Panhead EL
Panhead EL
Virginia
38 registered members (79T140E), 255 guests, and 443 spiders.
LandoLando, MikeA, Jay Gilling, scratchedtank, Magic Monkey
10253 Registered Users
Stuart 72
Lannis 67
NickL 48
606,779 mail-order LSR
Topics67,086
Posts650,981
Members10,253
A10 oil pressure..how would you ever know? #590813
03/19/15 2:01 pm
03/19/15 2:01 pm
US
Z
zoe Offline OP
zoe  Offline OP
Z
US
How would you ever know if your A10 had low oil pressure?
Re: A10 oil pressure..how would you ever know? [Re: zoe] #590814
03/19/15 2:15 pm
03/19/15 2:15 pm
Christchurch New Zealand
Lew Graham Offline
Lew Graham  Offline
If there is a loud bang and the drive side conrod has punched a hole through the crankcase, that would be a fair indication. At swap meets one finds that there are many more timing side crankcases for sale than drive side cases. This is the reason.
Re: A10 oil pressure..how would you ever know? [Re: zoe] #590820
03/19/15 3:38 pm
03/19/15 3:38 pm
How would you ever know that your sludge trap is plugged?
Re: A10 oil pressure..how would you ever know? [Re: Alex] #590823
03/19/15 4:07 pm
03/19/15 4:07 pm
US
Z
zoe Offline OP
zoe  Offline OP
Z
US
How would you ever know before it's too late? Since it's evidently not possible to check the pressure with a gauge what are the early signs of low oil pressure in an A10.
Re: A10 oil pressure..how would you ever know? [Re: zoe] #590828
03/19/15 4:52 pm
03/19/15 4:52 pm
newcastle australia
trevinoz Offline
trevinoz  Offline
newcastle australia
Even with good pressure, take note of Alex's post.
Re: A10 oil pressure..how would you ever know? [Re: trevinoz] #590837
03/19/15 5:57 pm
03/19/15 5:57 pm
US
Z
zoe Offline OP
zoe  Offline OP
Z
US
It seems you wouldn't know your sludge trap was plugged, or partially plugged, unless you remove the sludge trap plugs and clean everything out. What does that have to do with being able to detect dangerously low oil pressure before you throw a rod? Am I missing something? All I want to know is how to try to prevent the situation of a thrown rod, or some other catastrophic failure, before it happens due to low oil pressure and/or a too worn timing side bushing.
Re: A10 oil pressure..how would you ever know? [Re: zoe] #590839
03/19/15 6:06 pm
03/19/15 6:06 pm
kommando Offline
kommando  Offline
You have no way of knowing but you can reduce the risk by futting a return line oil filter, unless you are doing big mileages that should be enough.
Re: A10 oil pressure..how would you ever know? [Re: kommando] #590851
03/19/15 7:14 pm
03/19/15 7:14 pm
Cork Ireland
chaterlea25 Offline
chaterlea25  Offline
Cork Ireland
Hi All,
The first sign of low pressure on the A7 /10's is tappet clearance increasing
This is due to the PRV not opening and feeding oil to the cam trough
leading to worn cams / followers
2c
Re: A10 oil pressure..how would you ever know? [Re: chaterlea25] #590859
03/19/15 8:01 pm
03/19/15 8:01 pm
US
Z
zoe Offline OP
zoe  Offline OP
Z
US
What prompted my original question is that someone on this forum suggested that .004" clearance on the timing side bushing meant it needed replacing which I don't doubt, i.e. if a narrow, hand cut ~ 3/32" wide, piece of .004" shim stock would slip between the crankshaft journal and the bushing the bushing needed to be replaced. My Haynes manual says .0015" is ideal when new and .002" is the wear limit.
So, I can just barely, only at some locations within crankshaft rotation, get my .004" shim stock to slip in but I have no problems with valve adjustment or anything else, i.e the engine runs great, has good power, no noticeable wear particles in the oil, etc.
I'm not enticed to replace the bushing but I also don't want a catastrophic failure.....what to do?
