TONUP69
TONUP69
Memphis, TN
207 registered members (57nortonmodel77), 2,339 guests, and 679 spiders.
myshootingstar68, Caddy, Spitfiregary, Ashley, HerbertG
10073 Registered Users
koan58 82
NickL 81
Stuart 64
503,301 mail-order LSR
Topics66,021
Posts638,985
Members10,073
podtronics VS Tympanium #572849
11/18/14 8:27 pm
11/18/14 8:27 pm
SEATTLE WA
SEATTLE GS Offline OP
SEATTLE WA
One better than the other?
Re: podtronics VS Tympanium [Re: NickL] #572909
11/19/14 9:13 am
11/19/14 9:13 am
Orlando fla/ shady valley Tn
bill50cal Online content
bill50cal  Online Content
either one is better than the sparks brand junk.
windy
72 combat
switchbackcreek.com
Re: podtronics VS Tympanium [Re: SEATTLE GS] #572947
11/19/14 1:27 pm
11/19/14 1:27 pm
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
FWIW,I've seen a couple of Tympaniums that were bad (The potting material was dark,like it had cooked) but I have not ever had a Pod go bad.I'm thinking the Pod's case(heatsink) helps. Jack
Re: podtronics VS Tympanium [Re: SEATTLE GS] #572985
11/19/14 7:05 pm
11/19/14 7:05 pm
Farmington,Connecticut,USA
JBMorris Online content
JBMorris  Online Content
Pod (Prince Of Darkness)is now being looked after by a very capable and worthy quartermaster.
Not too sure about the 'other' one for service- if needed.
Found mine (Pod)with an old price tag for $35 - 6 yrs. past.
1978 Bonneville T140V PX
Re: podtronics VS Tympanium [Re: SEATTLE GS] #573101
11/20/14 4:41 pm
11/20/14 4:41 pm
British Columbia Canada
Tony Schofield Offline
I have a Podtronics on the Norton and a Tympanium on the Trident. They both work well and I can't say that one is better than the other.
Re: podtronics VS Tympanium [Re: Tony Schofield] #573116
11/20/14 5:44 pm
11/20/14 5:44 pm
gastonia nc
raf940 Offline
raf940  Offline
gastonia nc
have pod on A65 and tymp on T120 (long time) both work good for me
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando project
Re: podtronics VS Tympanium [Re: NickL] #573342
11/22/14 9:12 am
11/22/14 9:12 am
barrie ontario canada
6
68 royalstar tony Offline
Originally Posted By: NickL
Make sure you obtain a correctly rated type as some stators have a higher output than others.
The Tympanium units I have tested in the past use a single SCR. This is fine for bikes with coil ignition but may cause battery overcharging when used on a bike with a magneto as there is no load at all without the lights on. The units I tested were pre 2004 and the design may have changed so it would be worth asking the question.
Personally I now use cheap chinese devices with no problems.
what are these cheap Chinese devices that you tal about? Thank Tony.
Re: podtronics VS Tympanium [Re: SEATTLE GS] #573492
11/23/14 11:28 am
11/23/14 11:28 am
6
Wow that is low priced, thanks just ordered one. Thanks again.
Re: podtronics VS Tympanium [Re: NickL] #576736
12/16/14 5:14 pm
12/16/14 5:14 pm
6
Thanks for the tip, mine came today. When you wire them is it red + and green - even on pos ground like my 66 TR6?
Re: podtronics VS Tympanium [Re: NickL] #576789
12/17/14 1:19 am
12/17/14 1:19 am
Stuart Online content
Stuart  Online Content
Green = Neg
Red = Pos
Fwiw, that's how Honda uses those colours.
If using on a two wire stator just join any two yellow wires together and connect the joined pair and the other yellow one across the stator
Just as a matter of interest, is there any advantage to joining two of the Yellow wires? Reason I ask is I've seen a single-phase alternator just connected to two of the wires on a 3-phase rect./reg., with the other one just insulated?
Also, seems the way Podtronics do a single-phase is to cut off one of a 3-phase's wires flush with the casing? confused
Re: podtronics VS Tympanium [Re: NickL] #576792
12/17/14 3:11 am
12/17/14 3:11 am
Pacific northwest
quinten Online confused
quinten  Online Confused
Pacific northwest
All you are doing is 'doubling-up' on a leg of the bridge rectifier, you can just cut off one yellow cable if you wish but as the bridge is 3 phase why not just parallel up two of the legs.
Nick
This is all splitting hairs
, I think ,
but here goes ... connecting a single phase ( 2 wire stator ) up to a 3 phase
(3 input wire) r/r unit ...
by hooking one stator output wire
To- 2 , of the 3 phase r/r input wires offers marginal if any gain.
The stator output leg that has it output shared by the extra diode bridge may have that side of the bridge run cooler ... but has , at the same time , an extra forward voltage drop to pay in order to operate .
The diode bridge is not the weak point in these low cost ( to manufacturer units )
So whats the point of this bodge ?
A 2 wire stator will work just a well , or better ,
on a 3 phase r/r
by leaving the 3rd. input wire ( un tapped)
Re: podtronics VS Tympanium [Re: NickL] #576821
12/17/14 11:39 am
12/17/14 11:39 am
Ottawa, Canada
gREgg-K Online content
gREgg-K  Online Content
Ottawa, Canada
Nick,
You're correct, linking any two of the yellow inputs to the 3 phase bridge will work fine in a single phase application. It is functionally identical to clipping off one of them, and as you say, can not add a series diode drop. I fail to see why someone would consider this a bodge, at least not with my understanding of that word's meaning and intent.
I suspect PODtronics chose the "clipping off a lead" approach because it is simpler, and does not need explaining in the customer documentation ... nor is there possibility of error if the instructions for clipping are misinterpreted.
.. Gregg
magneto@spyder-it.com
Moderated by  Dave Comeau
Page Time: 1.548s Queries: 15 (0.021s) Memory: 1.0761 MB (Peak: 1.2888 MB) Zlib disabled. Server Time: 2018-02-21 13:00:52 UTC
