Bruce Martin
Bruce Martin
New Brunswick, Canada.
17 registered members (BeezaBryan), 138 guests, and 419 spiders.
10416 Registered Users
btour 83
Rohan 78
Triless 77
reverb 74
Stuart 70
706,491 mail-order LSR
Topics68,280
Posts664,701
Members10,416
Emgo fuel tanks #589975
03/13/15 7:12 am
03/13/15 7:12 am
Running from demons in WNY
Hillbilly bike Offline OP
My recently finished 70 T120/750 just started seeping fuel after being filled with fuel for a week weeks. It's leaking at the rear above the mounting plate so the mount needs to be removed and so on.
The tank interior now looks nastier that before. No, I don't use E10 fuel.....I can do extensive metal repair but looking at options also...
Sealers are something I don't want to get into to due to all the complaints.
I see that several well known Triumph vendors sell the slimline replacement tanks. These are not the often complained about made in India tanks. They are Emgo brand probably made in Taiwan ? Not cheap at about 350 bucks...
Anyone have actual experience with Emgo tanks?
I ride dinosaurs that eat money
Re: Emgo fuel tanks [Re: Hillbilly bike] #590020
03/13/15 1:53 pm
03/13/15 1:53 pm
Christchurch NZ
R Moulding Online content
R Moulding  Online Content
Christchurch NZ
I have one on my Bonnie project. They have good and bad points.
On the plus side the front mounts are solid threaded plugs welded into the tank, as opposed to the hollow tubes notched and welded to the outside.
The filler necks are also not crimped in the same way as original. Although not sure quite how they are attached.
They are also made from a thicker gauge steels and plenty heavy!
Shape wise they are taller, longer and wider. This can cause problems with handlebar mounts and means that a specific chrome strip is supplied.
Emgo tank is on the far right.
The metal work and welds are all quite nice. The tanks seam to have been stamped rather than hammered and I used 4 coats of high build primer to straighten out the stretch marks. About the same as I use on an original Slimline.
Rod
So remember, when you're feeling very small and insecure,
How amazingly unlikely is your birth;
And pray that there's intelligent life somewhere out in space,
'Cause there's bugger all down here on Earth!
Re: Emgo fuel tanks [Re: R Moulding] #590034
03/13/15 3:32 pm
03/13/15 3:32 pm
Nice detailed report, thanks.......I decided to repair the leak on the existing tank ...
Re: Emgo fuel tanks [Re: Hillbilly bike] #590109
03/13/15 11:41 pm
03/13/15 11:41 pm
Santa Barbara, California
KC in S.B. Offline
KC in S.B.  Offline
Yep, I got one of the Emgo tanks when they were 1st announced, and it is a good tank. If the later ones hold true to this one, I'd certainly do it again. I few comments. Not surprisiing, but noted, ALL the edges and especially the bottom to side welded seams were sharp, and had bits of rod and BBs stuck in. A file and some time took care of it nicely. besides looks, Paint tends to run thin on a sharp edge. After a good cleaning with thinner or PrepSol, the entire surface needs to be sanded. The metal is very thick, and noticable heavier. There were nicks and scratches that need filler, but that goes with anything. The filler neck is great! It is welded full circle from the bottom, so much better than OEM crimped seam. Be aware that the OEM trim strim and possibly the badges won't fit. The tank is slightly longer (3/4"?), but more of an issue is it is TALLER. you will find that out after you try to mount the tank and turn the bars lock to lock. If I had known better, I would have compensated for that before paint. The only way I could get it on and clear the bars, was to eliminate the top rubber in the front mounts. Kind of hokey, but no other choice. With a bare tank, I was sure you could trim some metal off of the forward tank mounts. As mentioned, they are solid steel "pegs" and have more material than OEM, and I looked at that option. It was likely possible to get enough clearance that way,.... but not when painted. The top clamp pinch bolt is the problem area. The rear mount tab is welded like Triumph should have done them, all around. After looking at the replacement badges, I did end up using the OEMs this time. The replacements needed paint, but are good quality. Again, make that choice before paint, as you might find yourself wanting to smack them once to get the fit right. Over all, it is a good tank in my opinion.
Oops,.. add 1 Sporty