Re: A10 oil pressure..how would you ever know? [Re: zoe] #590865
03/19/15 9:04 pm
03/19/15 9:04 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Is the A10 OPRV the same as the A65 thread and diameter? I am making OPRVs with a -03 JIC port on a banjo that you will be able to connect to a pressure gauge.
If you can get a 0.004" shim between the crank and bush I would say it is well past worn. I know little about A10s except what is in Bacon's book but unless the pump is a lot greater capacity than an A65 the crank is probably looking to relieve itself of excess reciprocating weight soon. Power and running performance give little indication of connecting rod failure.
Re: A10 oil pressure..how would you ever know? [Re: DMadigan] #590928
03/20/15 11:11 am
03/20/15 11:11 am
Canada
LarryLebel Online content
LarryLebel  Online Content
Canada
Return flow in the oil tank indicates the oil pump is working ergo you have oil pressure.
Re: A10 oil pressure..how would you ever know? [Re: LarryLebel] #590937
03/20/15 11:42 am
03/20/15 11:42 am
US
Z
zoe Offline OP
zoe  Offline OP
Z
US
The oil pump is working well as I have good flow back into the tank but I think I'll have to go to the trouble of installing a new timing side bushing based on what I'm hearing on this forum. Better safe than sorry.
Re: A10 oil pressure..how would you ever know? [Re: zoe] #590941
03/20/15 12:12 pm
03/20/15 12:12 pm
kommando Offline
kommando  Offline
But if the OPRV is stuck open you have low oil pressure but as it dumps to the sump you will have good return. If the timing side bearing is shot again you get excess flow too early to the sump and good return to the oil tank. All good oil return flow shows is that oil is getting to the feed pump and then to the return pump, it tells you nothing about what is going on in between. To know the oil pressure you need a gauge.
Re: A10 oil pressure..how would you ever know? [Re: kommando] #590943
03/20/15 12:33 pm
03/20/15 12:33 pm
US
Z
zoe Offline OP
zoe  Offline OP
Z
US
Since it appears there is no way to check the pressure I'm left with no choice but to tear it down and install a new bushing with .0015" to .002" clearance and check and refresh everything else along the way. I like doing this stuff but it a a pain in the butt at the same time. Peace of mind is worth the effort as the risk of losing a case with the original factory case would be somewhat of a disaster value wise.
Re: A10 oil pressure..how would you ever know? [Re: zoe] #590946
03/20/15 12:43 pm
03/20/15 12:43 pm
Plus the thought of it going BANG! somewhere far from home, or at speed, or cranked over in a turn...
If you REALLY want to cover ALL the bases, years ago, I had a friend who's engine went BANG! because the flywheel broke in three!
Maybe have the crank and flywheel magnafluxed? Nitrided?
Re: A10 oil pressure..how would you ever know? [Re: zoe] #590953
03/20/15 1:22 pm
03/20/15 1:22 pm
Tridentman Offline
Tridentman  Offline
After initially riding a BSA Bantam (the normal first bike in UK in those days) in 1964 I bought a 1960 A7 Shooting Star. After about a month I was going about 70 mph down the local dual carriage way (the place to see "what'll it do") when there was a loud bang and no power.
I was lucky that the engine had not seized but the primary side rod had made a nice hole in the crankcases--about two inches by two inches.
With not a lot of mechanical knowledge at that time--and no real experience of motorcycle engineering--I had a real stroke of luck. The father of a friend of a friend heard about it and said "bring it around-we will have a look at it". Only turned out that he was an ex road racer--having raced in the immediate post war years against Geoff Duke etc. He taught me how to strip the motor. Then the next stroke of luck--he was then the superintendent of the light machine shop of a big local engineering company (employing about 12,000 people). So the crankcase half went into the trike bath for several days and was then welded up by a Lloyds accredited welder using what was then the new fangled Argon Arc process for welding aluminum.
We built the bike back up and it was as good as new until I sold it about 9 years later.
So--having seen the results of a thrown rod--Zoe--attend to the problem before it throws a rod--not afterwards.
