Ian Clifton
Ian Clifton
Rotherham, UK
199 registered members (Adam M.), 2,042 guests, and 550 spiders.
10070 Registered Users
koan58 85
Lannis 83
NickL 75
501,725 mail-order LSR
Topics66,002
Posts638,761
Members10,070
spoke patterns #59943
03/09/08 12:21 am
03/09/08 12:21 am
gastonia nc
raf940 Online content OP
raf940  Online Content OP
gastonia nc
howdy.....i spotted some rims on eBay....the ad said they were 1x1 pattern....what pattern does bsa QD crinkle hub have.....what pattern does TLS front brake have?? how do you tell the difference?
thanks
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando project
Re: spoke patterns #59944
03/09/08 3:52 am
03/09/08 3:52 am
ca, us
DMadigan Online content
DMadigan  Online Content
ca, us
Spoke patterns are 1x, 2x, 3x,... It is the number of spokes that cross each other on one side. Presumably 1x1 means it has 1 cross on each side. The weakest pattern is 0x (no crossing or radial). I do not believe anyone except Hardley guys use that on the front with no front brake (no way to transmit the tangential rim force to the hub except radial compression of the rim). The closer the spoke pulls tangent to the hub the stronger it is. I think the QD hubs were 3x on both sides. The comical hub had 1x on the brake side (because of the diameter) and 3x on the far side.
Re: spoke patterns #59945
03/09/08 4:27 am
03/09/08 4:27 am
Toledo, OH USA
M.O.Ther Offline
M.O.Ther  Offline
Toledo, OH USA
I think the 1 x 1 he's refering to is the dimpling pattern, every other dimple is on the opposite side of the rim. 1 x 1 is the most common, and I believe crinkle hub BSAs were like that, but it's too dark in my storage place to go and look right now.
I have a sprung hub Triumph that has a 2 x 2 pattern (but is drilled differently from my early '60's Harley Sportster Aluminum rim that is also 2 x 2. On the Triumph, each pair of dimples is drilled for the spokes to go in opposite directions, on the Harley, each pair goes in the same direction) I also have a 21" rim with a 3 x 1 dimpling pattern. I think some of the early '60's BSAs with the half brake on the front were dimpled like that.
M.O.Ther
Assorted Harleys
Pre Unit Triumphs
Unit BSA twins
and a Matchless Pinto
Re: spoke patterns #59946
03/09/08 4:48 pm
03/09/08 4:48 pm
Toledo, OH USA
M.O.Ther Offline
M.O.Ther  Offline
Toledo, OH USA
Daylight finds the following: 4 BSA A65 crinkle hub rears, 1 x 1 dimple pattern. These are laced cross 2. (that means each spoke crosses two other spokes on the same side of the wheel.)
2 BSA A65 front half brake 3 x 1 dimple pattern. These are laced cross 2 on the brake side, and cross 4 on the small side.
2 BSA A65 front TLS brake 2 x 2 dimple pattern, with each pair going in the same direction. These are laced cross 1.
M.O.Ther
Assorted Harleys
Pre Unit Triumphs
Unit BSA twins
Re: spoke patterns #59947
03/09/08 5:01 pm
03/09/08 5:01 pm
gastonia nc
gastonia nc
MO Ther
many thanks!
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1975 yamaha xs650b
Page Time: 0.163s Queries: 14 (0.005s) Memory: 1.0153 MB (Peak: 1.1656 MB) Zlib disabled. Server Time: 2018-02-19 00:06:09 UTC
