Ob1quixote
Ob1quixote
Charleston SC
207 registered members (1xfatboy), 1,884 guests, and 585 spiders.
BosBSA, Ron 1973 TR7RV, barnett468, dohck4, Pascal Di Marco
10028 Registered Users
Lannis 146
Stuart 63
475,307 mail-order LSR
Topics65,693
Posts634,977
Members10,027
Johnvr's Greeves clutch mod photos and info #605821
06/23/15 9:28 am
06/23/15 9:28 am
Jordan, NY
Al Eckstadt Offline OP
Jordan, NY
John sent me photos and notes on his adaptation of a Greeves clutch to fit an Interceptor. This unit requires no machining - the only fitting is to use spacers to line up the chainring with the front sprocket.
The unit is from a Greeves 380cc "Crosser" - I am guessing that is a Greeves motocross machine. The cost last year was L350 - 350 pounds GB. The vendors contact info is below.
John has no financial interest - nor I - in this modification. John has offered assistance to anyone who needs help installing it. His contact info is also below.
My understanding is that these photos are of the Greeves unit:
Note from Simon at Nametab Engineering:
"From: simon [simon@isdm.co.uk]
Sent: zaterdag 10 mei 2014 14:27
To: John Van Ravenswaaij
Subject: Greeves Clutch
Hi John
Yes I have all parts for these clutches
Bronze plates are 6.10 each
Complete clutch is 350.00
The above prices do not include postage & vat @ 20% Regards Simon"
Nametab Engineering, Redditch, Worcestershire
Note from John van Ravenswaaij:
"There is no shock absorber in the clutch. Never have felt it as a disturbance,
I have replaced the shock absorbers in the rear wheel.
There is no machine work on the clutch at all, straight on the shaft of the gearbox.
Only line up with the front sprocket with the washers if necessary. I used one to line up.
I have used 1 old clutch spring with a Teflon damper and an inner bolt to span the chain spanner.
Use Loctite to fix the nut of the shaft to fix it.
I have drilled a M3 thread in the clutch to fix the nut extra.
The clutch is only suitable with a push rod.
The same push rod as the original Interceptor clutch."
You can find him on BritBike.com as Johnvr
email - john.van.ravenswaaij@diracindustries.com
Al Eckstadt
Re: Johnvr's Greeves clutch mod photos and info [Re: Al Eckstadt] #605825
06/23/15 10:04 am
06/23/15 10:04 am
The Netherlands
Johnvr Offline
Johnvr  Offline
The Netherlands
Hi Al,
Thanks for posting the pics.
The clutch is from a Greeves 380cc Griffon motocross bike.