And to my late mentor----R.I.P. John Thomas
Re: A10 oil pressure..how would you ever know? [Re: DMadigan] #590956
03/20/15 1:35 pm
03/20/15 1:35 pm
triton thrasher Offline
If you can lift the crankshaft 4 thou, I don't think your engine is safe to run.
Re: A10 oil pressure..how would you ever know? [Re: zoe] #590972
03/20/15 3:52 pm
03/20/15 3:52 pm
My point was that you can't monitor everything going on in your engine. To some extent you always have to rely on your ability (or the person your paying) to put the thing together right. Particularly on a road bike where you're usually operating well below the limits.
Trying to use oil pressure to diagnose whether or not .004" of radial clearance in the timing side bearing is ok is a whole 'nother bag of nuts. The simple answer is: the bearing is shot, time to tear it down. That will solve your oil pressure gauge installation problem.
Re: A10 oil pressure..how would you ever know? [Re: DMadigan] #590987
03/20/15 5:11 pm
03/20/15 5:11 pm
Sarpsborg, Norway
Jon Fredheim Offline
Sarpsborg, Norway
I am interested in your A65 PRV. My mate is just about to finish rebuilding his Spitfire MkIV and it would be really nice to monitor the oil pressure when starting it up.
Can you supply one? And send it to Norway?
Re: A10 oil pressure..how would you ever know? [Re: zoe] #591013
03/20/15 9:20 pm
03/20/15 9:20 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Jon, I have not got the pieces from the shop yet. Then I have to make a check on the relief pressure.
Re: A10 oil pressure..how would you ever know? [Re: zoe] #591036
03/20/15 11:49 pm
03/20/15 11:49 pm
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
I am not familiar with the A-10 OPRV. You can modify the A65 OPRV so you can use a test gauge. I used to do it so I could check my oil pressure at least annually ON MY a65. I had the same concerns as you, Zoe. I have now converted to a new pressure control system of my own design that permits a gauge to be installed. I have pictured it before on this site.
Re: A10 oil pressure..how would you ever know? [Re: Mr Mike] #591041
03/21/15 12:49 am
03/21/15 12:49 am
US
Z
zoe Offline OP
zoe  Offline OP
Z
US
Is the oiling system similar enough on the A10 to the A65 that I could install a fitting on the A10 OPRV cap to which a pressure gauge could be fitted?
I've now got my engine apart and will install a properly fitted timing side bushing anyway but I would like to be able to check the pressure in the future.
Re: A10 oil pressure..how would you ever know? [Re: zoe] #591153
03/21/15 5:07 pm
03/21/15 5:07 pm
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
Zoe,
An easy way to make a test setup is to find an early OPRV with the flat hex cap. Drill and tap for 1/8th NPT for a 90 degree fitting and a gauge. Temporarily plug the return port. Easy on A65 with 8-32 set screw, not sure on A10. You can also solder up the bypass holes on the A65 plunger. This will give a test port. Bear in mind you will have no pressure relief. The firt time I tried this I ruined a nice oil filled gauge when I pegged it on startup at. Warming oil first will help and you may only be able to run at idle if you have good oil pressure.
Re: A10 oil pressure..how would you ever know? [Re: zoe] #591234
03/22/15 8:12 am
03/22/15 8:12 am
Lucan ON Canada
jfligg Offline
jfligg  Offline
Lucan ON Canada
Hey Zoe
Did you remove your slud trap? If so what did you find? Jeff
Re: A10 oil pressure..how would you ever know? [Re: zoe] #591328
03/22/15 5:08 pm
03/22/15 5:08 pm
Auckland NZ
Ignoramus Offline
Ignoramus  Offline
Auckland NZ
same comment as Mr Mike above , only difference was I wrecked a manky old gauge so wasn't as pissed off. All I did was use an old A10 OPV and make a brass "collar\' to go inside to blank off the holes then just reduced the male thread down with all sorts of fittings till I had one a gauge would go on. With effectively no OPV it shot straight up to max (100psi gauge) ...I killed the motor straight away.
I just needed to see the pressure once to be happy and forget about it ...so far so good.
