welded metric stud for lower fitting. Too long at front edge. Overall finish good from 10 feet but still shows sanding marks close up. Fitted very well.
Rear guard. No makers name but made in Taiwan sticker. Came from Triumph Twin Spares. Un drilled.Similar finish to front. Nice rolled edges along sides but cut edges not finished and not symmetrical. Poorly produced flair at rear edge and forward edge to long meaning recess for shock bolts did not line up.
Slimline Tank. Made by Emgo in Taiwan. Nicely formed, required minimal bodywork. Front mounts are solid threaded bungs welded into tank as opposed to original tubes welded to outside. Too fat, tall and long when compared to original. Some adjusting of mounts required to avoid fouling steering stem while turning. Reasonable alternative when comparing prices of originals.
Cant think of anymore right now and my brain hurts.
Rod
Re: Parts, good and bad [Re: R Moulding] #603312
06/07/15 4:39 am
06/07/15 4:39 am
You should have good luck with the Harris pipes. According to the late Keith Moore, Harris produced these using the original Triumph tooling. Where they were made would be the question.....
Check the bends. There shouldn't be any mandrel impressions on the inside radius of any of the bends exactly as the original Triumph pipes. They were drawn with an insert just a tad smaller than the inside diameter of the pipe so the bends would be uniform.
Very nice.
Re: Parts, good and bad [Re: R Moulding] #603326
06/07/15 6:08 am
06/07/15 6:08 am
dave jones Offline
dave jones  Offline
I sent off for a clutch thrust washer that turned out to be solid bronze instead of steel backed. I used it but it broke up and the whole primary was filled with metal! It broke initially where the locating tabs are. The steel backed ones are best and the plain one works anyway. You don't need the tabs.
My silencers have broken a few times but having the cross brace between them helps a lot. Also, making sure everything fits with no strain before bolting up is good. I spoke to a chap who had a 650 in the 60s and he said the original silencers on his did the same thing.
Re: Parts, good and bad [Re: R Moulding] #603373
06/07/15 11:09 am
06/07/15 11:09 am
Santa Barbara, California
KC in S.B. Online content
KC in S.B.  Online Content
RE: the EMGO tank. Same issues on my TR6, and you did not mention the problem of the center trim strip needs to also be EMGO for the tank. My Buddy pointed out that the steering head clearance issue is likely only TR6, as the rubber mounted P-clamp style clamps look to be forward of the tank. On a TR6, dry fit and modify the forward mounts BEFORE paint!
Down to 1 BSA, 2 Triumphs, 2 '56 Chevys
Re: Parts, good and bad [Re: R Moulding] #603398
06/07/15 12:56 pm
06/07/15 12:56 pm
Irish Swede Offline
Irish Swede  Offline
Always my complaint. WHY, oh WHY, can't these suppliers and makers of so-called "re-production parts"
take the time and effort to get them CORRECT the first time around?
It can't take any more time to "do it right" that it takes to do it WRONG.
Are they just to cheap or lazy to find an original part to copy, or what?
Re: Parts, good and bad [Re: R Moulding] #603402
06/07/15 1:06 pm
06/07/15 1:06 pm
Maybe they copy the scrap and forget what hapened, what wore away, in the period before the parts became scrap?
On a shipyard I worked at in the 19 nineties a Portuguese speaking steel worker and a welder were told to cut a
square section out of the hull of a ship because the ship had collided and had a huge dent.
They cut out the steel plate with the stiffeners on the inside and took the part to the steel workshop.
When I went to see them there, they were ready to start bending new profiles and a steel sheet to copy the dent. eek
A language problem...
Re: Parts, good and bad [Re: R Moulding] #603423
06/07/15 2:37 pm
06/07/15 2:37 pm
Christchurch NZ
Christchurch NZ
KC, I was bound to forget something! Issue is still apparent on my T120R, forward part of the ridge rubs on the bottom of the top clamp.
Swede. Not that I see this as a defence. One supplier of Emgo tanks states that they had to use thicker steel to meet modern requirements. Consequently they could not make it the right shape.
Rod
Re: Parts, good and bad [Re: Ger B] #603480
06/07/15 8:13 pm
06/07/15 8:13 pm
Queensland, Australia
Tiger100 Online content
Tiger100  Online Content
A language problem... [/quote]
Ger that is rather funny, incredibly frustrating no doubt but funny nonetheless
Grant
Re: Parts, good and bad [Re: R Moulding] #603513
06/08/15 1:43 am
06/08/15 1:43 am
In hindsight yes, but at that moment we did not think it was funny.
It would have cost the yard the equivalent of 8,000 USD if they had produced that patch and installed it.
What was learned though was: Give them instructions that cannot be understood wrong.
