38 registered members (Al Eckstadt), 259 guests, and 75 spiders.
10381 Registered Users
Mori55 98
NickL 86
Stuart 83
DavidP 79
reverb 73
Triless 68
688,100 mail-order LSR
Topics68,001
Posts661,478
Members10,381
Extra fuses neg or pos side ? #612471
08/11/15 6:06 pm
08/11/15 6:06 pm
MOTHERWELL NORTH LANARKSHIRE S...
F
FLYNN54 Offline OP
FLYNN54  Offline OP
F
As my post suggests. Your thoughts and experiences are welcomed regarding:
I would like to add additional fuses to my wiring harness on my OIF 1971 BSA A65L.The bike has a new harness ( from Burton Bikes in the UK )with the stock single cylinder style 35 amp (suicide) fuse. My options appear to be 1) fit a 3 in, 3 out fuse box between the coils - a fuse for charging, lighting and ignition circuits ( in addition changing the cylinder fuse to a splash proof type). Or 2) splice into the harness three splash proof fuses holders that clip together (again adding a fourth to replace the "old "35 amp fuse). The general idea is to provide protection for different circuits in the event of an “electrical mishap". The main question is which side of the circuit is best for the extra fuses - the Positive earth side (RED) or Negative side (various colour codes). Or does it not really matter ? Podtronic unit (on bracket under the battery carrier) and Boyer Unit (which will need to be repositioned somewhere) are already fitted. Trying to keep the wiring from resembling a large plate of spaghetti is a consideration also. As always thank you for your thoughts in advance and sorry to any pasta lovers !! John "Born to be Mild" Flynn.
Re: Extra fuses neg or pos side ? [Re: FLYNN54] #612480
08/11/15 8:24 pm
08/11/15 8:24 pm
Hi John,
I have a fuse box on my '71 A65, but my wiring harness is far from stock and connected negative common (AKA "Earth".)
In any case, it would be most difficult to isolate each circuit's common lead, therefore much easier to fuse the negative side, in your case. I believe that Hella make a compact, 4-circuit fuse holder with a cover.
Mine uses a single input, with fuses for lights, brake lights, horns, and charging. I have a separate fuse on the Pazon.
72 T150V yet to be named
Re: Extra fuses neg or pos side ? [Re: FLYNN54] #612481
08/11/15 8:26 pm
08/11/15 8:26 pm
kevin roberts Online content
fefsa
kevin roberts  Online Content
fefsa
a single fuse will protect your wiring equally well on either the hot or the earth side of your battery.
but if you're doing multiple fuses, put them on the feed (hot) side of the circuits you want to protect. if you fuse the earth part, then the wiring or the component can short to ground anywhere before the fuse and melt whatever is there. if you fuse the hot side, closer to the battery, then more of the circuit is protected.
your original configuration is negative feed (hot), positive return (earth). fuse the negative wires.
if you're using a 3-in, 3-out fuse holder, put it in a convenient place and then cut the circuits you want to protect, splicing in two leads to the bare ends, one to the fuse, and other from it. this will disturb your harness the least, and you won't have to fish around under the tank or inside the headlamp shell for an inline fuse.
fuse the feed to the Boyer for sure. my podtronics on my 72 T120 is unfused, and just connects directly to the battery hot side.
Re: Extra fuses neg or pos side ? [Re: FLYNN54] #612495
08/11/15 10:03 pm
08/11/15 10:03 pm
Stuart Online content
Stuart  Online Content
Hi John,
'Fraid not.
On standard pre-'79 Britbike electrics, the single fuse is usually (always?) in the Brown/Blue attached to battery -ve. If you're unlucky enough to experience something (loose tool, broken seat pan, etc.) touching both the -ve battery terminal and the structure of the bike, that fuse won't protect the battery. sick
Otoh, single fuse in the Red wire attached to battery positive will protect from both the above situation and short-circuits elsewhere in the wiring. bigt
new harness
Podtronic
You aren't likely to be able to do it without at least some hacking into the new harness. frown
"charging": if the Podtronic is connected direct to the battery terminals, not into the harness, a fuse in either wire will isolate it; otoh, if it's connected into the harness at the original rectifier connections, the existing fuse is already between the battery and the rectifier connection in the Brown/Blue.
