trevinoz
trevinoz
newcastle australia
14 registered members (Alan_nc), 173 guests, and 104 spiders.
DennisMartin, Dwight V, urbanghost, Richard313, Gordo
10385 Registered Users
NickL 97
Mori55 82
Stuart 81
Rohan 80
Triless 79
reverb 78
DavidP 74
btour 66
690,050 mail-order LSR
Topics68,037
Posts661,964
Members10,385
Pre Mark-3 Isolastics? #592407
03/29/15 4:08 am
03/29/15 4:08 am
Royal Berkshire.
Kev. Offline OP
Kev.  Offline OP
Royal Berkshire.
I need to do the front iso's on my 750, but which set do I need? I have seen this on eBay, are they right for my 73 roadster...
http://www.eBay.co.uk/itm/351343651783?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
1952 Norton Special
1970 BSA A65 Lightning
1973 Moto Guzzi Eldorado
1981 Harley FLH
2006 BMW R1200GS
Re: Pre Mark-3 Isolastics? [Re: Kev.] #592416
03/29/15 5:47 am
03/29/15 5:47 am
kommando Offline
kommando  Offline
Do not buy ISO's from Norvil, they are built to a price and use an off the shelf tube which has too large an ID, the bearded one says they are OK but why risk it to line his pockets. Buy from Mick Hemmings, RGM or Andover Norton, if you ring them they can sort out the best version for you, best to go for vernier adjusters for pre-MK3 as for the front at least MK3 will not fit without some work.
Re: Pre Mark-3 Isolastics? [Re: kommando] #592417
03/29/15 6:06 am
03/29/15 6:06 am
Les P Offline
Les P  Offline
Originally Posted By kommando
RGM
I liked the RGM isolastics enough to buy another set for the Fastback along with the extended top fork bushes for both bikes (Mk2a and Fastback)
More bikes and projects than you can shake a stick at but they should be done in two shakes of a lamb's tail.
Re: Pre Mark-3 Isolastics? [Re: Kev.] #592420
03/29/15 6:18 am
03/29/15 6:18 am
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
Originally Posted By Kev.
I need to do the front iso's on my 750, but which set do I need? I have seen javascript:%20void(0)this on ebay, are they right for my 73 roadster...
Yes, should be, although it isn't entirely necessary to replace the front engine mounting (061410) although I'd also suggest you buy the kit from Mick Hemmings or RGM.
Re: Pre Mark-3 Isolastics? [Re: Kev.] #592422
03/29/15 6:42 am
03/29/15 6:42 am
Peter R Offline
Peter R  Offline
Another vote for the Mick Hemmings iso adjusters.
Concerning the rubbers: make sure you buy the soft rubbers, many aftermaket iso rubbers are harder than the originals, and will transmit more vibration than the originals.
Don't ask me how I know..
Re: Pre Mark-3 Isolastics? [Re: Kev.] #594068
04/08/15 5:07 pm
04/08/15 5:07 pm
Royal Berkshire.
Kev. Offline OP
Kev.  Offline OP
Royal Berkshire.
I bought a vernier iso kit for my 750 commando, from Andover Norton, but all it came with was an
exploded diagram from the parts manual, . No instructions or anything on how to fit or set up??
Have any of you used the Andover kit, do I need to get the tube cut or is it all a straightforward fit?
frown
1952 Norton Special
1981 Harley FLH
2006 BMW R1200GS
Re: Pre Mark-3 Isolastics? [Re: Kev.] #594078
04/08/15 6:08 pm
04/08/15 6:08 pm
Norfolk, UK
Norfolk, UK
"Kit"?
06-7116 kit (front)?
06-7337 kit?
Assemble the new end caps, PTFE washers and abutments onto the tube and measure the overall length and compare that to the original assembly and/or the gap between the frame plates.
If it's the 06-7337 pre-Mk3 conversion kit, then the tube doesn't need to be cut down:
http://www.andover-norton.co.uk/News.htm
New from Andover Norton is a Vernier adjustable front Isolastic engine mount kit for all Pre-Mk3 Commandos, which is any Commando before 1975 which used shim Isolastic adjustment.
The new kit has modified width abutment and adjuster end parts to suit the unequal length front engine mount tube on pre-1975 Commandos, and gives the ease of adjustment which is only normally found on the Mk3.
This kit makes the setting and adjusting of the Isolastic clearances a much faster job.
Re: Pre Mark-3 Isolastics? [Re: Kev.] #594214
04/09/15 5:21 pm
04/09/15 5:21 pm
Royal Berkshire.
Kev. Offline OP
Kev.  Offline OP
Royal Berkshire.
I got this kit...
but where do the bits shown at the front go?
1952 Norton Special
1981 Harley FLH
2006 BMW R1200GS
Re: Pre Mark-3 Isolastics? [Re: Kev.] #594223
04/09/15 6:07 pm
04/09/15 6:07 pm
Norfolk, UK
Norfolk, UK
The silver coloured items are the new tube caps (these replace 060684).
The bronze coloured items are the PTFE washers (replace 060578).
The clip, far left, fits over the movable adjuster to prevent crud blocking the adjuster rod holes.
Here's the instructions for the RGM vernier conversion kit which is basically similar to the AN kit as far as assembly and set up is concerned, so might give you an idea of how it fits together and how to adjust it, however it's not exactly rocket science.
http://www.rgmnorton.co.uk/csi/1245184/f/pdf/mk3_vernier_isolastic_instructions.pdf
I do recommend that you check the Iso. clearance with a feeler gauge after the assembly has been fully tightened, and I prefer not to rely on the instruction to: "back off the adjuster by 1.5 turns". Due to the necessary running clearance between the threaded parts of the adjuster some Iso. clearance can be lost when the bolt (and nut) is tightened.
Re: Pre Mark-3 Isolastics? [Re: Kev.] #594290
04/10/15 9:50 am
04/10/15 9:50 am
Hamilton, Mass. USA
Dave Comeau Offline
Crew Chief
Dave Comeau  Offline
Crew Chief
Hamilton, Mass. USA
I got this kit...
Gotta say I have been given one for free and would not use it. Maybe the newest and softest kits and then only on the heavier MKIII. In my test chart the brown kit is probably what you currently get. Notice the blue curve originally supplied on pre MKIII, which is about half the rate of the brown.
And then people are surprised that their preMKIII vibrate more than before. But for a lot of people marketing seems to trump engineering and science.
The Mick Hemmings adjuster (designed by an American) is IMO an acceptable/worthwile mod for reasons of adjustability.
dynodave
BSA 3 1961-1963
Ducati 3 1992-2002
Norton many 1951-1975
Moderated by  Dave Comeau
