441DailyRide
441DailyRide
BrisVegas, Oz
194 registered members (737Captain), 2,258 guests, and 595 spiders.
koan58 90
Lannis 88
NickL 86
Stuart 57
505,967 mail-order LSR
Topics66,066
Posts639,453
Ethanol laced gas and Amal floats #584263
02/05/15 9:05 pm
02/05/15 9:05 pm
Cape Carteret, NC
Mr Mike Offline OP
Mr Mike  Offline OP
Cape Carteret, NC
I was out starting my Lightning yesterday and while it started OK, it ran real crappy. Pretty easy to diagnose as the left side was very rich. Upon disassembly of the carb I found the AMAL float (a white one) was half full of fuel. I swapped it out and the bike ran good. This is the third float that has leaked in one of my bikes in the past 8-10 years.....all on different bikes. Is this an ethanol gas thing or just lousy AMAL floats? Do I need to go to the newer black floats at about $18 a pop.
Re: Ethanol laced gas and Amal floats [Re: Mr Mike] #584266
02/05/15 9:30 pm
02/05/15 9:30 pm
Edgewater, Md
Blown Income Online content
Blown Income  Online Content
Edgewater, Md
Upgrading to a stay up float would be best. I have yet to do this on any of mine but I am using the original AMAL floats and I also turn the petcocks off and let the bike run itself out of fuel.
1955 BSA Bantam D1 Plunger
1961 BSA C15S
1966 BSA spitfire
1969 Triumph T100C
1970 Triumph TR6R
1972 BSA Lightning LSR Bike
1974 Triumph T150V
Re: Ethanol laced gas and Amal floats [Re: Blown Income] #584269
02/05/15 9:40 pm
02/05/15 9:40 pm
US
Z
zoe Offline
zoe  Offline
Z
US
I was told to run ethanol free fuel whenever possible so I do and I have had no float problems running black AMAL floats.
Re: Ethanol laced gas and Amal floats [Re: Mr Mike] #584335
02/06/15 2:53 pm
02/06/15 2:53 pm
Magnolia, TX
htown Online content
htown  Online Content
Magnolia, TX
Good luck finding ethanol free gas in most areas. I have stay-up floats in the three Brit bikes I currently have on the road. They are also easier to adjust the fuel level.
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
2-1974 Norton Commandos
2004 XL 1200R Sportster
Re: Ethanol laced gas and Amal floats [Re: Mr Mike] #584346
02/06/15 3:37 pm
02/06/15 3:37 pm
Tridentman Online content
Tridentman  Online Content
The "stay up" float is not hollow like the yellow ones. It is a "closed cell foam" where there are lots of air bubbles not connected together. It was developed in UK for the British Army so that nasty fuels (like ethanol) could not make the float sink.
Not too sure what the effect is of ethanol on the yellow plastic floats but there have been reports of the ethanol affecting them adversely.
Good policy to fit the stay up floats IMHO.
As for being easier to adjust the fuel level--this can be true but our moderator (JH) believes that this affects the sensitivity of the float and therefore the level operation--for reasons which make sense to me.
Re: Ethanol laced gas and Amal floats [Re: Mr Mike] #584398
02/07/15 3:03 am
02/07/15 3:03 am
Allan Gill Online happy
Allan Gill  Online Happy
I have to agree with JH's beliefs on the sensitivity of these floats.
With the work I have done in my own bike it will run very rich if you don't control it correctly, when last ran it was running a lot richer on the left pot, however the float heights were set the same with the stayup float ( note that unlike the older float bowls the brass seat us now non adjustable in the newer units). As an experiment I have swapped around the float bowls and floats to the other carb (being twin carb) to see if the richness changes sides ( proving the float hight causing richness and not difference in port size). As a last resort I will switch to the White plastic floats which are yet to cause me a problem.
Re: Ethanol laced gas and Amal floats [Re: Mr Mike] #584461
02/07/15 5:23 pm
02/07/15 5:23 pm
Magnolia, TX
Magnolia, TX
I set mine using the u-tube method. AMAL recommends a fuel level of .17 to .24 below the top of the float bowl. I found that my bike runs best and has best plug color(not that reliable with today's gas) at the bottom number or just a hair below. Towards the .17 side was too rich. You need to experiment a little to find each bikes comfort zone.
1974 Trident
Re: Ethanol laced gas and Amal floats [Re: Mr Mike] #584499
02/07/15 9:50 pm
02/07/15 9:50 pm
Irish Swede Online content
Irish Swede  Online Content
Although the word "Concentric" is not used in any of the above posts, I assume they have the float problem being discussed here.
If you are working with MONOBLOCS, please note that the early ones had BRASS floats, and these do turn up at swap meets.
I have yet to see any gas or ethanol that will dissolve BRASS.
Re: Ethanol laced gas and Amal floats [Re: Mr Mike] #584518
02/08/15 1:05 am
02/08/15 1:05 am
Bowral NSW Australia
John Goodwin Online content
John Goodwin  Online Content
I have a real concern about the fuels we have to buy these days as I patiently wait for at least one of my Spitfires to turn up. Both of which in original trim have glass tanks.
I've done many searches to try and find out if any of the fuels here in Australia are ethanol free, but cannot find any definitive information about ethanol contents other than our E10 fuels here.
The only article I could find of any help was this one
http://www.roadrider.com.au/gear-reviews/the-fuel-truth
Sadly it doesn't seem overly encouraging about the use of Shell V Power which was until now going to be the fuel of my choice.
Even worse is the viability of storing modern fuels, from what I read, 4-8 weeks is about it which isn't a long time to store fuels.