You could fuse "lighting" by disconnecting the existing Brown/Green from the ignition switch, connecting a new Brown/Green wire from the ignition switch to the fuse box and another from the fuse box back to the aforementioned disconnected Brown/Green.
The "ignition circuit" isn't separate from the other White wires supplied from ignition switch terminal #2 until it emerges from a standard harness just before connecting to the wiring to the handlebar switch cluster that contains the kill button.
Edit: however, like several other posters, I include a fuse to protect an e.i. When I was doing my first rewire, John Carpenter of Mistral Engineering in GB - who marketed and did the Rita technical backup for Lucas - advised a 10A fuse between the handlebar kill switch and the Rita 'black box'. Curiously, when I asked the same question of Ernie Bransden during rewiring a bike with B-B e.i., he advised against a fuse - "Something else to go wrong", he said. grin
To fuse a particular circuit, you must use the "Negative [supply] side"; a fuse in the Red return cable could not protect the supply cable or from a fault that connected to the cycle parts through the component's mounting.
Otoh, as I've explained above, a replacement for the standard single fuse would be best in the Red cable attached to battery positive.
You would've been wiser to have considered additional fuses before buying an off-the-shelf harness. While nothing's impossible, 'fraid adapting said off-the-shelf harness to a fuse box will more than likely result in it "resembling a large plate of spaghetti". frown
Re: Extra fuses neg or pos side ? [Re: FLYNN54] #612499
08/11/15 10:30 pm
08/11/15 10:30 pm
Mark Z Offline
Mark Z  Offline
I agree with Stuart on fusing the "ground" leg of the battery.
The only reason to install multiple fuses is in order to allow some circuits (for instance, the ignition circuit) to function when there's a short in some other circuit (for instance, lighting). This of course precludes having the battery directly fused, as a short anywhere will shut down everything.
I've never felt the need for having more than one fuse, mainly because, if there's a short anywhere in my bike, I won't ride it until it's found and fixed.
And it doesn't have to be a 35-amp (suicide? ok...) fuse; a 15-amp fuse is all you need. The fuse only has to be "big" enough to carry the maximum amount of current that will flow in normal operation. Headlamp, 5A, ignition, 3A, everything else, an amp or so. Adds up to about 10.
Re: Extra fuses neg or pos side ? [Re: Stuart] #612503
08/11/15 10:42 pm
08/11/15 10:42 pm
fefsa
fefsa
Re: Extra fuses neg or pos side ? [Re: Mark Z] #612505
08/11/15 10:54 pm
08/11/15 10:54 pm
fefsa
fefsa
mark, you won't have any choice. with only one fuse, you can't ride it until it's found and fixed.
the advantage of separate fuses is that a bad horn or turn signal circuit won't keep the ignition from running, so you can ride the bike home and fix it there.
Re: Extra fuses neg or pos side ? [Re: Mark Z] #612506
08/11/15 10:55 pm
08/11/15 10:55 pm
Hi Mark,
John The O.P. is in GB, where the single cylindrical glass-'n'-metal fuse will be labelled with its ("35-amp") 'blow' rating. The equivalent US rating would be "15-amp" 'continuous'. smile
Re: Extra fuses neg or pos side ? [Re: kevin roberts] #612509
08/11/15 11:09 pm
08/11/15 11:09 pm
Hi Kevin,
If you re-read his original post, John The O.P. hasn't asked about separately-fusing "horn or turn signal circuit[s]" ...
Just as a matter of possible interest, since I rewired my first bike over the winter of 1982/83, I've never had a "bad" circuit, so extra fuses and yards of extra wiring would not have been of any benefit whatsoever. Plan and execute the job right in the first place, KISS and you'll be able to hand it over to your grand-children ...
