The Bonneville Shop
wadeschields
wadeschields
10528 Registered Users
franko 90
NickL 66
785,188 mail-order LSR
Topics69,221
Posts674,274
Members10,528
Page 2 of 2 1 2
Re: Annealing Copper Head Gaskets [Re: Triless] #580738
01/13/15 10:06 am
01/13/15 10:06 am
Running from demons in WNY
Hillbilly bike Online content
Wow,do you guys have digital thermo sensors to indicate the proper temperature for annealing or is the bright red color close enough? grin
I take off bike parts until it doesn't function, then put on just enough so it functions
Re: Annealing Copper Head Gaskets [Re: Charlieboy] #580745
01/13/15 10:47 am
01/13/15 10:47 am
JubeePrince Offline
Born To Run
JubeePrince  Offline
Born To Run
If it's Amaranth Red, it's not hot enough.
Re: Annealing Copper Head Gaskets [Re: Hillbilly bike] #580747
01/13/15 10:59 am
01/13/15 10:59 am
Magnetoman Online content
Magnetoman  Online Content
Yes, and...
...Yes.
Here the analog eyeball definitely is close enough.
Re: Annealing Copper Head Gaskets [Re: Charlieboy] #580760
01/13/15 1:01 pm
01/13/15 1:01 pm
Tridentman Online content
Tridentman  Online Content
Cherry red has done the job for me for over 50 years--without any problems.
Re: Annealing Copper Head Gaskets [Re: Tridentman] #580765
01/13/15 1:21 pm
01/13/15 1:21 pm
Amaranth red is ~1200 oF, cherry red is ~1500 oF, and red paint that has been in the desert sun too long (i.e. orange) is ~~1700 oF, so it's easily possible by eye to discern temperature difference of only 100 oF or so.
You don't have to get the entire head gasket glowing cherry red simultaneously to accomplish the task. Just get a region a few sq. inches in size up to cherry red and then slowly advance the torch to "push" that red region around the entire gasket (with the back edge of that region cooling off as the torch advances). Although you will do the entire gasket, at any one time only a few sq. inches will be glowing.
I've never timed it, but the heat capacity of the copper does a pretty good job of timing the annealing for you. That is, if you try to advance the torch too quickly the leading edge won't have time to come up to cherry red so that will force you to slow down. It only requires being at cherry red for a few seconds to accomplish the task. Longer is fine (although, with increased oxidation of the surface), but hotter is risky.
It's safer if you do this with a propane torch since it is possible to melt the thin copper with oxy-acetylene. If you do use acetylene I'd recommend using a "rosebud" tip, although any tip will work as long as you pay attention and don't let any portion ever get hotter than cherry red.
Re: Annealing Copper Head Gaskets [Re: Charlieboy] #580781
01/13/15 3:48 pm
01/13/15 3:48 pm
Yes--I use a propane torch and progressively "cover" the whole of the gasket.
When all done I ease the gasket into a bucket of cold water. That gets rid of most of the crud and the gasket is then very soft.
Re: Annealing Copper Head Gaskets [Re: Charlieboy] #580796
01/13/15 5:19 pm
01/13/15 5:19 pm
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
The last part of TDM's post gets to the real point. When you are done annealing it,It will be soft enough to bend with your fingers. Jack
Page 2 of 2 1 2
