ChrisX
ChrisX
Lake Macquarie NSW Oz
201 registered members (57nortonmodel77), 2,292 guests, and 670 spiders.
myshootingstar68, Caddy, Spitfiregary, Ashley, HerbertG
10073 Registered Users
Lannis 84
koan58 82
NickL 78
Stuart 63
502,952 mail-order LSR
Topics66,018
Posts638,954
Members10,073
Headstock bearings #594045
04/08/15 2:13 pm
04/08/15 2:13 pm
Llangollen, North Wales
Treforissa Offline OP
Hi, Converting my C15 with different forks and need to change the headstock bearings. Machining up top and bottom bearing holders but my question is.... What are the best type of bearing to use? Plain roller or taper roller. Or is there any other ideas. I'm all ears.
1958 Tiger Cub
1959 C15
1960 C15
2014 Triumph Bonneville America
Re: Headstock bearings [Re: Treforissa] #594069
04/08/15 5:16 pm
04/08/15 5:16 pm
Sydney, Oz
Shane in Oz Online content
Shane in Oz  Online Content
Sydney, Oz
Tapered roller if you can get them in the right dimensions.
SRM sells tapered roller bearings as a straight replacement for the pre-OIF unit singles and twins, but they may not fit the new shaft. If you have the gear you could build up / machine the shaft to size.
Re: Headstock bearings [Re: Treforissa] #594088
04/08/15 7:29 pm
04/08/15 7:29 pm
Tridentman Online content
Tridentman  Online Content
Historically almost all steering head bearings were of the cup and cone type.
Then came the use of tapered roller bearings (but never parallel roller bearings at least in general use).
Now some of the modern Japanese machines have reportedly gone back to cup and cone bearings.
The reason is that the tapered roller bearing rollers have a larger diameter than the cup and cone type balls. In the steering head application the handlebars are normally in the straight ahead position or just a little to each side of it.
This small movement gives plenty of rotation on the small balls but very little on the much larger taper rollers. This can cause the surface of the taper roller to "Brinell" and the surface of the taper roller to crack up.
Certainly on a C15 I would have thought that the original cups and cones would be perfectly satisfactory.
Re: Headstock bearings [Re: Treforissa] #594159
04/09/15 11:43 am
04/09/15 11:43 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
The load on the lower bearing is both radial and axial. The top bearing is mostly radial so a taper bearing on top is overkill.
Re: Headstock bearings [Re: Treforissa] #594206
04/09/15 4:40 pm
04/09/15 4:40 pm
NH
GreenMonster Offline
NH
Tapered bearings upper and lower.
Their is reason modern machines use these.
Never Allow The Radical Views Of The Few To Infringe On The Constitutional Rights Of The Many
Re: Headstock bearings [Re: Treforissa] #594280
04/10/15 8:31 am
04/10/15 8:31 am
NH
NH
The original ? was was are the (best) type of bearings to use?
Okay we know that that application is the fork yokes.
Tapered roller bearings do a much better job at handling the stresses that are exerted at the neck than ball bearings.
Straight roller bearings????
They fit ball bearings because they are cheap. Not because they are optimal choice for that application.
But what the hell do I know i'm just a stupid wrench not a mechanical engineer.
Re: Headstock bearings [Re: Shane in Oz] #594477
04/11/15 4:05 pm
04/11/15 4:05 pm
Columbia SC USA
H
Hambone Online content
Hambone  Online Content
H
Columbia SC USA
I too am considering this head stock bearing conversion for my 1969 A65 and as you say Shane they may not fit? I believe I once read where the headlight ears don't quite seat right after conversion leaving a gap at the top. Am I correct in assuming that would be the case if I installed the SRM straight replacement? Or have they solved that issue? I am fine with the balls and cups but not the pain of installing them!! any advice would be great Thanks.
Re: Headstock bearings [Re: Hambone] #594554
04/12/15 5:08 am
04/12/15 5:08 am
Sydney, Oz
Sydney, Oz
I think they fit standard bikes alright, but the OP was considering fitting non-standard forks.
I read ages ago that the SRM taper roller steering head bearings are off the shelf bearings of the right thickness, and SRM grinds the OD of the cup and / or ID of the cone to fit BSA steering heads.
Of course, that may just have been press release hype.
I bought a set of SRM tapered roller steering head bearings on special from Walridge Motors, but they were held up in Customs for ages so I haven't fitted them yet.
Re: Headstock bearings [Re: Hambone] #594558
04/12/15 5:52 am
04/12/15 5:52 am
Factory photo where the headlight brackets do not meet up with the top yoke.
Taper rollers are a good upgrade in my opinion.
Re: Headstock bearings [Re: Treforissa] #594813
04/13/15 7:20 pm
04/13/15 7:20 pm
Gone for taper roller. Machining up new bearing holders to fit the C15 headstock. Thanks for the help guys.
1958 Tiger Cub
1959 C15
1960 C15
Page Time: 0.915s Queries: 15 (0.006s) Memory: 1.0613 MB (Peak: 1.2485 MB) Zlib disabled. Server Time: 2018-02-21 01:13:02 UTC
