Bruce Martin
Bruce Martin
New Brunswick, Canada.
23 registered members (BeezaBryan), 140 guests, and 413 spiders.
10416 Registered Users
btour 83
Rohan 78
Triless 77
reverb 74
Stuart 70
706,491 mail-order LSR
Topics68,280
Posts664,701
Members10,416
H-4 headlamp bulbs #58569
12/20/07 1:40 am
12/20/07 1:40 am
Florida
F
Florida TR6 Offline OP
F
Florida
Have had to replace 3 H-4 headlamp bulbs in the past five months. The first and second were NAPA brand, the third was a Phillips (lasted two weeks). None were discolored and appeared fine at first glance. But tonight I turned the last bulb upside down and noticed a tiny spring fragment slide up from the bottom, suggesting vibration has been the culprit. Any particular brand of bulb that works well on a Brit bike? Any other suggestions or solutions? Thanks.
"For every problem, there is a solution that is simple, neat, and wrong." H.L.MENCKEN
'06 T100 Bonneville
'70 TR6 Bitsa, Pazon EI
Re: H-4 headlamp bulbs #58570
12/20/07 1:59 am
12/20/07 1:59 am
Tolland, CT, USA
sparklow Offline
sparklow  Offline
Tolland, CT, USA
This may help but I'm not sure. I have bought a couple (to have a spare) H4s from Mike's XS for my Bonneville. The XS Yamas are vibrators too, so I figured that I would take a chance on these parts. So far these H4s, which are reasonably priced, are standing up to the "good vibrations" of my T140.
'78 T140E
'79 XS650
Re: H-4 headlamp bulbs #58571
12/20/07 11:20 am
12/20/07 11:20 am
Asheville, NC
Mike Baker Offline
Mike Baker  Offline
Asheville, NC
Hi FL
I've had pretty good luck with NAPA H4 bulbs. But I've always asked for motorcycle bulbs. A heavier filament, I suppose? They do finally succumb to the vibes, but I can usually get a season out of them.
Mike
Re: H-4 headlamp bulbs #58572
12/20/07 1:22 pm
12/20/07 1:22 pm
Florida
F
F
Florida
Perfect suggestion that I hadn't even considered. Silly me. Thanks.
'06 T100 Bonneville
Re: H-4 headlamp bulbs #58573
12/20/07 2:27 pm
12/20/07 2:27 pm
Rich B Offline
Rich B  Offline
They are not cheap, but I have a PIAA bulb on my daily ride (68 Lightning) that is at least 3 years old. I was getting 1 year (barely) out of a bulb before that. So, IME, it is worth the extra money.
Re: H-4 headlamp bulbs #58574
12/20/07 3:31 pm
12/20/07 3:31 pm
melbourne florida
bodine031 Offline
bodine031  Offline
melbourne florida
tr6 try this:: 67697-81 or 67074-02 HD part #s the -02 is a xenon gas briter but same current draw as the -81 been using these in the old brit jalopy's for years with good results 18&21$$$$ at your local dealer
Re: H-4 headlamp bulbs #58575
12/20/07 5:42 pm
12/20/07 5:42 pm
Florida
F
F
Florida
Thanks very much guys. RICH, found PIAA on the web but they seem to be available only in 55/60 watts. Was very impressed that they put out far more light than the wattage indicates. I do have a new alternator/Tympanium but was still worried about excessive current draw as per posts on the Triumph forum. $53 for a twin-pack (ouch) plus shipping does seem expensive, but they may well be worth the price (and then some) given the bulbs I'm blowing, plus a $51 Christmas present from a state trooper.
For now I'm gonna try to locally get one of bulbs suggested by Bodine-- thanks a lot for the part numbers-- big help. Thanks again to both of you and Merry Christmas.
'06 T100 Bonneville
Re: H-4 headlamp bulbs #58576
12/20/07 6:06 pm
12/20/07 6:06 pm
Florida
F
F
Florida
How stupid. Got out the magnifier and read the very tiny print on the burned out bulbs: each was 60/55 watts. No alternator issue using them.
