John Michl
John Michl
Keokuk, Ia
200 registered members (68 royalstar tony), 1,981 guests, and 525 spiders.
Mark Masa, Jody Camak, analyse, Drifter, john harrison
10041 Registered Users
Lannis 149
kommando 117
Stuart 60
479,420 mail-order LSR
Topics65,754
Posts635,650
Members10,041
73 750 Commando Speedo #559793
08/23/14 5:17 pm
08/23/14 5:17 pm
Iowa, USA
1
1958superrocket Offline OP
Iowa, USA
Just bought a really nice 73 750 Commando that runs like a champ and looks really good as well with one problem. The speedo is insanely off, appears to be reading 85-90 MPH when I'm riding around 60-65! Were there different calibrated instruments and speedo drives etc., the gauges I'm sure are correct for the bike and the seller says were the bikes originals. Needle bounces quite badly back and forth over a 10 MPH range as well. The tach is smooth and even and appears to be correct. Any ideas on things to check before I replace it or send it off for a rebuild? Thanks.
Re: 73 750 Commando Speedo [Re: 1958superrocket] #559794
08/23/14 5:57 pm
08/23/14 5:57 pm
California, US
Peter_Joe Offline
Peter_Joe  Offline
California, US
It sounds as though you may have the wrong speedometer drive. The Norton Commando speedometer drive ratio is 15/12 which equals 1.25:1. You may have a 2:1 ratio speedometer drive on your bike right now. The speedometer drive ratio is stamped on the felt seal retainer and is easily seen once you remove the speedometer drive from the rear wheel. If the speedometer drive is correct I would ride the motorcycle along a road where there are mile markers or use a GPS and see if the odometer is correct. If the odometer is correct then there is a problem with the speedometer itself. I am assuming your bike has the original 19 inch rim with the 4.10 x 19 tire.
The speedometer cable is a likely culprit for a bouncing speedometer. Check the routing to see if there are any kinks and also go ahead and re-lube the cable as well.
Re: 73 750 Commando Speedo [Re: 1958superrocket] #559810
08/23/14 7:42 pm
08/23/14 7:42 pm
Ottawa, Canada
gREgg-K Online content
gREgg-K  Online Content
Ottawa, Canada
Further to Peter_Joe's suggestion, the correct speedo drive for your bike is a SMITHS BG5330/171. You have to remove it from the bike to check the number, but its worth it as a first check.
While you have it off and assuming it is the correct one and the gears are in good shape, it would be worthwhile to take it apart, clean out the old grease and re-lube it.
.. Gregg
magneto@spyder-it.com
Re: 73 750 Commando Speedo [Re: gREgg-K] #559822
08/23/14 9:26 pm
08/23/14 9:26 pm
Iowa, USA
1
Iowa, USA
Thanks to both of you for the suggestions, I feel a rear wheel coming off in the next few days.
Re: 73 750 Commando Speedo [Re: 1958superrocket] #559836
08/23/14 10:58 pm
08/23/14 10:58 pm
Nanaimo, B.C. Canada
W
Wilfred Online content
Wilfred  Online Content
W
When I finished my T100R 20 years ago and went for a spin up the road I was doing about 30MPH and the speedo said 50. Same problem so I went through a couple of indicated speed zones and found that I was getting my speed in kilometers per hour. As the speedo was a 150 mph speedo, it would work well in Canada where we don't have miles anymore. Only trouble was that the speedo light is on the left side and once past 100 kph the needle went into darkness so I got the right drive and went back to MPH. Cheers, Wilf
"It's about the ride..."
Re: 73 750 Commando Speedo [Re: 1958superrocket] #559852
08/24/14 4:32 am
08/24/14 4:32 am
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
If you want to check the drive gearbox ratio, then the easiest way is to disconnect the upper end of the cable from the speedo and count the number of cable turns per revolution of the wheel.
If one wheel revolution = 1.25 cable turns, then the drive is the correct ratio.
The correct Smiths speedo for your '73 model would be a 'Green Globe' 150 MPH SSM 3001/09 unit, the instrument number should be printed at the bottom of the dial, however, by '73 they were also fitting Veglia instruments (in pairs) in which case, if Veglia, it would probably be: 09190919900.
Re: 73 750 Commando Speedo [Re: L.A.B.] #560157
08/25/14 9:20 pm
08/25/14 9:20 pm
Iowa, USA
1
Iowa, USA
Did the cable revolution to rear wheel check and one revolution of the wheel moves the cable a turn and a half. Appears to be 1.5 reduction, off a quarter of a turn. Do they make a 1.5 to one drive?