Re: Extra fuses neg or pos side ? [Re: Stuart] #612510
08/11/15 11:09 pm
08/11/15 11:09 pm
fefsa
fefsa
^^^i didn't know that.
...about the differences in british fuse ratings. i've always run a 30-amp US fuse, and wondered why i needed something that huge
Re: Extra fuses neg or pos side ? [Re: kevin roberts] #612512
08/11/15 11:20 pm
08/11/15 11:20 pm
Hi Kevin,
i didn't know
eek That's equivalent to 60A 'blow'. Just as well the bike never had a 'short' ...
Re: Extra fuses neg or pos side ? [Re: FLYNN54] #612513
08/11/15 11:21 pm
08/11/15 11:21 pm
fefsa
fefsa
you're right. he asked about installing separate fuses for "charging, lighting and ignition circuits." yet the same observation obtains, stuart. with a single fuse for the entire electrical system, you can be stranded by a loose wire in your tailight. i always separate my ignition feed from any other circuit in the harness.
with your circuits fused separately, a failure in one doesn't make for a failure in all.
Re: Extra fuses neg or pos side ? [Re: Stuart] #612515
08/11/15 11:23 pm
08/11/15 11:23 pm
fefsa
fefsa
Hi Kevin,
i didn't know
woo are you right.
i tossed my original harness in my first machine as soon as i could. never had a problem since. i did run a single fuse for many years on it, but i never liked the "all my eggs in one basket approach." i'm running 10 and 15-amp ATC fuses in it now.
Re: Extra fuses neg or pos side ? [Re: FLYNN54] #612521
08/11/15 11:43 pm
08/11/15 11:43 pm
Anchorage Alaska USA
Mitch Offline
Mitch  Offline
you want fuses in the "hot" side of the battery unless the frame is not grounded (earthed). any wire that might get rubbed through and touch the frame would be shorted in a normal system, so fuses are as close to the battery as possible to minimize unprotected wire. the fuse protects the wires... once a user unit goes bad & fries, it's already gone, the thing now it to prevent the wires from catching on fire. there should be NO unfused wires that source power from the battery. there are certain types of tach generators and EGT probes etc that generate only low voltages that are not powerful enough to cause damage, those can be left unfused. we have them on aircraft but they are not often seen on motorcycles
Re: Extra fuses neg or pos side ? [Re: Mitch] #612538
08/12/15 5:35 am
08/12/15 5:35 am
Hi Mitch,
Uh-uh. As posted already:-
On standard pre-'79 Britbike electrics, the single fuse is usually in the Brown/Blue attached to battery -ve. If you're unlucky enough to experience something (loose tool, broken seat pan, etc.) touching both the -ve battery terminal and the structure of the bike, that fuse won't protect the battery. sick
... because the frame is connected to battery +ve, a fuse between the frame and battery +ve will blow. bigt
Re: Extra fuses neg or pos side ? [Re: kevin roberts] #612642
08/12/15 5:44 pm
08/12/15 5:44 pm
Makes it easier to figure out which circuit is at fault, too.
+2 on fusing the ignition, especially electronic ignition. I had a dual-lead coil go low resistance once on a ride. The 5A fuse in that circuit saved me from a fried black box. 20A single main fuse would have kept supplying too much current to the ignition until the smoke escaped.
John: If you decide to install a fuse box, plan ahead and understand exactly which wire to cut, and where. Figure out exactly where the fuse box will live, measure twice, cut once and you can avoid a lot of "spaghetti." I had the advantage of designing my harness with a fuse box in mind. Certain circuits, like the horn, would be difficult to fuse separately with the stock wiring.