'06 T100 Bonneville
Re: H-4 headlamp bulbs #58577
12/20/07 6:08 pm
12/20/07 6:08 pm
gastonia nc
raf940 Offline
raf940  Offline
gastonia nc
hi..you can get 35 watt H4s from Bike Bandit..i'ved had one in my bonneville for over 18 months with no problem..also..if your bike can handle it look on eBay for xenon/krypton motorcycle headlights.there's a company...i forget the name ...that sells them especially for bikes and snowmobiles..they are around $13 for two...they are bright,,i put one in my Honda Aero and you can tell people see you coming..a really intense blue/white light 55 watts i think
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando
Re: H-4 headlamp bulbs #58578
12/20/07 8:30 pm
12/20/07 8:30 pm
FLTR6,
I run a 55/60 on a stock alterator with no problem unless I sit in traffic idling for more than 5 minutes. Current bulb is 2-1/2 years old and it survived a wreck. Could it be that either your headlight socket, reflector or headlamp are loose, causing the bulb to rattle around? Most H4 reflectors don't seem to fit in the headlight rim very tightly (often, they rotate around on their own. I slice a 3/4" wide ring from an old inner tube and stretch it around the reflector, which keeps it from rotating and rattling around.
Re: H-4 headlamp bulbs #58579
12/21/07 12:10 pm
12/21/07 12:10 pm
hampshire, england
t120mike Offline
t120mike  Offline
hampshire, england
I used to get only 300 miles out of my "dip" filament on H4 becuase I ride with the dipped headlight on in daylight. I then found a HEAVY DUTY H4 designed for off-road car use. It was great and it gave at least 10 times the mileage. But then they seemed to stop doing them but they were available wholesale. So I bought 200 quids worth (minimum order quantity) which was about 80 bulbs. That should see me out! I might be in the market but postage and packing would be an issue as well as warranty as they are now about 5 years old!
mike
Member #: 147
1960 T120 Bonneville
1999 H*%^a VFR 800 FI
V4 Triton Project (still keeping me sane (Ha-Ha!))
Re: H-4 headlamp bulbs #58580
12/21/07 12:32 pm
12/21/07 12:32 pm
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
I read on a manufacturers [I think] site one time that halogen globes do not like low supply voltage, that would seem another good reason to look into Richard Whatley's grounding mods.
1969 TR6R
Re: H-4 headlamp bulbs #58581
12/21/07 2:12 pm
12/21/07 2:12 pm
Florida
F
F
Florida
Alex: Neat idea-- am off to bicycle store to get an old intertube. I'm put thin rubber grommets (Ace Hardware) on either side of the bolts on the headlight ears, hopefully to further reduce vibration. But if it is a low voltage problem (Tiger), I've got more work to do. Yesterday, I carefully bubble wrapped a spare H-4 and put it inside the headlight shell, just in case. The young bull-necked State Trooper who on Monday wrote me a daylight no-headlight ticket initially treated me as if I was an escaped convict, then after writing and handing me the ticket, told me he admired "what you old guys do with these old bikes" and then told several stories about riding on the back of his dad's old Triumph. He even shook my hand before he left. For a moment there I was kinda thinking he might tear up the ticket-- yeah, right, when pigs fly.
'06 T100 Bonneville
Re: H-4 headlamp bulbs #58582
12/21/07 2:52 pm
12/21/07 2:52 pm
Halifax, Butt end of Europe
andrewinpopayan Offline
Florida TR6, I run a 30/35 halogen headlight bulb, but also inside the bowl and permanantly "on with ignition" is a 22 w indicator bulb for a modern Italian scooter.
They come in the small bayonet fitting (1/4") Lucas liked so much. Even if the H4 bulb pops off, you will still have the 22w "pilot" shining away. Out of interest how much did your traffic ticket cost you?
The little snotty nosed British police end to shy away from Britbikes because they are older than THEY are and don't like appearing "dumb", very rare to be bothered by the "bizzies"
99% of carb problems are electrical.
1959 3TA
BMW R1150 Oilhead
Re: H-4 headlamp bulbs #58583
12/21/07 3:39 pm
12/21/07 3:39 pm
Florida
F
F
Florida
Andrew: $51 plus two points on FL driving record if not verified as fixed within 30 days. Headlights are mandatory on motorcycles day and night in FL. Lucky you re: attitude of police... the local cops (Sherrif's Dept.) here seem to be O.K. and will cut some slack to motorcyclists. But at least some State Troopers (Highway Patrol-- but patrol on 2-lane roads down here) go strictly by the book -- last month a couple fellow riders (both on Harleys) got nailed in separate incidents by troopers -- one for running open pipes, the other for 41 in a 35 mph zone. That's getting a bit picky.
