RGSDave
RGSDave
Kansas City
193 registered members (1xfatboy), 1,900 guests, and 546 spiders.
10070 Registered Users
koan58 85
Lannis 82
NickL 75
Stuart 67
501,233 mail-order LSR
Topics65,994
Posts638,644
Members10,070
1972 TR6, Valvoline VR1 20W50 engine oil? #613181
08/16/15 2:28 pm
08/16/15 2:28 pm
Dibnah Offline OP
Dibnah  Offline OP
Hi All
Just bought a 1972 TR6 650, any reason why I can't use Valvoline VR1 20w50 racing oil as engine oil? The oil should be shared between the crankcase and the primary chaincase, I know there is oil in the primary chaincase because it's leaking! Also some clutch slip, just like the last one I bought...
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: Dibnah] #613200
08/16/15 4:18 pm
08/16/15 4:18 pm
Irish Swede Online content
Irish Swede  Online Content
ANY oil with "friction modifiers" in it will cause clutch-slip in Triumphs made from 1970-on, where oil is shared between the engine and primary chain case.
The chain case is being used as a big plenum chamber to vent the engine. This was not a problem when these bikes were first produced, but with the popularity of overhead cam auto engines and a desire for better fuel mileage, these additives were introduced, thus causing OUR problems with using this oil.
There are several alternative oils that do not have these friction modifiers. Honda and Yamaha dealers stock their own brands, and there are others.
By the way: Why are you using 20W50 instead of straight-weight 40, as Triumph recommended?
These are air-cooled engines, and the heat from the crankcase is carried away by the oil, and is
disbursed by the walls of the oil tank or, in your case, by the oil reservoir of the frame.
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: Dibnah] #613206
08/16/15 4:43 pm
08/16/15 4:43 pm
Magnolia, TX
htown Online content
htown  Online Content
Magnolia, TX
Use 20w/50 Valvoline 4 stroke motorcycle oil. It doesn't have the friction modifiers that affect the clutch and is designed for air cooled engines. Triumph may have recommended the single weights at one time and expected you to change them winter and summer but when the multi-weights became available they switched the recommendation to those. As long as you change on a regular basis the 20w/50 motorcycle specific oils work fine. Better circulation on cold start up and protection at high temps.
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
2-1974 Norton Commandos
2004 XL 1200R Sportster
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: Irish Swede] #613211
08/16/15 5:04 pm
08/16/15 5:04 pm
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
The "Triumph recommended" engine oil by that time was 20w/50.
Edit: Currently using Morris 20w/50 'V-twin' in my T140V and Commando: http://www.morrislubricantsonline.co.uk/v-twin-20w-50-top-quality-multigrade-motorcyle-oil.html
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: Dibnah] #613245
08/16/15 9:21 pm
08/16/15 9:21 pm
kevin roberts Online content
fefsa
kevin roberts  Online Content
fefsa
i've got modern 20W50 in my street T120, and the clutch has started to slip around 5600 in fifth. never had a problem before.
i'm taking the primary apart soon to swap out gearbox sprockets, so i'll clean the clutch out then and start using more appropriate oil.
live every day.
die once.
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: htown] #613246
08/16/15 9:24 pm
08/16/15 9:24 pm
JubeePrince Online content
JubeePrince  Online Content
What he said. I've been using it for a few years now, with very good results: no slip and about 1/2 kick to free the clutch if it sits for over a week...
If the PO didn't already do it, get yourself an external oil filter...
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: JubeePrince] #613265
08/16/15 11:40 pm
08/16/15 11:40 pm
USA, WA state
russrudolph Online content
russrudolph  Online Content
USA, WA state
I just changed oil in my 1969 tr6c. Used VR1 20/50 racing oil. Since I have been using castrol 20/50 for last 28 years, do I have to worry? I do have external oil filter on return side.
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: Irish Swede] #613277
08/17/15 2:15 am
08/17/15 2:15 am
Stuart Online content
Stuart  Online Content
Errrm ... thread title says "1972 TR6", 1972 650 Owner's Manual, page 39 ... wink
Also, the o.p.'s "Loc:" is "UK"; although it's a beautiful sunny morning, even if he's in the south, the temperature was in single figures early on; if he fancied an early-morning ride, "straight-weight 40" wouldn't do the bike's big-ends and top end any favours whatsoever.
