Lars Melin
Lars Melin
Sweden
30 registered members (Adam M.), 173 guests, and 442 spiders.
Andy Mac, kwbikr, RandomTask, George Henstorf, IanBSABurns44
10378 Registered Users
Mori55 94
NickL 86
DavidP 82
Stuart 82
reverb 73
Triless 69
687,851 mail-order LSR
Topics67,995
Posts661,404
Members10,378
Removing Magdyno from B33...Trouble #611718
08/06/15 8:04 am
08/06/15 8:04 am
Leicestershire, England
Owain Offline OP
Owain  Offline OP
So I'm dismantling the engine of the B33 barn find I have. I'm having trouble removing the magneto drive pninion center nut. Everytime I take a spanner to loosen it...the entire cam gears rotate with it. One of the fella's in the garage said to stick a spanner in the teeth of one of the cam gears to stop it rotating when I try to loosen the nut but that sounds a sure-fire way to knacker the gears themselves.
In the Haynes manual, it says just use a spanner to loosen it....and then use a special tool (no.61-1903) to extract the pninion itself. No chance of me getting to that pninion with this gear and nut in the way though...
Any solutions?
Owain
1969 - BSA Rocket 3
1950- BSA A10
Re: Removing Magdyno from B33...Trouble [Re: Owain] #611735
08/06/15 10:20 am
08/06/15 10:20 am
Canada
LarryLebel Offline
LarryLebel  Offline
Canada
Maybe use a block of hard wood instead.
Re: Removing Magdyno from B33...Trouble [Re: Owain] #611740
08/06/15 11:14 am
08/06/15 11:14 am
Put the bike in gear, sit on the seat with one foot on the rear brake, remove the nut. The pinion gear sits on a taper. You need an extractor, 61-1903, that threads into the center of the gear. Snug up the bolt in the center of the extractor but don't over tighten. The bolt doesn't remove the gear, a light tap on the end of the bolt will break the hold on the taper. If you use the bolt to remove the gear you will mushroom the end of the magneto pinion.
Re: Removing Magdyno from B33...Trouble [Re: Owain] #611779
08/06/15 3:31 pm
08/06/15 3:31 pm
Owain Offline OP
Owain  Offline OP
Cheers boomer, unfortunately the engine is already removed and laying on a work bench...so no chance of me placing the bike in gear and removing it that way. Good tips for pninion Removal though. Perhaps sticking an old wooden Broom handle between the CAM gears like Larry suggested might work without arsing up the teeth on the gears..
Owain
1969 - BSA Rocket 3
1950- BSA A10
Re: Removing Magdyno from B33...Trouble [Re: Owain] #611791
08/06/15 5:39 pm
08/06/15 5:39 pm
newcastle australia
trevinoz Offline
trevinoz  Offline
newcastle australia
Put a piece of rag between the gears.
Re: Removing Magdyno from B33...Trouble [Re: Owain] #611850
08/07/15 5:29 am
08/07/15 5:29 am
Westminster, Colorado
stubbicatt R.I.P. Offline
A shop towel or rag in the gears will jamb them so that the nut may be loosened.
