Buckshot1
Buckshot1
Diamond Springs, Kalifornia
38 registered members (Al Eckstadt), 334 guests, and 363 spiders.
10419 Registered Users
btour 88
reverb 75
Triless 75
711,216 mail-order LSR
Topics68,310
Posts665,061
Members10,419
Which Roadholder forks? #58983
01/16/08 11:15 am
01/16/08 11:15 am
London
Jake Offline OP
Jake  Offline OP
London
Hullo All,
I am rebuilding a set of Roadholders which are on my T110 / Slimline Featherbed Triton. As far as I can see they are unmarked. They have internal springs, not the exposed ones that I see in many photos. How do I tell which set of forks I have (long or short?) and how much oil do I fill them with? What is the preferred oil for these forks?
Many thanks,
Jake
Re: Which Roadholder forks? #58984
01/17/08 2:45 am
01/17/08 2:45 am
georgia
trumpetloon Offline
trumpetloon  Offline
georgia
Remove the springs, collapse the forks and set oil level at 6 inches from top of tube. Start with 20 weight fork oil from Silkolene or whatever your local shop carries. These are starting values only. If too stiff first remove 1/2 inch of oil, no more than 1 inch to soften. Or try 15 weight at full value. Use reverse for soft but do not increase oil level more than 1/2 inch to avoid hydraulic lock and seal blow out. Hope this helps.
1974 TR5T
Re: Which Roadholder forks? #58985
02/04/08 1:01 pm
02/04/08 1:01 pm
London
Jake Offline OP
Jake  Offline OP
London
Many thanks for the information. I took the forks apart last night to find that one spring was 3 inches longer than the other! New fork springs required... What do I buy? Are there progressive springs for these forks? And how do I tell which forks I have? Long or short Roadholders?
Many thanks
Re: Which Roadholder forks? #58986
02/04/08 1:13 pm
02/04/08 1:13 pm
London
Jake Offline OP
Jake  Offline OP
London
Re: Which Roadholder forks? #58987
02/04/08 5:43 pm
02/04/08 5:43 pm
bromley uk
norton bob Offline
norton bob  Offline
bromley uk
Look like standard dommy,Think about fitting Hemmings damper extenders,covenant type alterations etc while in bits,check length of staunchions.
Re: Which Roadholder forks? #58988
02/04/08 9:31 pm
02/04/08 9:31 pm
australia
dogsrocket Offline
dogsrocket  Offline
australia
Look like short roadholders to me (same as on my triton see photo triton cafe forum)external springs fit into those chrome cups & up against triple tree.
Length of my forks from stanction top nut to centre of axle 720mm when assembled with springs in.
Re: Which Roadholder forks? #58989
02/04/08 10:07 pm
02/04/08 10:07 pm
Winona, MN
Swan Offline
Swan  Offline
Winona, MN
They look like short roadholders. Unity Equip have external springs and and holders.
I trust you are not going to use that vice grip and crescent wrench on your bike. Nothing trashes bolts faster than the wrong tools. Buy a set of proper wrenches (spanners) and sockets.
1966 Triton
1962 BSA DBD34 Gold Star
1966 Triumph Bonneville
Re: Which Roadholder forks? #58990
02/05/08 10:19 pm
02/05/08 10:19 pm
London
Jake Offline OP
Jake  Offline OP
London
Thanks all for the information. My original question was 'which forks do I have?' - the answer, based on stanchion length is here:
http://www.nortonownersclub.org/
-->Technical
-->Dominator (small tab at bottom of page)
If others need to identify unmarked Roadholder forks you can measure the stanchions and match them to the information.
Swan - I appreciate your advice about the wrong tools. I have a set of 'wrenches' but didn't want to take them out of the wrapping as they seemed so shiney and nice. You advise against using a 'crescent wrench', which one is the crescent wrench? The long, spring-shaped thing? When I took my'wrenches' out of their wrapping one end was bigger than the other - which end do I use? I do value your experience.
Re: Which Roadholder forks? #58991
02/09/08 6:47 am
02/09/08 6:47 am
Pasadena, California, USA
E
Eric Eccleston Offline
E
Nothing wrong with shifters!!!
'69 Velocette Venom Clubman
'57 Norton 19S
'56 BMW R69
Re: Which Roadholder forks? #58992
02/12/08 10:36 pm
02/12/08 10:36 pm
London
Jake Offline OP
Jake  Offline OP
London
"Nothing wrong with shifters!!!"
Eric - I agree. But I also agree with Swan, the right tool for the right job is important. I posted my snarky reply when drunk and now regret it. Swan's comment was well-intentioned but I felt I was being preached at. I may not know the length of my stanchions but I know how to use a spanner. The shifting spanner was in the photo because I had used it to hold a stubborn spacer in the forks. Moral: drink less beer before posting. Sorry Swan.
Re: Which Roadholder forks? #58993
05/26/08 2:08 pm
05/26/08 2:08 pm
Concord Township, Ohio
57nortonmodel77 Offline
Jake,
Your forks are definatly short roadholders. The fork tube (stansion) length is one way to tell (although they can be made to any length you want ie: choppers )but several sure fire ways to know just by looking are
1) long roadholders use external springs, short use internal springs
2) at the top of the fork end (slider)the long roadholder uses 2 small screws to hold the bottom cover directly to the slider, the short use a main tube lock ring that is threadred into the slider , then the bottom cover threads onto the main tube lock ring. The lock ring is chrome plated and has a series of holes on its diameter to accept a pin-spanner.
Now you can tell from a mile away you definatly have a set of short roadholders!You can get any part for the shorts (Norvil is who I use), the long roadholders are very difficult to get parts for.Eric & I know this all too well as he is restoring a 19s & I am restoring a model 77 which both use the long roadholders!
Skip Brolund
sbrolund@yahoo.com
Magneto & Dynamo restorations & supplies
My Bikes
1948 Norton 500T Trials bike
1950 Norton Model 7
1952 Norton ES2
1957 Norton Model 77
1960 Norton Nomad 600cc Desert sled
1961 Norton ES2 (slimline)
1964 Norton Atlas Scrambler
1972 Bultaco Alpina
