Jake Hartley
Jake Hartley
Oklahoma City OK
25 registered members (Bluehighways), 194 guests, and 370 spiders.
10476 Registered Users
franko 72
Triless 67
747,234 mail-order LSR
Topics68,821
Posts670,336
Members10,476
6T ENGINE REBUILD - T110 Barrels 6t Head?? #578356
12/28/14 11:26 am
12/28/14 11:26 am
Kent UK
6
666Thunderbird Offline OP
Kent UK
Hi Everyone...
Finally getting close to engine assembly time on my 1955 Thunderbird. Some of you may remember the bike as it had an 18 foot holly tree growing through it!
I have saved the casings which are big bearing type.
The cylinder head looks ok and is a 4 fin one.
I have 2 barrels... First I have a 3332 T110 one with pistons which I was just going to fit but.. not sure if this will work with my head??
Everything I have is 6T camshafts, crank/rods, pushrods etc etc but the barrels are T110
Does anyone know any reason why I shouldn't fit these
2nd barrel option is a 6T one bored to +60 but I have no pistons yet and this seems more hassle not to mention expense.
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578358
12/28/14 11:41 am
12/28/14 11:41 am
Kent UK
6
Kent UK
For those that don't remember my bike this is the story so far......
https://www.flickr.com/photos/116301631@N02/
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578365
12/28/14 11:56 am
12/28/14 11:56 am
Kent UK
6
Kent UK
Another "silly" question... Why are all the old 6T pistons so flat looking on top yet all the pistons I can find for sale seem far more dome shaped.. The pistons in my T110 Barrels are a lot rounder than the flat ones which were welded into the original barrels by 43 years of English weather!
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578384
12/28/14 1:24 pm
12/28/14 1:24 pm
triton thrasher Offline
T110 barrels and 8 stud 6T are the same.
The domed pistons you are seeing commonly for sale are probably 9:1 compression ratio, standard on late Unit 650s.
They probably work ok in a 6T. I've never heard of any problems and I'd bet loads of owners have fitted them.
They do work in an iron headed T110. The measured compressipn ratio with "9:1" pistons in mine was just under 8:1.
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578392
12/28/14 2:33 pm
12/28/14 2:33 pm
Rotorua, New Zealand
'59 Bonnie Offline
'59 Bonnie  Offline
Just looked, you doing a great job. No you should not have any issues using the higher compression pistons etc.
"We are "motorcyclists" & "historians" our hobby includes the research & preservation of motorcycle history. What we are doing in the research & preservation of iconic bikes is, an important part of its history & value".
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578517
12/29/14 7:51 am
12/29/14 7:51 am
Kent UK
6
Kent UK
Thanks for the advice so far..
Does anyone know why the 6T and T110 Barrels have different part numbers if they are the same?
6T E2895
T110 E3332
Seems unlikely they would be the same. I have cross refd a lot of other parts and they use the same part number if they are the same so why not on the barrels?
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578521
12/29/14 8:23 am
12/29/14 8:23 am
craig Offline
craig  Offline
i would do a volume measure to get accurate comp , you do not want 9:1 in a all iron 6T , it will run but not as sweet as this engine should be
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578523
12/29/14 8:39 am
12/29/14 8:39 am
http://britishbikebits.com/cylinder-barrel-8-stud-triumph-650cc-pre-unit#.VKFLNYoN8
8 Stud Cylinder Barrel
Suitable for Triumph 650cc Pre-Unit Models circa 1954-62
T120 Bonneville
6T Thunderbird
T110 Tiger
TR6 Trophy
Triumph Part number E3332, 70-3332
Can also replace E2895 (70-2895) This just has a different fin style
2895 may be older, from when the only 650 was a 6T.
Can you see a difference in the fins?
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: craig] #578524
12/29/14 8:51 am
12/29/14 8:51 am
Have you tried it?
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578526
12/29/14 9:34 am
12/29/14 9:34 am
craig Offline
craig  Offline
i have built and own several pre unit triumphs (i still have a 6T) setting comp via volume measure is the only way and on petrol have tryed upto 10.2:1 and they will run , 9:1 will run but still to high for a sweet running all iron engine , if you want a easy starting very nice running 6T 7.5 to 8:1 is perfect , they still go well and top end is almost the same but takes a little longer to get there . if you combined this comp with a SU carb you will think your riding a jap bike they really are that good .
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578559
12/29/14 1:23 pm
12/29/14 1:23 pm
Kent UK
6
Kent UK
Both numbers quoted are from the 1955 Parts Cat.
All my parts are 6T apart from the Barrels and Pistons which are T110
I might try and find some flat topped +60 Pistons for the other barrels just to be on the safe side.
Thanks for everyone's input.
