richardvarcoe
richardvarcoe
Fort Worth
20 registered members (ducati2242), 229 guests, and 379 spiders.
Onder Zee, WardDuffield, Biscuits, DT 150, DamienE
10293 Registered Users
Stuart 98
Lannis 68
Mori55 67
639,438 mail-order LSR
Topics67,412
Posts654,555
Members10,293
T140 pressure fed rockers, good idea? #575305
12/06/14 10:50 pm
12/06/14 10:50 pm
San Francisco Bay Area
MarksterTT Offline OP
Wondering why I shouldn't pressure feed the rocker shafts on my T140 project bike. I understand Norton Commando's use press. fed rockers and I have followed a post on another site where a rather ingenious fellow runs his rocker oil through 2 coolers before it gets into the head, this arrangement is said to be more beneficial at engine cooling then the std. way of routing the engine oil through a cooler and back into the tank or into the crank.
I know Triumphs need and get very little top end oil and it is tapped off the oil return but I'm more interested in the cooling benefits of more and cooler oil through a high performance tuned head. I would imagine valve guide oil seals would be required and perhaps opening up of the drain back holes in the tappet guide blocks. Taking the oil press. off the forward timing cover boss would be easy. The rocker feed oil line could have an adjustable or replaceable restictor to tailor the amount of oil getting to the rocker boxes if necessary or a differential amount to ex. vs. intake.
So I'd like any opinions, from a cooling/longevity stand point, of why or why not pursue this...Mark
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575317
12/07/14 2:27 am
12/07/14 2:27 am
Nick, oil seals and plumbing are no problem, it's an easy mod but is it worth the effort? The ex. rocker box area runs pretty hot, I plan to modify the ex. ports with a machined stainless steel insert with an air gap to keep as much of the ex. heat as possible out of the head and perhaps with a higher flow of cool oil the head will benefit from a longer life. I view the Triumphs head design as it's weakest point so feel that any effort to improve things up top can't hurt...Mark
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575319
12/07/14 2:42 am
12/07/14 2:42 am
Stuart Online content
Stuart  Online Content
Hi Mark,
This, or a very similar question, has been asked before, and answered at length by John Healy. He might answer again but in the meantime:-
I assume you mean the "press." feed for the rockers from the timing cover? If so, you would then rob the crank bearings of oil they need to feed rockers that don't. confused
You can increase oil supply to the rockers by completing the modifications that Meriden failed to complete. crazy John has detailed these modifications in earlier posts. This would achieve your aim more simply and without robbing the bottom end?
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575334
12/07/14 6:13 am
12/07/14 6:13 am
Triumph undid what you are proposing, in the 1940s.
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575439
12/07/14 5:39 pm
12/07/14 5:39 pm
Stuart, I was sure this had been discussed but for me this site is very frustrating when it comes to 'searching' for anything. I just don't have the ability to find what I'm looking for so please forgive me for that. I have the Meriden mods covered from posts on this forum and 30 yrs. of the TIOC magazine, to me J.H. is a national treasure but what I was proposing goes beyond proper parts and assembly techniques and would hopefully improve head cooling & valve train longevity. Also from this forum, I've been led to believe that a Triumph end feed crank can almost survive on gravity feed alone, so with an uprated Morgo plunger pump I was hoping taking some press. feed off for the rockers would be o.k., do you think this is a false assumption? I could just do the ex. side and use return oil for the intake rockers per standard procedure. I'm sure the Morgo rotary pump would be up to the task but I have already seen one Triumph big end sieze up from a rotary pump that had lost it's prime so don't really want to go there.
Nick, I have planned on c.c. and port coatings so I'm with you there but you do make a good point about drain back being a potential issue, there is room to drill out the drain holes in the tappet guide blocks a bit.
TT, do you know why Triumph undid what I'm proposing back in the '40's? I realize that 1000's of Triumphs have run and raced on the stock set up but I've also seen some very worn and over heated valve train parts (esp. ex. side) but perhaps the meager amount of cooler oil I'm talking about wouldn't do much in regards to extra cooling. I'm trying to think of any and all means to keep my 825cc street tracker cool on our super slabs and this seemed to be one small step to consider, I've already gone to dual plugged head (Pazon), will do coatings, ex. spigot air gap, 9.5-1cr 'squish' low profile pistons, nicasil bores etc., even an air duct to dump cool air between rocker boxes.
So I wonder why Nortons (Commando's)run system press. to their rockers and why isn't it a problem for them? Do Commandos run valve guide seals on intake & exhaust guides? I'm pretty sure some of the smaller, earlier Nortons tapped rocker feed oil off the scavenge return like our Triumphs so they had experience with both methods.