If you want a machine shop in Pakistan to produce a correct batch of camshafts for no matter what engine,
give them a drawing with the correct material spec, correct sizes, tolerances, smoothness characters and hardening instructions.
Do not give them a worn chipped camshaft.
Re: Parts, good and bad [Re: R Moulding] #603594
06/08/15 2:00 pm
06/08/15 2:00 pm
dave jones Offline
dave jones  Offline
Factories in India, Taiwan and Pakistan are fully capable of making parts of the absolute highest quality. The trouble is no one wants to pay the price for the highest quality parts. The English parts would be better if people are prepared to pay the price, too.
Re: Parts, good and bad [Re: HawaiianTiger] #603603
06/08/15 2:46 pm
06/08/15 2:46 pm
Peter R Online content
Peter R  Online Content
There must be an awfull lot of "original" factory tooling and equipment around, considering the fact that so many makers/suppliers claim to use original factory tooling for their products. confused
Re: Parts, good and bad [Re: Peter R] #603610
06/08/15 3:34 pm
06/08/15 3:34 pm
Bishop, Calif.
desco Online content
desco  Online Content
Bishop, Calif.
And that "original tooling" is 40 or 50 years old. It's worn out.
Re: Parts, good and bad [Re: R Moulding] #603620
06/08/15 4:31 pm
06/08/15 4:31 pm
You do not need original tooling to produce a simple product.
You need to know original dimensions.
Re: Parts, good and bad [Re: R Moulding] #603684
06/09/15 3:14 am
06/09/15 3:14 am
With regards to the Triumph pipes, the type of tool used is more important. Anyone with a pipe bender from a muffler shop can bend up some pipes for a Triumph, but they'll look like most of the crap that has been offered to the public as replacement pips for our bikes. You only need to see the original Triumph pipes next to the 100$ pipes we've seen for the last 30 years to realize how superior the Harris pipes are in comparison. It doesn't matter if it's the original tooling, no, but the type of pipe bender that draws a pipe with perfect flow from tip to tip. No dips, no creases, no mandrel marks at all.
So, the pipes are drawn, not bent, and that makes all the difference.
Re: Parts, good and bad [Re: R Moulding] #603703
06/09/15 8:35 am
06/09/15 8:35 am
UK Berks
AngloBike Online content
AngloBike  Online Content
UK Berks
harris made loads of parts for Triumphs back when the factory was running, and made bikes on their own.
Triumph didn't make everything in house, and some companies are still running.
some of the other manufacturers on eBay have never seen a bike.
There was a programme on TV the "Million £ Jag" where the Jaguar Co. remade a series of E type specials.
They found the original press and dies to make a load of new panels.
so there are companies in tyne UK making pressed steel tanks on the original kit (apparently)
or a guy in India beating the cr*p out of a sheet of metal over a log.
Re: Parts, good and bad [Re: R Moulding] #603720
06/09/15 10:55 am
06/09/15 10:55 am
TripleTown Offline
TripleTown  Offline
Rod
Few points.
New Production Lucas parts for motorcycles have only been instigated recently. If purchased 7 years ago, the rotor and stator would have to be either Original stock, or aftermarket with 'Lucas' stamped on them ,to stump up the price.
Same with the Rear lamps. Better than the cheaper aftermarket lamps I agree, but certainly not Genuine, as they haven't been made for years, and the ones I've seen bearing the Lucas mark, are nothing like the original lamps. Lucas haven't made any motorcycle rear lamps since the factory closed...
The 2 position ignition switch is an Automotive product. I have used them and they work fine.
I think you may be confusing 'New Production Lucas' with counterfeit aftermarket items stamped 'Lucas'.
Since 2003, all Genuine Lucas parts supplied into any market, automotive, lighting, motorcycle ,commercial etc, have been supplied in the Green packaging.
Exhausts and silencers... I share your pain. Without doubt the consistent bane of my life! I tend to use Armours, as when it's good, it's great...but etc etc
Wiring Harness. I agree on the Autosparks looms. Never had a problem with them.
Re: Parts, good and bad [Re: Ger B] #603794
06/09/15 5:59 pm
06/09/15 5:59 pm
You need to find machinists who can read 50-year old blueprints and measuring conventions.
Third-angle projection or first-angle? Bend up or down, at what angle, and what are the flat dimensions when the only drawing you have is of the formed piece?
Welcome to QC at a metal fabrication plant.
Re: Parts, good and bad [Re: DavidP] #604188
06/12/15 7:07 am
06/12/15 7:07 am
Brisbane, Australia
BrizzoBrit Online content
BrizzoBrit  Online Content
Brisbane, Australia
For the LF Harris pipes, I was talking to the local Brit shop owner the other day. He said they have the original drawings. Dunno about tooling. He also said the LF Harris pipes were the best of those available and will fit correctly.