Guess it beats no fuel at all
Re: Ethanol laced gas and Amal floats [Re: htown] #584573
02/08/15 11:34 am
02/08/15 11:34 am
Cape Carteret, NC
Mr Mike Offline OP
Mr Mike  Offline OP
Cape Carteret, NC
Originally Posted By htown
I set mine using the u-tube method. Amal recommends a fuel level of .17 to .24 below the top of the float bowl. I found that my bike runs best and has best plug color(not that reliable with today's gas) at the bottom number or just a hair below. Towards the .17 side was too rich. You need to experiment a little to find each bikes comfort zone.
I did some rather extensive utube testing last year on fuel level. I learned that setting fuel height within fractions of an inch or a few thousandths is likely unnecessary. If you get the level too high the carb will inadvertengly flood due to vibration and/or pther things depending on whether the bike is actually level when riding. It seems relatively unaffected by setting it too low. I also concluded that the black floats with the adjustable tangs are probably what AMAL should have used all along. Most carbs have a float with an adjustable tang. To adjust float height by moving a pressed in needle seat was likely not intended to be an adjustment. I have found that you can get excellent performance by adjusting the things that are meant to be changed or adjusted...ie needles, needle position, needle jet, main jet, pilot jet and slide. And with the black floats you have a simple easy float height adjustment. The AMAL Concentric is a very cheap to manufacture carb with a lot of flexibility. With judicious tuning they can be made to work very well on a variety of applications.
Re: Ethanol laced gas and Amal floats [Re: Mr Mike] #584574
02/08/15 11:37 am
02/08/15 11:37 am
Never had any issues with v power in the UK. The "yellow" which is mentioned in this article I have yet to find in any UK fuels, however I have found most fuels when used on the continent do have this yellow ness to them. The result is usually stained on the crankcases following flooding of the Carburetor
Re: Ethanol laced gas and Amal floats [Re: htown] #584579
02/08/15 11:53 am
02/08/15 11:53 am
Mr Mike, how do you explain setting the float height when the carbs were originally distributed with plastic unbendable floats.
Bout time I made a rig to set my float heights, have you tried the effects on float height with different fuel head hight or weight?
Re: Ethanol laced gas and Amal floats [Re: Mr Mike] #584649
02/08/15 10:40 pm
02/08/15 10:40 pm
Cape Carteret, NC
Mr Mike Offline OP
Mr Mike  Offline OP
Cape Carteret, NC
Hey Alan,
I think that fuel level height was something that AMAL chose not to have an adjustment for. If the float, seat, and needle are all within specs, they should deliver a fairly uniform fuel height. You never see that seat adjustment in the AMAL guides, but tuners figured out you could change the fuel height by moving the needle seat. In general the fuel level will vary depending on the depth of the needle seat, the length of the needle and the tab on the float. I measured a number of bowls and found the seats are very close to the same heights when the shoulder is on the casting . The needle lengths I measured were all within a couple of thousandths. The white floats did vary some. Some had what JH has referred to as a "drooping tab" (defect). These made a very measurable difference in fuel height(lower)because I had one. If you get the fuel height too high using a black float the float can foul on the top of the body and not shut off. I set my height at about 5/16ths to 3/8ths below the joint surface so I was sure it would not foul the float and stay open. When I tried to set it at the higher end of the .017-.024" range, it was very close to fouling the float on the top of the carb. The bike started well and ran well. Spark plugs were clean at both idle and at cruising. The black floats are similar to brass floats used on many carbs. The adjustable tang has been around since very early carburettors. I am NOT saying that fuel level does not make any difference. It does, but it is not huge, and with all the adjustments (slide, needle position, needle jet, mail jet, pilot jet) available on a simple AMAL it is easy to correct the mixture for smooth running.
I'm sure others will disagree with me on the importance of fuel height but I have always been able to adjust a carb to deliver the right mixture...well except for my first bike. At that time I didn't know there were different jets, slides and needles. I had a 250 that would foul the plug in 100 miles. I shimmed up the needle jet with a washer to lean it out. It worked and then someone told me about the notches and clip in the needle. Back then I didn't have a manual or anything else but did whatever it took to have a ride. I am sure that there were others that didn't know "jack" about their rides as youngsters.
Re: Ethanol laced gas and Amal floats [Re: Mr Mike] #588325
03/03/15 3:34 pm
03/03/15 3:34 pm
Atlanta, GA USA
Semper Gumby Offline
Atlanta, GA USA
Found my Firebird was idling on the LH carb only because the fuel level was too low in the RH carb (8mm) had to tap the seat down to get the fuel level up to 6mm. Idles on both carbs now.
I put a brass tube into a float bowl drain and attached some clear plastic tubing to make a fuel level tool. Works nice - easy to make.
Gaggle of BSAs
a Honda
an old BMW
and a Montesa
Parking lot Elf in training
Re: Ethanol laced gas and Amal floats [Re: Mr Mike] #588437
03/04/15 10:11 am
03/04/15 10:11 am
NH
GreenMonster Offline
NH
Mr. Mike :
Been a long time since we have chatted, how have you been?
Well figured I would lend a little advice hear. I also own a Kawasaki Concours and one of the things, that we do to help alleviate the issues caused by alcohol is we dope our fuel with TCW3 spec 2 stroke oil mainly Pennzoil.
It works wonders to prevent sticking, corrosion and helps add some lubricity.
It won't prevent the fuel from attacking the old float's so a newer float will be needed.
I have run Marvel Mystery Oil in my fuel for years also but, it does not have the lubricity that the TCW3 has.
General rule of thumb is 1 oz per 4 gallons for the TCW3 and 2 oz's for the Marvel.
Never Allow The Radical Views Of The Few To Infringe On The Constitutional Rights Of The Many
Page Time: 0.204s Queries: 15 (0.009s) Memory: 1.1149 MB (Peak: 1.3631 MB) Zlib disabled. Server Time: 2018-02-25 21:39:25 UTC
