bitsa110
bitsa110
Far Northern California
207 registered members (57nortonmodel77), 2,340 guests, and 680 spiders.
myshootingstar68, Caddy, Spitfiregary, Ashley, HerbertG
10073 Registered Users
koan58 82
NickL 81
Stuart 64
503,301 mail-order LSR
Topics66,021
Posts638,985
Members10,073
Cam timing #593447
04/04/15 3:43 pm
04/04/15 3:43 pm
Pennsylvania, USA
cacinni Offline OP
cacinni  Offline OP
Pennsylvania, USA
Got TDC using my degree wheel, using the method lobe center angle to time cams and checking i/2 a dozen times iam coming up with 106 on the intake, megacycle specs 101 intake, 104.5 on the exhaust, what adjustment do i make to get to megacycle specs, triumph 500 motor, thanks guys!
Re: Cam timing [Re: cacinni] #593481
04/04/15 7:48 pm
04/04/15 7:48 pm
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
Remove the camwheel from the intake cam.
Without moving the cam, rotate the camwheel 120 degrees clockwise to the next keyway. Fit the camwheel back on. That should advance the timing 4.8 degrees.
The cam will actually move slightly when you re-fit the camwheel, but barely perceptible.
Then you'll need a new timing mark on that camwheel, 17 teeth away from the original mark.
Re: Cam timing [Re: cacinni] #593501
04/04/15 9:01 pm
04/04/15 9:01 pm
Pennsylvania, USA
cacinni Offline OP
cacinni  Offline OP
Pennsylvania, USA
Thanks Pete, for future reference, like when i do the exhaust cam, say it was advanced 3 degrees, i would advance how many teeth clockwise to clear up the difference? Thank you!
Re: Cam timing [Re: cacinni] #593509
04/04/15 9:26 pm
04/04/15 9:26 pm
Pennsylvania, USA
cacinni Offline OP
cacinni  Offline OP
Pennsylvania, USA
Re: Cam timing [Re: cacinni] #593512
04/04/15 10:42 pm
04/04/15 10:42 pm
Vic. Australia
Vic. Australia
You can only change the timing in 4.8 degree increments, unless you start using a selection of different camwheels.
If it's advanced 3 degrees, it will still run fine. You could even be happier with it.
4.8 degrees = 1/3 of a tooth
14.4 degrees = a full tooth
Re: Cam timing [Re: cacinni] #593517
04/05/15 12:19 am
04/05/15 12:19 am
nc
F
fightclub Offline
fightclub  Offline
F
nc
Not trying to hi jack thread Caccini but I had a question for Pete R. Mr.Pete did you do a thread/post on details on center lobe cam timing method. I cannot find anything doing search.
Thank you
Re: Cam timing [Re: cacinni] #593522
04/05/15 12:29 am
04/05/15 12:29 am
Vic. Australia
Vic. Australia
Here's something I wrote on another forum. That should give you an idea.(about 2/3 way down the page) You can measure at the top of the pushrod, with a dial gauge. Just take the measurement at the same lift on both the opening and closing ramp.
Cam Timing Check
Re: Cam timing [Re: cacinni] #593563
04/05/15 7:07 am
04/05/15 7:07 am
Pennsylvania, USA
cacinni Offline OP
cacinni  Offline OP
Pennsylvania, USA
FIGHTCLUB there is a excellent article on this in one of the back VINTAGE BIKE magazines.
Re: Cam timing [Re: cacinni] #593657
04/05/15 5:31 pm
04/05/15 5:31 pm
Pennsylvania, USA
cacinni Offline OP
cacinni  Offline OP
Pennsylvania, USA
After spending more time on the intake cam utilizing all 3 key ways the numbers i have 98.5, 102.0, 105.0 ran these key ways a couple different times, do these numbers alarm anyone? Plan on trying all 3 key ways during the week to make sure iam getting consistant numbers before moving on to exhaust cam! Thanks for your input guys!
Page Time: 1.032s Queries: 15 (0.011s) Memory: 1.0484 MB (Peak: 1.2276 MB) Zlib disabled. Server Time: 2018-02-21 13:14:28 UTC
