iansoady
iansoady
Birmingham UK
33 registered members (998John), 215 guests, and 455 spiders.
10257 Registered Users
Stuart 80
Lannis 57
610,000 mail-order LSR
Topics67,134
Posts651,487
Members10,257
Rating: 2
BSA Speedo #598800
05/10/15 2:25 pm
05/10/15 2:25 pm
Hamburg, Germany
Thomas MS Offline OP
Hamburg, Germany
I just got a 1964 A50. The speedo is broken and was anyway an indian replica The speedo is driven from the crankcase, not from the rearwheel.
Can anybody recommend a good speedo with a correct gear ratio?
Or maybe the correct ratio at least?
I was looking around but can find only stuff for the rear wheel driven later models 1966 and younger.
Many thanks in advance smile
Thomas
BSA A50, before OIF Bonnie
Re: BSA Speedo [Re: Thomas MS] #598950
05/11/15 10:57 am
05/11/15 10:57 am
Your bike would originally have had a grey-face chronometric (SC3313/00 in miles, SC3313/00 in km), but those are pretty rare. Your best route is probably to find a useable chronometric speedometer and have it rebuilt with a reproduction face and the correct ratio. I don't remember the correct ratio off the top of my head, but I believe 1600 revs/mile (1000 revs/km) is correct.
Re: BSA Speedo [Re: Alex] #598973
05/11/15 12:33 pm
05/11/15 12:33 pm
The Northwoods... Michigan
Steve Erickson Offline
Are you sure, Alex? I thought that all the BSA line switched to magnetic instruments at the start of the 64 model year...?
Re: BSA Speedo [Re: Thomas MS] #598981
05/11/15 12:50 pm
05/11/15 12:50 pm
Hamburg, Germany
Hamburg, Germany
Hi Alex, Hi Steve,
Thanks very much for your help. I think I will try a replica speedo, but a better one this time.
Thats why i need the gear ratio, there are quite some on the market.
Any ideas?
Greetings from Hamburg
Tom
Re: BSA Speedo [Re: Thomas MS] #598990
05/11/15 1:29 pm
05/11/15 1:29 pm
kommando Offline
kommando  Offline
Your gearbox ratio is much the same as the rear wheel gearbox ratio of 2:1 which means the speedo needs to be a 1600 revs per mile or 1000 per km as the rear wheel does 800 revs per mile or 500 revs per km. Not seen an aftermarket speedo covering that ratio.
Re: BSA Speedo [Re: Thomas MS] #599000
05/11/15 2:22 pm
05/11/15 2:22 pm
Steve, you're right. My bad...I thought I saw that this was for a '62 model.
Re: BSA Speedo [Re: Thomas MS] #599099
05/12/15 8:54 am
05/12/15 8:54 am
West Virginia, United States
Beach Online content
Beach  Online Content
An A50 Star takes SC 3313/00...The A50 cyclone took SSM 5001/03 (1600 2-1) which is readily available...I would purchase a used one and if it doesn't work, have it rebuilt...
1974 Norton Commando
1966 Lightning
1965 Lightning Rocket
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Re: BSA Speedo [Re: Thomas MS] #599133
05/12/15 1:44 pm
05/12/15 1:44 pm
Hamburg, Germany
Hamburg, Germany
Hi all!
Thank you very much for your help! So I will try to get a speedo with a 2:1 ratio, of course preferred an original one.
Tom
Re: BSA Speedo [Re: Thomas MS] #599137
05/12/15 2:33 pm
05/12/15 2:33 pm
kommando Offline
kommando  Offline
It won't have 2:1 written on it anywhere, you need one with 1600 in small letters on the outside edge of the face if its MPH, not sure the numbers on the Km/h version.
Re: BSA Speedo [Re: kommando] #599140
05/12/15 3:04 pm
05/12/15 3:04 pm
Well,
I have two grey face chrono's, that are supposed to go onto the cowled or nacell type head lamp assemblies, because of the flanged bezel, it's numbers are:
SC 3313/02 1260
Re: BSA Speedo [Re: Rickman] #599863
05/17/15 1:56 pm
05/17/15 1:56 pm
South-Carelia, Finland
Beezaster Offline
Beezaster  Offline
Sorry to hijack this thread, but as it is rather convenient, I'll ask about this here.
Can anybody tell me how to tell apart chronometric an magnetic speedometers? I have a speedo that says "S.467/59/L CHRONOMETRIC SMITHS M.A. MADE IN ENGLAND" on the face. However, if I was asked, I would say the clock is operated by some kind of a magnetic system. Is the chronometric speedo mechanic, do I have some kind of a replica?
The speedo shows speed readings that are total nonsense and the odometer gives distances in miles that can be converted to kilometers By a coefficient of approximately 2,6 and it seems to work this way rather consistently.
Judging by the behaviour of the odometer it's easy to come to a conclusion that the speedo drive on the rear wheel hub might be too slow, but AFAIK this very clock has previously worked with an original Smiths 1,25:1 drive, which has since been replaced with a repro. Besides, wouldn't a 2:1 drive be even slower?
Some of them call me "Teddy"
'71 A65 Thunderbolt "The Killer Bee"
(Also the frustrated owner of a Triumph Spitfire 1500)
Re: BSA Speedo [Re: Thomas MS] #599866
05/17/15 2:12 pm
05/17/15 2:12 pm
kommando Offline
kommando  Offline
The Chrono has a clockwork mechanism, it moves in jerks or steps instead of having a smooth action like the Magnetic (assuming the magnetic is working as a lot don't).
This shows a tacho Chrono working
https://www.youtube.com/watch?v=c4n2dpK4Xfc
If the gearbox is wrong then the speedo readings will be wrong.
Re: BSA Speedo [Re: kommando] #600947
05/24/15 8:42 am
05/24/15 8:42 am
Beezaster Offline
Beezaster  Offline
Right, well there's definately no clockwork inside my speedo, so a knock off for sure. The drive gearbox is probably the wrong one, but even so, the speedo should still work logically, just giving too low readings. I went a short strech flat out in fourth gear last night and as I looked down at the speedometer it showed a steady 10 mph. I don't think that's correct.
I'm thinking of getting magnetic replica clocks (no tacho at the moment), but are they any good or just a waste of money?
Any experience on these for example?:
http://www.feked.com/speedometer-black-face-replica.html
http://www.feked.com/speedometer-grey-face-replica.html
Re: BSA Speedo [Re: Beezaster] #600988
05/24/15 2:32 pm
05/24/15 2:32 pm
Lives in Devon, covered in oil
DickDastardly Offline
Personally, I would get any original Smiths speedometer, (doesn't matter how crap it is) send it to:
A.E. Pople, Speedo Repairs,
C/O A & E Coachworks,
The Vehicle Centre
Ashchurch Road,
Aldershot,
Hants,
GU12 6LX
Tell them the model you want it to be, they also supply the correct length cables, don't buy Indian cr4ppy ones, job done! It wont be cheap but then, as they say, "Buy cheap, buy twice"!
I supplied them with an old Norton Commando Rev counter that was garbage that I got for next to nothing and they turned it into a pristine 'Grey Face' A65 Rev counter that is spot on!
