Transgarp
Transgarp
Quebec, Canada
189 registered members (1xfatboy), 2,125 guests, and 550 spiders.
koan58 90
Lannis 84
505,385 mail-order LSR
Topics66,055
Posts639,346
Exhaust Valve Lifter #586850
02/22/15 10:59 am
02/22/15 10:59 am
Lancashire. England.
resingled Offline OP
Sorry. Managed to find the rest of the instructions. Incidently, the cam is central to the rocker when the rocker is pushed to it. Regards. Dave.
Re: Exhaust Valve Lifter [Re: resingled] #586877
02/22/15 1:00 pm
02/22/15 1:00 pm
Middle East,
Kerry W Offline
Kerry W  Offline
Middle East,
Remember the split-pin on the end of the lifter shaft..
Oliver Wendell Holmes
Re: Exhaust Valve Lifter [Re: resingled] #586879
02/22/15 1:06 pm
02/22/15 1:06 pm
Middle East,
Kerry W Offline
Kerry W  Offline
Middle East,
...after looking at your other post...the parts should be fine. Do a dry assembly, and rotate the lifter shaft to put the lifter cam against the rocker and then position the lever. The usual manuals' instructions are very vague about clearances, etc. I set mine up to have just a little clearance from the rocker when pushed back by the spring in the lifter cable end. As you say, lifting the valve only a fraction will allow the release of the compression.
WARNING: do note the part off the manuals that says not to operate the lifter at high RPM. The consequences are not spelled out, though I can say with some authority that the exhaust lifter cam will ride past the rocker. The lifter will then be slack. If the lifter arm was then to be repositioned on the shaft in an effort to get the lifter working again, all you will get is a lifter than is immovable, as it is trying to 'lift' the inside of the rocker box..
Re: Exhaust Valve Lifter [Re: resingled] #586884
02/22/15 1:33 pm
02/22/15 1:33 pm
When I look at the end of the rocker in your photos I am of the opinion that the previous owner may have taken too much off the contact pad. The lifter cam might be just swinging past the rocker without touching it.
Here are a couple of examples, BB GS on left and BB31 on right.
Re: Exhaust Valve Lifter [Re: resingled] #587019
02/23/15 7:11 am
02/23/15 7:11 am
Thanks for all your input. Yes Kerry. The split pin has been in and out so many times it is now in the bin. I will remember to put one in though. I have done a dry assembly several times and with the exhaust valve loose in the guide and pressed against the seat I can rotate the lifter cam completely past the rocker arm. I think that the photo from Gordo says it all. Both rockers in his example have much more depth than the ones in mine. So it seems I need an exhaust rocker if I want to use the valve lifter - which I do. Now the engine is not stamped GS. It has BB32A crankcases but, going off the numbers stamped on the castings and measurements, the crank assembly, piston, head, and perhaps the rocker box are BB34. To me the rocker boxes may be identical on the 350's and 500's. I don't know but I'm sure someone out there does. After all that, any ideas where I can find an unmolested rocker arm to put in my mongrel engine? Thanks again. Dave.
Re: Exhaust Valve Lifter [Re: resingled] #587100
02/23/15 7:58 pm
02/23/15 7:58 pm
Dave: I think the early rockerboxes are all the same 350 and 500. I am trying to figure out what you have for an engine. The BB32A or BB32 GS cases for that matter are the same as the B31/33 with the small drive side roller bearing, smaller drive side shaft and the lack of steel support plate. I am guessing you have a BB34A crank with a 500 barrel and head.
One solution for your lifter problem would be to get a B31/33 rocker and have it lightened to match the GS version. Below is one of the B31/33 rockers I had turned down. My machinist was surprised how hard it was to grind them down. The only thing to look for would be the passageway to oil the top of the pushrod. The early rockers did not have this feature.
The oil hole is shown below
Re: Exhaust Valve Lifter [Re: resingled] #587475
02/26/15 1:56 pm
02/26/15 1:56 pm
Thanks for the photos Gordo. They illustrate the difference between my skinny rocker arms and the originals. I believe you are correct that I have BB32A crankcases with a crank, barrel and head from a BB34. I suspect the rocker boxes are all the same apart from engines which have eccentric rocker spindles. Hopefully some pictures will appear below to confirm my (our) thoughts about the make up of this engine. Fingers crossed. I've not mastered this yet. Ha.
Re: Exhaust Valve Lifter [Re: resingled] #588864
03/06/15 12:15 pm
03/06/15 12:15 pm
Just an update on the rockers, new and old. Someone has obviously spent a lot of effort on the original(assuming it started life as the new one). It seems a shame to take it out. However, I will settle for a valve lifter that works.
Page Time: 0.171s Queries: 15 (0.005s) Memory: 1.0493 MB (Peak: 1.2185 MB) Zlib disabled. Server Time: 2018-02-24 22:16:15 UTC
