dodgeboy57
dodgeboy57
Michigan
16 registered members (BeezaBryan), 149 guests, and 53 spiders.
10381 Registered Users
NickL 98
Mori55 92
Stuart 87
DavidP 73
reverb 69
Triless 69
Rohan 67
688,750 mail-order LSR
Topics68,017
Posts661,660
Members10,381
TR25W Replacement Speedo #578793
12/30/14 11:18 pm
12/30/14 11:18 pm
Monterey, CA
stugs Offline OP
stugs  Offline OP
Monterey, CA
Hey All,
My speedometer finally bit the dust (SSM2001/02 1600) and since I couldn't find a real Smiths for a price I'm willing to pay, I wanted to purchase a repo. Seems most of the repos are 80mm vs 60mm, so my search isn't quite as easy as I'd hoped.
I can find a few 80 or 100 MPH 60mm speedos, but none list the ratio. Looking through a couple reference sites, the SSM2001 came on plenty of bikes, but I'm not entirely clear if they can be directly swapped. For example, from a Cub.
My backup plan is upsize to an 80mm and use a mount from a BSA B44 or B25
Re: TR25W Replacement Speedo [Re: stugs] #578806
12/31/14 1:43 am
12/31/14 1:43 am
Pat Offline
Pat  Offline
Going through this right now. Triumphs used a 1.25/1 ratio hub drive and Bsa's use a 2/1 rear hub drive. BUT, you should pull the hub drive off and check your's since they might have used a Bsa unit. It will be marked on the inside ring. I'm going to use a Tri T140 gauge bracket, shiny and just clamps under the fork tube bolt.
Re: TR25W Replacement Speedo [Re: stugs] #578807
12/31/14 2:08 am
12/31/14 2:08 am
Stuart Offline
Stuart  Offline
Someone like Nisonger couldn't fix it?
Bear in mind though that any original Smiths you buy is likely to need to go to someone like Nisonger for a service?
The TR25W tacho. is an "80mm" (3"?) so, if the B25 uses a 3" speedo., possibly Meriden's use of a "60mm" speedo. was a small attempt to make the TR25W a bit more than just a re-badged BSA?
The more-expensive ($50-$60?) repos. have been around for at least ten years and appear to be good, restorers I know who've used 'em like 'em. I've only seen the really cheap repos. from India in the last year or so, dunno what their quality's like. Only thing you have to watch with the 'more expensive' repo. speedos. is the trip reset knob is fixed and not in the same position as the Smiths' one. frown First one I used, I fitted in an oif-type rubber mounting and that was fine, last one I tried was in a '69/'70 triple's rubber binnacle and that wasn't even close. frown
Re: TR25W Replacement Speedo [Re: stugs] #578810
12/31/14 4:05 am
12/31/14 4:05 am
Rotorua, New Zealand
'59 Bonnie Offline
'59 Bonnie  Offline
Is this the one you looking for? Here are some spares.
http://www.ebay.com/itm/Triumph-Tr25W-White-Smith-Speedometer-Guage-/261579362297
"We are "motorcyclists" & "historians" our hobby includes the research & preservation of motorcycle history. What we are doing in the research & preservation of iconic bikes is, an important part of its history & value".
Re: TR25W Replacement Speedo [Re: stugs] #578853
12/31/14 1:19 pm
12/31/14 1:19 pm
Monterey, CA
stugs Offline OP
stugs  Offline OP
Monterey, CA
Thanks for the replies. I did some searching on the forum and it appeared that rebuilding my speedo was going to be close to purchasing a NOS which is about $300. While not horrible, it's overkill for this bike. This is more of a dd vs something I'm planning to restore.
I guess I'm going to go dig through Raber's used parts section and see if I can't find that B44/B25 mount after checking that hub drive. As my speedo said 1600 I assumed it was 2:1, but I should know better than assume these things smile
Thanks all!
