Keane Lucas
Keane Lucas
New Jersey
33 registered members (Bob Buchanan), 271 guests, and 445 spiders.
vietnammotorbike, Lennart Liljedah, Mal Wood, FireGuyKC, spuggy
10288 Registered Users
Stuart 94
Lannis 65
Mori55 60
636,061 mail-order LSR
Topics67,365
Posts654,057
Members10,288
Page 1 of 4 1 2 3 4
Twice the problems #599572
05/15/15 7:00 am
05/15/15 7:00 am
Running from demons in WNY
Hillbilly bike Online content OP
Hillbilly bike  Online Content OP
This thing is sitting in my shop.My race bike rider and me dragged it back from Pa last week..He also picked up an elephant skull, but that's not bike related. grin
Supposedly I'm building this into a safe LSR bike.It would run in 1350cc gas altered/open class.The record for this class at Maine and Ohio is less than 140 MPH . Lowbrow has a 152 MPH record at Bonneville.
150 MPH for a naked frame LSR bike requires about 120 HP...I do know how to build reliable 60 hp gas 650 engines.. The engines is the easy part, the drive line and frame modification are more difficult... And about $10,000.................
I ride junk
Re: Twice the problems [Re: Hillbilly bike] #599589
05/15/15 10:31 am
05/15/15 10:31 am
queensland australia
ken sak Offline
ken sak  Offline
sonny route ,borris murray ran twin engines in drag racing, this is interesting - stock clutch/gearbox, mild engine
he comments idles at about 600 rpm
Re: Twice the problems [Re: Hillbilly bike] #599607
05/15/15 12:19 pm
05/15/15 12:19 pm
Irene, South Africa
robcurrie Offline
robcurrie  Offline
Irene, South Africa
It looks like the exhausts should be swapped around to clear the front carbs?
Rob C
Re: Twice the problems [Re: Hillbilly bike] #599620
05/15/15 1:37 pm
05/15/15 1:37 pm
ken sak Offline
ken sak  Offline
and add a supercharger
Re: Twice the problems [Re: Hillbilly bike] #599623
05/15/15 2:09 pm
05/15/15 2:09 pm
Riverside, CA.
noisy norton Offline
Riverside, CA.
Twice the problems? I'd call it twice the fun. Don Sligers twin Enfield (750s I think) was the first naked bike over 200. Good target.
Re: Twice the problems [Re: noisy norton] #599628
05/15/15 3:01 pm
05/15/15 3:01 pm
Well for sure twice the cost...a pair of 650 N/A Triumphs on gas is gonna be nowhere near 200 mph....As Noisy Norton knows from the JJ, I'm not too enthusiastic about using the stock stretched frame...But it is what it is on the available budget.
I think there's a few things to consider...How the engine are "timed". Do you phase them 360 or 180 degrees apart ?...And the drive system .I see they all appear the run a chain or belt from the front engine to the rear engine and then from the rear engine to the clutch.I think it's better to have both both engines drive a common jack shaft and then from the jack shaft to the clutch..But I don't know if this can be packaged properly...The idea here is to be efficient and not lose too much power through the drive train ..
I ride junk
Re: Twice the problems [Re: Hillbilly bike] #599670
05/15/15 9:17 pm
05/15/15 9:17 pm
kevin roberts Offline
fefsa
fefsa
pictures of the elephant skull!!!
i have no idea what i'm doing.
Re: Twice the problems [Re: robcurrie] #599715
05/16/15 6:20 am
05/16/15 6:20 am
Rob C
Those are just pipes I had laying around. The front engine needs to be raised up about an inch in relation to the rear engine for the carbs to clear properly.
Kevin, I don't have skull photos...but it was different...
I ride junk
Re: Twice the problems [Re: Hillbilly bike] #599750
05/16/15 12:54 pm
05/16/15 12:54 pm
ken sak Offline
ken sak  Offline
how about rotating the head? I thought I read somewhere sonny used 90 degrees apart
.quote I see they all appear the run a chain or belt from the front engine to the rear engine and then from the rear engine to the clutch.I think it's better to have both both engines drive a common jack shaft and then from the jack shaft to the clutch..But I don't know if this can be packaged properly...The idea here is to be efficient and not lose too much power through the drive train ..quote
why don't you think it would be efficient? 2 engines power on the back crank -must be up to it
Re: Twice the problems [Re: ken sak] #599764
05/16/15 3:41 pm
05/16/15 3:41 pm
Some do rotate heads....A chain or belt drive normally has a pulling side and a slack side. Like a Triumph unit or Harley with a slack adjuster on the bottom run of the primary chain. With two engine coupled by chain nothing is perfectly timed between the two engines and I think the chain is subject to a lot of harmonics whipping the chain . This wastes power and creates vibration..I'm no engineer so I'm just making opinion...
In reality there's no room for any design but what is typical used.
I ride junk
Re: Twice the problems [Re: Hillbilly bike] #599770
05/16/15 5:03 pm
05/16/15 5:03 pm
Riverside, CA.
Riverside, CA.
There is a way to couple the engines without harmonics or destroying chains. I don't know it but get a hold of Tyler and he'll tell you how. In the meantime I'll have to stop looking at this thread. It breaks my heart to think that frame will be scrapped.
Re: Twice the problems [Re: noisy norton] #599777
05/16/15 5:49 pm
05/16/15 5:49 pm
I never said the frame will be scrapped... I have expressed my doubts on using it because they are flexible...And Alp added not only flexible but subject to fracturing from the stresses.The builder of the "Parasite", one of the first dual Triumph dragsters mentions cracking hard tail frame rails.