Thank you for all the replies and I'd like to hear more so feel free to argue this idea, it still sounds good to me especially if oil drain back and robbing the crank of pressure are the only perceived issues...Mark
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575444
12/07/14 5:51 pm
12/07/14 5:51 pm
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
The most I've ever done to increase rocker oil flow is to reduce the size of the tank restrictor hole to about 1/3 the area.
That will give you about 9 times as much pressure in the rocker feed line, and it seems to cause no problem.
You can jam a suitable sized wire into the tank restrictor hole to get the same effect, but just make sure it can move and fall out of position.
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575445
12/07/14 5:54 pm
12/07/14 5:54 pm
For searching, use Google.
Search for your subject, along with the "britbike.com"
Re: T140 pressure fed rockers, good idea? [Re: triton thrasher] #575447
12/07/14 5:59 pm
12/07/14 5:59 pm
Vic. Australia
Vic. Australia
I do that with Google, and just put
site:britbike.com
after the keywords.
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575481
12/07/14 9:26 pm
12/07/14 9:26 pm
South cone
reverb Offline
reverb  Offline
South cone
...hello Pete R, what you say is what the 67 and other oil tanks have or can achieve with the stock restrictor?
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575561
12/08/14 1:51 pm
12/08/14 1:51 pm
Hi Mark,
Try starting off with something simple like "John Healy" in the "Display Name Search".
Because it's John,selecting "Newer than 1 Year" will obviously get a lot of posts but simply scanning the titles and checking the more likely ones will often find me what I'm looking for ...?
Or you can try adding things to the Search to see if they continue to narrow the results; if not simply use the browser back button to go to the previous useful Search.
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575569
12/08/14 3:33 pm
12/08/14 3:33 pm
John Healy Offline
John Healy  Offline
Google works "the treat."
For example use:
triumph 5 speed britbike
or
Triumph rocker shaft britbike
Then look at the results and you will see 4 or 5 results but to get the Full Load click on at the bottom of the first 4 results:
More results from www.britbike.com
It's magic!
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575573
12/08/14 4:14 pm
12/08/14 4:14 pm
Thank you John, Stuart, Pete and TT for your input on 'searching' I'll give it a try and see what happens. Eventually I'll learn how to post pix also as it's real nice to be able to see and share.
Pete R., I agree, blocking the scavenge return hole to force more oil to the top end would normally be the easy way to increase flow but in my case my oil return outlet is internal to a custom C&J oil in frame and I still need to get a bore scope to look in there to make sure there is even a restriction built in...should be but you never know.
I'll go and search for Commando valve guide seals and see if indeed they have them on both intake and exhaust as I'm pretty sure they must to be able to run full system press. to the top end, in which case I would probably have to do the same...Mark
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575575
12/08/14 4:23 pm
12/08/14 4:23 pm
The Guide seals are on the inlets only on a Commando.
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575597
12/08/14 6:45 pm
12/08/14 6:45 pm
John Healy Offline
John Healy  Offline
In my experience with custom after market oil tanks is there is no restriction. Typically an external restriction is required.
Re: T140 pressure fed rockers, good idea? [Re: John Healy] #575608
12/08/14 8:27 pm
12/08/14 8:27 pm
Farmington,Connecticut,USA
JBMorris Offline
JBMorris  Offline
Back in the day it occurred the same thought of insufficient initial oil flow so on the T140 was added a third leg from the direct return and the siphon feed using simple 45 angle adaptors:
Ran that way for quite some time with no harm- now it's just back to normal plumbed.
Pretty sure those fittings were for vacuum lines?
bigt
1978 Bonneville T140V PX
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575634
12/08/14 10:34 pm
12/08/14 10:34 pm
HawaiianTiger Offline
I think it's a waste of time to increase oil flow to the rockers. The rockers and shafts don't seem to wear out any faster than anything else. It's the valve guides that wear out way too fast. So, increasing the oil flow to the head will have no effect on valve guide wear since fuel supplies the only lubrication to the guides.
Valve guide wear has been reduced, I think significantly, by selecting top quality guides and valves. I had good luck with Ampco 45 guides and Kibblewhite black diamond valves.
But at the end of the day what I put in my bike will be what available at the price I want to pay. I can easily get 5 years of riding with ordinary parts but If I put the Kibblewhites and good guides I suspect the bike would certainly outlast me.
