kyrbz
kyrbz
Midwest, United States
204 registered members (650thrasher), 2,160 guests, and 551 spiders.
Jerry Dahlinger, RoyalSpares.com, GabrielSoren, JoshP, spikey45
10079 Registered Users
koan58 85
NickL 84
Lannis 81
Stuart 60
504,540 mail-order LSR
Topics66,038
Posts639,210
Members10,079
Por-15 chassis black #58368
12/07/07 4:06 am
12/07/07 4:06 am
Billings, MT
Brendan Shannon Offline OP
Billings, MT
Has anyone used the por15 gloss black chassis paint? (Not the stuff made to apply over rust; they have a topcoat designed for car chassis that is supposedly tougher than the average auto paint. I'm thinking of using it for frame and other black parts.
Brendan
67 Triumph T100R
68 Norton Commando
71 BSA B50MX basket
Re: Por-15 chassis black #58369
12/07/07 5:21 am
12/07/07 5:21 am
Jon W. Whitley Online content
Yes, I have used it. Don't try and brush it on as they say it can be...it must be sprayed.Brushing is fine for a car chassis (I guess) but not for your motorcycle parts. I tried it just to see if it would work and quickly found it didn't...just on a test piece. But yeah, I like the POR-15 stuff.
Re: Por-15 chassis black #58370
12/07/07 4:15 pm
12/07/07 4:15 pm
Western Oregon
enigmaT120 Offline
enigmaT120  Offline
Western Oregon
Jon, what kind of respirator do you use when spraying POR-15? For the frame I would use the regular POR-15 first, then top it with the chassis black.
Ed
1970 Bonneville
Re: Por-15 chassis black #58371
12/08/07 6:27 pm
12/08/07 6:27 pm
Sorry,I haven't sprayed it using a paint gun. My brushing it on brought me to the conclusion that it needs to be sprayed if using it on mototcycle parts.
The POR-15 black rust preventative paint doesn't show brush lines, but the chassis black does.I had to sand out the lines and clearcote the pieces I did use it on. Nothing major (small parts), so I got away with it.
Posted by enigmaT120:
Re: Por-15 chassis black #58372
12/10/07 2:47 pm
12/10/07 2:47 pm
Sydney, Australia
GuyboA10 Offline
GuyboA10  Offline
Sydney, Australia
Hey Guys, yea i'm gonna use the por15 THEN the Blackcote for the topcoat. Anyone know if blackcote works well with a brush? The chassis coat is a semi-gloss whereas Blackcote is gloss.I'll prob use por15 in grey and blackcote on top so i see if the topcoat is thoroughly done. Cheers ,Guybo.
51'/53'/58' A10 Plunger(frankenbsa) Golden Flash
Re: Por-15 chassis black #58373
12/10/07 3:30 pm
12/10/07 3:30 pm
wisconsin
BSAketcase Offline
BSAketcase  Offline
wisconsin
has anyone ever used this stuff on cylinders? would it contain the heat too much?
It almost seems like the coating the factory used on the cylinders
Re: Por-15 chassis black #58374
12/11/07 5:52 am
12/11/07 5:52 am
Billings, MT
Billings, MT
I've heard that the glossy and glassy looking por15 rust preventive paint is sensitive to UV light.
67 Triumph T100R
68 Norton Commando
71 BSA B50MX basket
Re: Por-15 chassis black #58375
12/11/07 3:10 pm
12/11/07 3:10 pm
, Lower -Lower michigan
Bob S Offline
Bob S  Offline
powdercoat it.....................and be done with it, cheaper harder, flows better when applied by experience,drop awrench on it the paint stays where its at. in the long run you`ll wear your self out, and cost you more monry, believe me i`ve been there, won`t go back. cool smile they`ll p.c your parts any color you wish, added bonus TSHelp
bob scharp
Bob S
Street Rods, Kustom Kars,A BSA,Cushmans,H.Shadow ACE, Now a 2004 triumph america . "More than enough!!!!
Re: Por-15 chassis black #58376
12/12/07 7:13 am
12/12/07 7:13 am
Billings, MT
Billings, MT
I hear you Bob, it might not be quite as good, but it would be done at home and I think either the single part blackcote ($44.00/quart) or the 2 part "hardnose" (~60.00/quart) would be cheaper than powdercoating, especially with all the little extra bits, footpeg hangers, etc. to do.
Brendan
67 Triumph T100R
68 Norton Commando
71 BSA B50MX basket
Re: Por-15 chassis black #58377
12/13/07 12:35 am
12/13/07 12:35 am
Guybo,
Now that you mention it, it was the Blackcote that I used...not the Chassis Black. As far as using a brush, it is out of the question with that stuff. It is thin and really shows the brush marks...it is also not hard like the rust preventative POR-15 that is applied first.
Posted by GuyboA10:
Re: Por-15 chassis black #58378
12/13/07 12:39 am
12/13/07 12:39 am
The rust preventative Black and Silver POR-15 base coats are sensitive to UV light and susceptible to fading. That's what the top coats of let's say Blackcote are for.
Posted by Brendan Shannon:
Page Time: 0.082s Queries: 14 (0.007s) Memory: 1.0716 MB (Peak: 1.2621 MB) Zlib disabled. Server Time: 2018-02-23 16:40:46 UTC