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: Dibnah] #613278
08/17/15 2:21 am
08/17/15 2:21 am
Magnolia, TX
Magnolia, TX
Russ,
The only worry might be the clutch slipping. I wouldn't think it would do any harm to anything else.
Htown
1974 Trident
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: Dibnah] #613282
08/17/15 3:22 am
08/17/15 3:22 am
Russ,
Does your bike have shared oil in the engine and primary? If so, thee might be an issue with clutch slipping. It's difficult to determine which bike will have clutch slip and which won't. I have a friend with a '71 using VR-1 with no clutch slipping reported.
I use it in all my bikes, but the issue is oil availability vs price for me. I can get motorcycle oils at the Harley shop for big bucks, or VR-1 at the auto parts store for a bit less, so that's what I use.
If you try it and the clutch slips, then maybe it's time for a clutch strip and clean. We have to do it every once in a while anyway...
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: HawaiianTiger] #613285
08/17/15 4:52 am
08/17/15 4:52 am
Ohio,USA
Alan Lonneville Offline
Ohio,USA
Here is a link for oil recommendation from British Cycle Supply
http://www.britcycle.com/Manuals/bcs_oil_recommendations.htm
I use the VR1 in all of my Triumph's and use the Brad Penn "Break-in" oil as well on new builds.
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: Dibnah] #613294
08/17/15 8:03 am
08/17/15 8:03 am
Deltona, FL
lrutt Offline
lrutt  Offline
Deltona, FL
I run the Quicksilver syn 20w50 mc oil that is sold by WalMart. It's made just for motorcycles and has the appropriate Zn etc. in it plus lacks the bad juju for clutches. Has worked fine on all my bike, including brits, for years now. A little more than the Valvoline MC oils but it is synthetic and I like to give the old bikes every little bit of help I can.
1970 Tiger
1971 Trophy
1973 Commando
1976 CB750k
1965 CA77
1978 CB750k
1970 T250II
1971 RT1B
1977 Lemans
2001 M900
2001 XR650L
1994 FLSTC
2006 XL1200C
1984 XV1000
1981 C70
1973 Z50
1989 Hawk GT
2006 Scrambler
1970 CT90
1965 CT200
1977 R75/7
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: lrutt] #613298
08/17/15 8:19 am
08/17/15 8:19 am
Running from demons in WNY
Hillbilly bike Online content
If you look at Valvoline's website and product specs...Their 20-50 motorcycle oil has what many consider to be less ZDDP than desirable for older engines, less than 1100 PPM. The ZR1 is with range with 1400 PPM...
But if it works for you then it's just fine...
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: Dibnah] #613316
08/17/15 12:40 pm
08/17/15 12:40 pm
Deltona, FL
lrutt Offline
lrutt  Offline
Deltona, FL
1970 Tiger
1971 Trophy
1973 Commando
1976 CB750k
1965 CA77
1978 CB750k
1970 T250II
1971 RT1B
1977 Lemans
2001 M900
2001 XR650L
1994 FLSTC
2006 XL1200C
1984 XV1000
1981 C70
1973 Z50
1989 Hawk GT
2006 Scrambler
1970 CT90
1965 CT200
1977 R75/7
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: Dibnah] #613336
08/17/15 2:43 pm
08/17/15 2:43 pm
No worries if your oil doesn't rate with ZDDP. It's available as an oil additive.
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: HawaiianTiger] #613341
08/17/15 3:40 pm
08/17/15 3:40 pm
Oil engineers caution that mixing in additives can impact the base oil additive package in a negative way.
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: Dibnah] #613347
08/17/15 5:06 pm
08/17/15 5:06 pm
John Healy Offline
John Healy  Offline
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: John Healy] #613354
08/17/15 5:53 pm
08/17/15 5:53 pm
Originally Posted By John Healy
That test is at least nine years old. Automotive oils have changed in nine years and probably bike oil?
It appears the tests were done in a lab and not after many miles of actual road or race riding? Oil testing using methods like pressing steel balls into spinning wheels has come under a lot of criticism lately because they don't reflect the dynamics of what goes on in a running engine.