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575636
12/08/14 10:36 pm
12/08/14 10:36 pm
Thanks Kommando, seals on the 'inlets only' makes sense due to vacuum drawn on intake stroke so maybe with a nice close fit ex. valve stem to guide my excess oil delivery wouldn't be any more of a problem then on the Norton.
John, I've found the same with some aftermarket oil tanks but this frame was built to my drawings and I specified a similar return pipe scheme as found in the Triumph oil tanks but I'm not real comfortable assuming it was done...so I will have to investigate.
Thanks for picture JB, brought back an old memory with those clear oil lines, I had a similar rocker feed line to my Webco rocker box oil manifold (1970)and while on a long trip with nothing much else to do, I leaned over to see how much oil was flowing to the boxes, next thing I knew I ran off the road and through a road sign, my left hand, clutch lever and left exhaust pipe took off a 4x4 post which left me in the ditch with the ex. header smashed against the front of the primary case with the top end no longer attached to the cylinder head. Pop, pop, pop and not much horse power. By the way there seemed to be plenty of oil in that clear line...Mark
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575655
12/09/14 2:41 am
12/09/14 2:41 am
Some seals crumbled under the heat of the exhaust.
There may be better ones available now.
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575660
12/09/14 5:36 am
12/09/14 5:36 am
Those clear lines harden and then fracture quickly, good for a fresh rebuild to see what's going on but best replaced once the rebuild is confirmed as working with a good rubber hose.
Re: T140 pressure fed rockers, good idea? [Re: kommando] #575720
12/09/14 4:26 pm
12/09/14 4:26 pm
New Zealand
Excalibur Online content
Excalibur  Online Content
New Zealand
+1 for the good advice. A good rubber hose is one that is rated for oil and has the inbuilt reinforcing. I believe better brands are more kink resistant.
Re: T140 pressure fed rockers, good idea? [Re: Excalibur] #575738
12/09/14 7:31 pm
12/09/14 7:31 pm
JBMorris Offline
JBMorris  Offline
True et all,
Still use a clear hose to watch the "pulsing" - pretty cool like watching a heartbeat!
'was one of those who changed the oil when picked up second hand and had a 'no oil pressure' problem.
The pump was worn- how badly not known- so a new one was installed, right after buying the factory service tome.
Comments?
Re: T140 pressure fed rockers, good idea? [Re: JBMorris] #575747
12/09/14 9:30 pm
12/09/14 9:30 pm
New Zealand
New Zealand
To me the witness marking on the pumps' pistons is very suggestive that it will scrub up OK. To properly evaluate it, lightly rub the pistons with 600 or finer wet&dry. Then buff them on an electric wire wheel. Next take the valves out of the body and wash all the parts in solvent and air blast clean. Apply engine oil to the pistons and bores and test the fit. It should be a nice sliding fit with negligible play. Then refit the valves, testing them by using the piston to pump oil through each valve. Oil should go through but not pull back. In addition with the pistons fully home when you gently pull each one, there should be a small amount of "spring back" from the vacuum. If it passes this, I call it good. HTH
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575830
12/10/14 6:03 pm
12/10/14 6:03 pm
Naarfuk, UK
Tigernuts Offline
Tigernuts  Offline
Naarfuk, UK
To me, the interesting question is how did those wear marks appear on the plungers? Both feed & scavenge seem to have identical marks. I can't envisage how this could have happened and I'm curious to know. I must admit, if it was off a bike of mine, I'd consign it to the 'interesting things' shelf and buy a new one, not mess around trying to fix it.
Re: T140 pressure fed rockers, good idea? [Re: Tigernuts] #575837
12/10/14 6:50 pm
12/10/14 6:50 pm
Running from demons in WNY
Hillbilly bike Offline
Just above your post, Excalibur implies those are "witness marks" . As in original machining marks made more visible by the scuffing action of the pistons in pump bore.
I ride junk
Re: T140 pressure fed rockers, good idea? [Re: MarksterTT] #575859
12/11/14 1:21 am
12/11/14 1:21 am
Hawaiian Tiger, thanks for your input but I'm not trying to increase the oil flow for lubrication purposes as much as for cooling purposes as I had proposed running oil off the pressure side of the pump and through a cooler and then into the head. The ex. rocker box and valve gear inside runs much hotter then any other part of the engine, even the T140 non magnetic stainless steel head bolts slowly become magnetic on the ex. side of the head from the high heat environment.
I can't agree on fuel being the only lubrication valves and guides get, probably to some degree back in the days of leaded fuels it helped but I have to disagree, they may not need much oil but I think 'some'.
I agree that KW valves and guides with a minimum clearance honed fit as John Healey recommends will probably be all that I would ever need.