'06 T100 Bonneville
Re: H-4 headlamp bulbs #58584
12/21/07 9:21 pm
12/21/07 9:21 pm
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
Recently got a deal on 10 off Phillips "Vision Plus" 55/60 H4 with an LED flashlight for $AU80.00 at our auto elec wholesaler, you walk into a "Shell Shop" here and the buggers get into you for $22.00 for one lower quality globe mad
Front wheel out of balance can also shake globes to death.
Andrew, you really have to get sensitive and realise that all those Gyppos actually own your stuff, the govt is just letting you use it at the moment.
I may suggest that a "Five Year Plan" be instigated to alleviate balance of trade issues by digging up the playing fields of Eton to plant various smelly things that Gyppos like to eat.
Sport is competitive and therefore discriminatory in any case.
1969 TR6R
Re: H-4 headlamp bulbs #58585
12/22/07 9:39 am
12/22/07 9:39 am
Hey, the globes that I sell in MY Shell shop are guaranteed to get you off the forecourt at like 7 each. I just get loads of "freebies" when I visit car breaker yards, although I did BUY (yup, with real money) the 30/35w thats in there now eek
1959 3TA
BMW R1150 Oilhead
Re: H-4 headlamp bulbs #58586
12/22/07 9:54 pm
12/22/07 9:54 pm
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
Just found the failure diagnosis section in a Phillips brochure, low voltage failure with a halogen is indicated by blackened glass, air leak is white/yellow frosting.
If yours are showing neither I reckon failures are down to vibration.
Phillips apparently do a vibe/shock resistant globe, signified by a red dot on side of base and "HD" in the part number.
1969 TR6R
Re: H-4 headlamp bulbs #58588
12/23/07 10:28 am
12/23/07 10:28 am
beltdriveman Offline
Have never had an H4 bulb fail in any car or bike I used them in..(olde British ES2 and Norton twins many years ago). HOWEVER I do wire my bikes myself and there is always an 1/4" or similat bolt in the headlamp shell forming a main earth point which is actually making electrical contact with the shell and which is connected to the main earth bolt on the frame(Also actually making electrical contact with the frame, the battary being connrcted to the earth point with a lump of 40 x 0.0076 via a lump of say 70 x 0.0076" or similar (Or whatever todays equiv is) Plus I use small car type relays to switch the power to the headlights so the switches only carry the power to switch the relays plus there is mounted within the headlamp shell a flexible choc block that is coupled direct to the battary via a nice big lump of amp carrying wire(with all connectors on one side coupled together thus giving me lots of connection points for the switches for indicators horn ignition etc ) so that there is no voilt drop to speak of between the battary and the relays supplying the main beams and thus the main bulb.(and horn etc).
Of course I do remember the comment contained within a 1980 thesis conducted to determine the suitability of a belt for primary drive using a T140 in which it was stated that whilst it was not part of any conclusions or testing it was interesting to note that during the period of testing no bulbs had failed!!!(the testing had shown a reduction in vibes at all revs using a belt).
I thus suspect its a case of vibes and crappy earth returns... the crappy earth returns being something not just limited to motorcycles in my experience!! 'But that radar above deck section is bolted to the main deck'......'Yes and its seperated by gunge to stop water ingressand dissimilar metal corrosion in the joint and the bolts are all sitting on very well anti sea water painted metal plus each bolt was coated in duralac before being fitted'.'Oh so we are going to have to install an earth return' And thus another expensive modification is borne, paid for by the tax payer. Of course had the company not sacked/severenced all the olde farts who knew about silly little things like how important earth returns are instead of employed bright young tigers straight out of Uni who knew less than bugger all about such things having not been through the learning curve that leads to becoming an olde fart......
Re: H-4 headlamp bulbs #58589
12/23/07 12:40 pm
12/23/07 12:40 pm
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
Old Tigers know better bigt
The young ones build Frigate superstructures from ally and don't they burn well when struck by a missile ?
1969 TR6R
Re: H-4 headlamp bulbs #58590
12/23/07 1:19 pm
12/23/07 1:19 pm
Melbourne Fl
Terry_tr6 Offline
Terry_tr6  Offline
Melbourne Fl
TR, i don't know what hedlight shell you have, but my tr6c has the little one, and i long ago swapped the Lucas internals out and just use the small dual beam sealed beam halogen headlight. Originally back in the 70's it was just so i could buy a new bulb anywhere along the Melbourne to Miami weekend run. i find the halogen sealed beams last almost forever for me. May be coincidence, but bulbs started lasting longer when i took off the turn signals that hung off the headlight. maybe that reduced the vibrations