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: Dibnah] #613360
08/17/15 6:17 pm
08/17/15 6:17 pm
Magnolia, TX
Magnolia, TX
Gee, Amsoil paid for the study and came out #1.
1974 Trident
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: htown] #613368
08/17/15 7:12 pm
08/17/15 7:12 pm
USA, WA state
USA, WA state
Thanks every one. I have a non shared oil model, primary clutch and engine. I should be fine with VR1 20/50. Since my cars are older and I have to use redline ZDDP additive. I will use some redline ZDDP additive to my VR1 oil just to be safe and get above 1400ppm.
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: Dibnah] #613373
08/17/15 7:37 pm
08/17/15 7:37 pm
John Healy Offline
John Healy  Offline
Actually motorcycles have gone backwards over the past ten years. The SG standard was last used in 1993. The SG oil is what we used in the day. 2015 motorcycle oils are now SG.
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: John Healy] #613398
08/18/15 1:11 am
08/18/15 1:11 am
Dibnah Offline OP
Dibnah  Offline OP
Thanks for all the detailed replies. I can only find one seller of Valvoline 20w50 motorcycle oil in the UK (on Amazon) at GBP12.50 a litre. Lucas 20W50 motorcycle oil is a possibility, or buy some Motul 3000 and use a ZDDP additive.
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: Dibnah] #613400
08/18/15 2:46 am
08/18/15 2:46 am
There are any number of suitable 20/50 motorcycle oils in GB - syn., semi- and straight dead dino juice - look for one marked "4T" and/or "V-twin".
You do not need to faff around with "ZDDP additive", any one that meets API SG spec. or earlier will have sufficient ZDDP.
There's much twaddle posted on Britbike forums about ZDDP; I would strongly advise that you 'phone Fuchs Lubricants (think Silkolene) at Belper, Derbyshire, who r&d and blend in GB. Ime, you'll speak to someone who actually knows what they're talking about (as opposed to a 'Customer Service Representative' reading answers off a computer screen, or someone reposting an amalgam of half-remembered information read weeks and months ago on the aforementioned forums ... frown ).
As your bike uses the same oil in engine and primary transmission, any oil you select should also meet JASO MA2 spec. - essentially, means it's missing the additives that can cause clutch slip.
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: Dibnah] #613424
08/18/15 9:42 am
08/18/15 9:42 am
When the Speed Twin cam out in 1938 ZDDP was an experimental additive being tested as a corrosion inhibitor. When the 650 came out in 1950 ZDDP was not found in many motor oils in the USA. The late 50'sand 60's HP increases in OHV V-8's using hotter cams with more spring pressure was one of the reasons for increased ZDDP..
I would think the Triumph radius tappet and about 180 pound open spring pressure is a lot less stressful than the punk kid down the street with a built Chevy engine having 300 plus pounds open pressure on a .840 diameter partial contact tappet.
Re: 1972 TR6, Valvoline VR1 20W50 engine oil? [Re: Dibnah] #613474
08/18/15 4:28 pm
08/18/15 4:28 pm
Triumph has a well known problem with rapid cam wear on the earlier machines. As a matter of practice, I always fit nitrided cams to any engine I build in order to slow down this problem.
Inlet cams have a much easier life. Nitrided inlet cams with breather drillings are rather rare on the used cam market. So in order to help the situation, I add oil with ZDDP or additives when I can.
Despite the light loadings of these components, rapid cam wear is a real issue. Anyone with a 69 or later bike need not worry too much about it.
I imagine that there are clutches that are designed to run in the modern oils. It seems to me an opportunity for some enterprising individual or concern to manufacture clutch plates that work with the modern oils.
So, with nitrided cams and new clutch pack, a Triumph owner could select whatever oil it pleased him, including that Royal Purple or Lucas oil that seem not to live up to their claims on the above oil testing.
Or you could even use Slick 50 which claims were proven over stated, to be kind. The only thing slick about it was the advertising.
Page Time: 0.556s Queries: 17 (0.011s) Memory: 1.2103 MB (Peak: 1.5684 MB) Zlib disabled. Server Time: 2018-02-18 04:58:10 UTC