Re: 73 750 Commando Speedo [Re: 1958superrocket] #560170
08/25/14 10:13 pm
08/25/14 10:13 pm
Ottawa, Canada
Ottawa, Canada
It's not easy to resolve such small increments of a single rotation, and the error you're seeing may be due to wind-up of the inner cable. Why not turn the wheel 10 revolutions, and see what you get out of the speedo drive?
For example, if you were supposed to get 1.25 turns resulting from a single rotation, you should now see 12.5 ... much more accurate way to do it.
.. Gregg
Re: 73 750 Commando Speedo [Re: gREgg-K] #574416
11/29/14 7:48 pm
11/29/14 7:48 pm
IN
cireland Offline
cireland  Offline
IN
I recently picked up a '72 Commando and am in the process of sorting some stuff out. My bike encounters the same issue. 12 turns of the rear wheel equals 15 going to the speedo. Stock wheels and tires as well. Indicated 100mph of the bike feels like 60 gauging only on others in traffic. Speedo needle does not bounce either.. Any ideas?
Re: 73 750 Commando Speedo [Re: cireland] #574418
11/29/14 7:52 pm
11/29/14 7:52 pm
Norfolk, UK
Norfolk, UK
What is the number (SSM ????/??) printed at the bottom of the dial?
Re: 73 750 Commando Speedo [Re: L.A.B.] #574429
11/29/14 9:31 pm
11/29/14 9:31 pm
IN
cireland Offline
cireland  Offline
IN
SSM 3001/09
Re: 73 750 Commando Speedo [Re: cireland] #574460
11/30/14 5:08 am
11/30/14 5:08 am
Norfolk, UK
Norfolk, UK
SSM 3001/09
SSM 3001/09 is the correct MPH speedo for that period. As the drive ratio you measured is 15/12 (1.25:1) then the unit itself must be faulty.
Re: 73 750 Commando Speedo [Re: L.A.B.] #574492
11/30/14 12:25 pm
11/30/14 12:25 pm
IN
cireland Offline
cireland  Offline
IN
My buddy happens to have a SSM 3001/09 off of his '74. I'm going to swap them and see what happens. I'll report back. -Chris
Re: 73 750 Commando Speedo [Re: cireland] #574528
11/30/14 5:14 pm
11/30/14 5:14 pm
IN
cireland Offline
cireland  Offline
IN
I fitted a different speedo on to my bike and now it works perfectly. So, now that I have isolated the issue being my speedo unit, how do I go about fixing/taking it apart. I took the three screws out that hold the guts in and it won't budge. Does the chrome bezel unscrew from the housing?
I find it very strange that it reads so consistently off if it is broken. It doesn't jump around either, as I mentioned earlier.
Thanks! -Chris
Re: 73 750 Commando Speedo [Re: cireland] #574530
11/30/14 5:35 pm
11/30/14 5:35 pm
Norfolk, UK
Norfolk, UK
Unfortunately not, the crimped-on bezel has to be removed to get to the mechanism.
http://members.shaw.ca/randell/Smith/Speedo.html
http://www.lulu.com/gb/en/shop/graham-bl...t-20270214.html
Whether you decide to attempt a repair yourself or send it to a specialist Smiths instrument repairer or just find another good speedo is a decision I will leave up to you.
Re: 73 750 Commando Speedo [Re: L.A.B.] #574533
11/30/14 6:03 pm
11/30/14 6:03 pm
IN
cireland Offline
cireland  Offline
IN
The Shaw website link you attached was very informative. Towards the end of the read, he mentions calibrating the speedo with a power drill and simply turning a little brass screw. I'd say I'll give it a crack.. Thanks a bunch, Chris
Re: 73 750 Commando Speedo [Re: cireland] #574568
11/30/14 9:36 pm
11/30/14 9:36 pm
IN
cireland Offline
cireland  Offline
IN
An evening update..
I disassembled the speedo and adjusted it by turning the little brass screw behind the housing. Unfortunately, the chrome bezel got compromised in the adventure. Now I'll be on a hunt for that piece and how to re-crimp it.. I'm still scratching my head as to how that adjustment got so far off. The screw had to be backed out at least 10 revolutions to get it in spec with my spare speedo using my drill and square drive tip used for deck screws.
Thanks for the tips, Chris
Re: 73 750 Commando Speedo [Re: cireland] #574569
11/30/14 9:44 pm
11/30/14 9:44 pm
Norfolk, UK
Norfolk, UK
Here's a recent "bezel" thread at accessnorton:
http://www.accessnorton.com/speedometer-glass-question-t18456.html#p271625
Moderated by  Dave Comeau