I DO NOT use any AMAL parts that dont come in the AMAL branded bag anymore. Too many shonky suppliers out there. There hard anodised slids are brilliant. Even better then the hard chromed brass ones I've used in the past.
Found the new Lucas parts to be good. Had cause to buy some headlights recently. Had a NOS Lucas shell and rim fitted for a crash repair at the local brit shop. Wanted to save that for my 'as original as possible' T120. Bought an EMGO replacement and it was much better chrome and finish overall. That surprised me. So, I'm gonna recommend the EMGO headlight shells.
Thats a start.
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
& too many projects!
Re: Parts, good and bad [Re: BrizzoBrit] #604806
06/15/15 9:26 pm
06/15/15 9:26 pm
Originally Posted By BrizzoBrit
I DO NOT use any Amal parts that dont come in the Amal branded bag anymore. Too many shonky suppliers out there.
Same with Mikuni parts, too much crap out there. Must buy original.
My new one looks good, so do the pipes I just bought. Their silencers are just OK, though. I use their 20" megas. I've had one where the baffles came loose, and they are not replaceable. The mounting slots also wallow out and loosen.
Also, like too many these days, their fork gators last about a month.
The only "original equipment" which ever disappointed me was a front rim. Once I ordered a new rim, but it was after Triumph had switched to Radelli rims. The chrome on the Italian rim started pitting after only a year. The 10-year old Jones rim looked better, but it had gotten bent.
Re: Parts, good and bad [Re: DavidP] #604817
06/15/15 10:03 pm
06/15/15 10:03 pm
Jaffrey, NH, USA
Peter Quick Offline
Peter Quick  Offline
Jaffrey, NH, USA
Originally Posted By DavidP
[quote=BrizzoBrit]
With Radaelli rims you get what you pay for. You save 1/4 to 1/3 in cost compared to more expensive chrome rims and get rims that rust through much faster. They sell because of their pricing point and then folks complain after voting with their wallet.
Peter
Re: Parts, good and bad [Re: R Moulding] #604837
06/16/15 12:17 am
06/16/15 12:17 am
South cone
reverb Offline
reverb  Offline
South cone
...sometime ago I bought a lever for the choke made by EMGO that is top quality. Best chrome that I ve seen in these type of bits.
The lady from UK that sells these products said that have quality but not until I saw it that I appreciate the quality.
I have the chromed piece that goes in the middle of the slim tanks and is perfect; Im not sure if its Emgo.
I have the rear 43 sprocket/drum by Emgo, that looks very good; however, is cheaper than the UK made due to not resist too much kms¿?
Brake and clutch levers from Emgo that are pretty good.
I had some AMAL spares that do not look AMAL purchased by one of the big sellers in Canada/US.
SS Spokes from Buchanans that are very high quality.
Cylinder barrels for T140E that I think are LF Harris new production that are good but seems not totally accurate.
Re: Parts, good and bad [Re: R Moulding] #604846
06/16/15 3:18 am
06/16/15 3:18 am
Christchurch NZ
Christchurch NZ
New twin pull twistgrip arrived today from AMAL. I already have the single pull type on my TR6 and to have this one for the Bonnie.
Since a picture (or two) paints a thousand words.
lovely jubbly
Rod
Re: Parts, good and bad [Re: R Moulding] #617218
09/12/15 11:58 pm
09/12/15 11:58 pm
Christchurch NZ
Christchurch NZ
Just fitted a new Lucas branded headlamp shell. Fitted the lens to rim and secured it using the correct screw and tag. Chrome plate immediate cracked and lifted around the screw. Really pissed off and disappointed.
Rod
Re: Parts, good and bad [Re: R Moulding] #617238
09/13/15 4:25 am
09/13/15 4:25 am
Stuart Online content
Stuart  Online Content
Hi Rod,
When Wassell announced they'd secured a licence to brand their Lucas pattern parts (and rushed out several websites with "Lucas" in the address ...), I posted wondering whether Wassell quality would rise to previous Lucas standards or "Lucas" quality would fall to previous Wassell standards ...
While it's too late this time, fwiw even with original Lucas shells, simply to avoid any scratches in the chrome from the screw head, I put a 3/16" white nylon washer under the screw head. Original screws were pan head so the washer is virtually invisible.
Re: Parts, good and bad [Re: R Moulding] #617245
09/13/15 4:58 am
09/13/15 4:58 am
Christchurch NZ
Christchurch NZ
Hi Stuart.
I've had some reasonable Lucas stuff lately so decided to take a punt on the shell. Seems at least in this case the Wassel reputation for crap remains intact. I like the idea of the nylon washer and will look into it. I dont think it would have helped in this instance though as the chrome has lifted as opposed to being scratched. Now I've drilled it for idiot lamps it's probably worth me spending the money to have it chromed properly.
S$it happens
Rod