Re: Extra fuses neg or pos side ? [Re: FLYNN54] #612688
08/13/15 1:18 am
08/13/15 1:18 am
Mitch Offline
Mitch  Offline
whuuuuttt??? choose the proper rating and style. there is fast, normal, and slo-blo. even a slo-blow will cook off at 2x the rated current (in less than a second). a dead short will take out a fuse that is 2, 3, maybe even 4x the rating
it's nice to have a main fuse, then, sub system fuses at lower ratings. lights, ignition, accessory, etc. any failure in a subsystem should leave the main intact. the only time a main would blow is a dead short on the main cable
Re: Extra fuses neg or pos side ? [Re: Mitch] #612780
08/13/15 2:54 pm
08/13/15 2:54 pm
Hi Mitch,
Note Nick's "Loc:" ... I think the humour has something to do with being upside-down ...
Regards, wink
Re: Extra fuses neg or pos side ? [Re: Stuart] #612862
08/14/15 6:58 am
08/14/15 6:58 am
fefsa
fefsa
meanwhile, in australia . . .
Re: Extra fuses neg or pos side ? [Re: FLYNN54] #612979
08/15/15 2:01 am
08/15/15 2:01 am
That your idea of a date?
We like to keep our women on the pillion here in the states.
Re: Extra fuses neg or pos side ? [Re: DavidP] #612993
08/15/15 4:56 am
08/15/15 4:56 am
OZ
Triless Offline
Triless  Offline
OZ
So, that explains why quite a few of you blokes have the wool pulled over your eyes!
Re: Extra fuses neg or pos side ? [Re: kevin roberts] #613004
08/15/15 7:43 am
08/15/15 7:43 am
shocked O...M...G
Still, we can console ourselves it's only a Suzuki owner?
laughing
Re: Extra fuses neg or pos side ? [Re: FLYNN54] #613362
08/17/15 6:22 pm
08/17/15 6:22 pm
F
FLYNN54 Offline OP
FLYNN54  Offline OP
F
Thank you to all who responded to my post regarding adding extra fuses/protection to my wiring harness. After reading your experiences I intend to fit a 4 way fuse box in the space between the coils. Circuit 1 lighting. 2 Ignition. 3 charging through Podtronics - using existing (old rectifier) terminals. 4 a spare to carry a fuse - all on the "Hot Side" as suggested. Sticking a small cardboard box under the seat and slamming it shut shows enough clearance to be present. (high tech eh?). Some fuse boxes on sale in the UK do appear to have their terminals somewhat exposed and within close touching distance of the metal coil holding tray - others have their metal terminals protected by a ledge below them ( I'm about to order the latter type). I fully take on board the comments made regarding "new" stock type harnesses - a custom made one would have been a far better bet- ha ho!! As stated previously the rationale for all of this was to avoid being immobile because of a "fault" in a circuit taking out the single fuse. As a footnote my new battery has its terminals facing forward and they are too close to the frame plate behind the oil filler cap (oif) for my liking - I must wrap it in old inner tube to be on the safe side. Best regards and thank you again. John.
Re: Extra fuses neg or pos side ? [Re: FLYNN54] #613382
08/17/15 9:12 pm
08/17/15 9:12 pm
fefsa
fefsa
consider adding the ground-side main fuse that stuart suggested, to protect the entire harness plus battery. if you're also adding hot-side fuses for individual circuits, you'll have a harness better in every way than what your machine came with.
Re: Extra fuses neg or pos side ? [Re: kevin roberts] #613390
08/17/15 10:40 pm
08/17/15 10:40 pm
Pacific northwest
quinten Online confused
quinten  Online Confused
Pacific northwest
If it were a new harness and you were of limited low voltage experience .
... And wanted to stay that way .
The quickest way to 'double' your fusing , without making a mess of wires , would be to fuse both positive and negative .
A red fuse holder for the positive .
A black fuse holder for negitive .
Wired within 6"~10" of the battery .
This would confuse all camps ... and when queried about them , you could say ,
" yeah , they're in series " .
The only bits left unprotected would be the battery terminals and the short
lengths of wire before the fuses .