I believe a competitive bike needs to be reliable, easy to ride, stable and rigid. We're not running in vintage so the frame heritage isn't important. Another guy has asked to buy the frame from from me. If you like the frame so much then make me an offer.
Lowbrow uses belts from what I see. Routt may have timed the engine at 90 degrees. Lowbrow and "Parasite" and a few other timed the engines to run together...I assume that means right cylinders, front and rear, fire at the same time.
I ride junk
Re: Twice the problems [Re: Hillbilly bike] #599785
05/16/15 8:54 pm
05/16/15 8:54 pm
ken sak Offline
ken sak  Offline
If the the hardtails crack and the rules allow,get or make a new one made up from the front downtube back,
the bottom rails prob have been joined anyway.
I can remember a twin side by side engine street bike that had the engines pistons rising and falling together
and he said the vibrations were bad,and he changed it
90 degrees - like the offset crank 1 pistons stopped at TDC the other near full piston speed
Re: Twice the problems [Re: Hillbilly bike] #599787
05/16/15 10:39 pm
05/16/15 10:39 pm
Iowa
konon Online content
konon  Online Content
Iowa
I would think you'd want the front engine firing on left and back engine on right to counter each other.
1968 BSA Firebird
1200 HD
XS 1100
1972 Rickman 125
Re: Twice the problems [Re: Hillbilly bike] #599803
05/17/15 6:57 am
05/17/15 6:57 am
ken sak Offline
ken sak  Offline
Run front motor off rh side? to jackshaft then short distance to rear engine
Re: Twice the problems [Re: Hillbilly bike] #599804
05/17/15 7:02 am
05/17/15 7:02 am
ken sak Offline
ken sak  Offline
raised front motor
Re: Twice the problems [Re: konon] #599805
05/17/15 7:06 am
05/17/15 7:06 am
ken sak Offline
ken sak  Offline
you would still have the problem of all 4 rising and falling
together
Re: Twice the problems [Re: Hillbilly bike] #599833
05/17/15 12:07 pm
05/17/15 12:07 pm
south ester pa
DanDaughenbaugh Offline
south ester pa
I guess we were bidding against each other, Got me in the last second
Re: Twice the problems [Re: DanDaughenbaugh] #599837
05/17/15 12:40 pm
05/17/15 12:40 pm
Then you were bidding against my race bike rider. The bike is worth the money depending on what a person intends to do with it.
I ride junk
Re: Twice the problems [Re: Hillbilly bike] #600869
05/23/15 4:33 pm
05/23/15 4:33 pm
Florida PanHandle
Zombie Offline
Zombie  Offline
Florida PanHandle
I thought that was you... Glad to see you posted that cool factor machine here.
I'm no rocket surgeon but chain drive, and same side firing sounds like a bucket full of whipped chains, and a shop full of welding materials.
I messed around w/ twin 50cc single cylinder engines for awhile, and came to realize that ALL multi cylinder engines must be hard joined, and opposing firing orders. Think about it. No production multi cylinder engine uses any sort of buffer between cylinders. They all uses one cylinder to force the other(s) thru the cycle.
I would seriously think about a gear drive joining the engines. It's as close to a hard join as you can get.
I may be WAY off in this but I'm sure the current multi engine bikes can provide a clue.
edit... Whatever you come up with, I'm sure will be cooler than anything else around for MILES!
Looking forward to seeing what you do w/ this. beerchug
RZ
Re: Twice the problems [Re: Zombie] #600933
05/24/15 6:48 am
05/24/15 6:48 am
Most All the successful Triumph dual engine drag and LSR bikes have the engines firing as one.Some are right front and left rear firing together or right and right.
It h to do with the way two engines are linked by chain or belt and the pushing/pulling action...
A gear drive is wonderful but the cost is totally out of my budget.It would require a train of gears on precision centers enclosed in a oil tight case which is beyond my experience.
Other than engine machine work everything is done with hand tools and an WW2 lathe in my shop.
100 bucks worth of O ring chain and another 100 bucks worth of sprockets will build a workable chain drive. Properly done and adjusted a chain is as efficient as gears.....Also considering linking the engines with a tooth belt that would offer some dampening effect.
I ride junk
Re: Twice the problems [Re: Hillbilly bike] #600943
05/24/15 8:06 am
05/24/15 8:06 am
Florida PanHandle
Zombie Offline
Zombie  Offline
Florida PanHandle
I sure understand that.
If you went into belts I imagine there are some easy solutions to using some of the heavy duty Harley primary parts.
I'm sure it will be a challenge, and hopefully more fun than frustration.
Re: Twice the problems [Re: Zombie] #600960
05/24/15 12:16 pm
05/24/15 12:16 pm
I removed the engines and had a good look at the frame...I'm going to work with it, some gussets and trusses.
I ride junk
Re: Twice the problems [Re: Hillbilly bike] #600978
05/24/15 1:58 pm
05/24/15 1:58 pm
Riverside, CA.
Riverside, CA.
Delighted to hear that!
Re: Twice the problems [Re: Hillbilly bike] #601036
05/24/15 8:38 pm
05/24/15 8:38 pm
Florida PanHandle
Zombie Offline
Zombie  Offline
Florida PanHandle
Is the frame marked? do you know what it started life as?
I was thinking about this last night, and it occurred to me that balancing the carbs would be the toughest real issue in balancing the engines to run synced up.
Then the idea of spinning a cylinder head to put all of your intakes in the center, and making an intake manifold to run a single 4bbl carb. It would be a great deal easier to set up one Quadrajet carb. than to tune 4 mikunis or whatever. Maybe an old Weidland intake could be the donor manifold/carb mount.
Just throwing some ideas around.
Page 1 of 4 1 2 3 4
Moderated by  Allan Gill