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: craig] #578578
12/29/14 2:33 pm
12/29/14 2:33 pm
Sunny Sussex, UK
tbird649 Offline
tbird649  Offline
Sunny Sussex, UK
I agree, my 1956 6T has 8:1 pistons, and SU carb, it is a very smooth and sweet engine. When I first got it it had bloody great domed pistons in it, +60's , I think maybe a few years ago these were all that were available in that oversize. New barrels, and lower compression was a big improvement.
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: craig] #578586
12/29/14 3:25 pm
12/29/14 3:25 pm
Yes, a real 9:1 might be high. Have you tried the pistons that are nominally 9:1 with an alloy head, in an iron headed 6T?
They give me just under 8:1 measured, in the iron T110. Could be different in a 6T and the OP can't measure before buying and fitting.
They are the commonest and cheapest Triumph 650 pistons. The low measured compression in the T110 makes me wonder whether pistons labelled as 7:1 or 7.5:1 might turn out to be 6:1 when used with an iron head.
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578589
12/29/14 4:08 pm
12/29/14 4:08 pm
Kent UK
6
Kent UK
I just bought some flat topped pistons (with the correct part number) for my old +60 6T barrels.. hoping this is going to prove a good move.. 7:1 seems a bit low but the part numbers are the same as the 1955 parts book... fingers crossed :-)
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578598
12/29/14 5:28 pm
12/29/14 5:28 pm
Sunny Sussex, UK
tbird649 Offline
tbird649  Offline
Sunny Sussex, UK
Just had another look at your pictures. At least mine didnt have a tree!
PS Keep the SU carb.
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578602
12/29/14 6:04 pm
12/29/14 6:04 pm
Kent UK
6
Kent UK
The tree is very under-rated.. I think it was holding mine together ;-)
Well actually it was just holding it in place for me... The tree must have been older than me. My bike was there when I was born.. and all the way through my life it was just sitting there. At one time I even lived just 9 miles away from it. Every single day of my life, through every event the Thunderbird was just sitting there.. makes you think really.
And yes I will keep the SU... I still have the tree trunk too :-)
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578606
12/29/14 6:19 pm
12/29/14 6:19 pm
HawaiianTiger Offline
At .060 over, you might be in for some problems. The max overbore on pre units is stated by the manual to be +040. You might get away with it or you might have cylinder wall distortion when you torque up the head bolts. I would test the cylinder with head bolts and spacers torque to spec, measured with a bore gauge or just blue up the cylinder and pass a hone once through it to see if the cylinder walls are bulging at the head bolt holes. I have done this and honed the cylinder to get it round again, but I'm not really proud of that since it is a bodge after all.
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578613
12/29/14 6:51 pm
12/29/14 6:51 pm
Kent UK
6
Kent UK
Thanks for the advice. Seems like a minefield whichever way I go.
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: tbird649] #578660
12/30/14 2:00 am
12/30/14 2:00 am
'59 Bonnie Offline
'59 Bonnie  Offline
That looks really great, hope you don't mind me posting this.
As to the differences between the T110 and 6T barrels exactly what they are I am not sure but one reason would be for mag motor compared to coil/ distributor motor. With Triumph if it had a extra hole it had a different number........ Nice bikes.
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578664
12/30/14 2:50 am
12/30/14 2:50 am
Kent UK
6
Kent UK
Top job. If mine ends up half as nice I'll be more than happy.
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578672
12/30/14 6:32 am
12/30/14 6:32 am
+60 rebores have always worked for me, but I can see how they might not always. The bore is close to the head bolt holes.
That is a handsome bike.
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578686
12/30/14 9:25 am
12/30/14 9:25 am
craig Offline
craig  Offline
are the cam follower blocks the same ? as the lower end of the push rods tubes are different did they alter the setting arrangement , very nice 6t , I changed mine to mag as I like control of the ignition adv/ret but that's ust my age as the dizi worked fine
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578690
12/30/14 10:03 am
12/30/14 10:03 am
Sunny Sussex, UK
tbird649 Offline
tbird649  Offline
Sunny Sussex, UK
Slight change of topic, but now someone has mentioned ignition, I kept the points for some years, then took the plunge and sent my distributor off to www.kirbyrowbotham.com and had it machined to take Pazon EL. Best mod I have made! Just saying, so if you go that route, send it off in plenty of time as mine took a bit longer to come back than was originally stated .
Re: 6T ENGINE REBUILD - T110 Barrels 6t Head?? [Re: 666Thunderbird] #578707
12/30/14 1:16 pm
12/30/14 1:16 pm
Irish Swede Offline
Irish Swede  Offline
tbird, thanks for the information on the Rowbotham conversions.
If I can never find a really competent magneto rebuilder, that's what I will have to have done.
