BONZO R.I.P.
BONZO R.I.P.
Michigan, USA
45 registered members (Al Eckstadt), 237 guests, and 451 spiders.
Norman Woollons, LandoLando, MikeA, Jay Gilling, scratchedtank
10254 Registered Users
Stuart 72
Lannis 68
L.A.B. 47
607,320 mail-order LSR
Topics67,089
Posts651,023
Members10,254
T150V Tool Kit #572252
11/15/14 4:05 am
11/15/14 4:05 am
kettle738 Offline OP
Does anyone know if original or repo tool kits are available for the T150V?
I thought this was something that wouldn't be too hard to find, but unless I'm missing something they are thin on the ground. I could make up my own, but I'd much rather start with the correct Triumph kit if possible.
Mick..........kettle738
Re: T150V Tool Kit [Re: kettle738] #572255
11/15/14 4:55 am
11/15/14 4:55 am
Stuart Online content
Stuart  Online Content
Hi Mick,
Not as a complete kit but a quick check on L.P. Williams's site shows some of the more unusual tools are listed individually; the double-ended screwdriver and spanners are more-generally available, certainly the screwdriver was by Draper.
Another person you could try is ex-dealer Phil Pick - pm him through the TOL forum.
Be aware that:-
. The original 7/16" x 1/2" ring spanner had special thin walls so the 1/2" ring fitted between the cylinder block and barrel base nuts. My first T160 came without one and, although originals exist and are much treasured by triple owners, later ones have to be ground to fit the aforementioned gap. frown
. The 1/2" ring also fits the hex. on one end of the plug spanner, which is also that length so the centre plug can be removed without needing to remove the tank. bigt
Re: T150V Tool Kit [Re: kettle738] #572441
11/16/14 10:44 am
11/16/14 10:44 am
Many thanks for the advice, much appreciated.
I've started looking and sorted out a few of the tools, however the parts list doesn't state the sizes of the open ended spanners......can anyone help with that please?
Re: T150V Tool Kit [Re: kettle738] #572462
11/16/14 12:39 pm
11/16/14 12:39 pm
Hi Mick,
British Spares has 60-3350 as a 5/16" & 9/16" open-ender but I'm pretty sure 5/16" is a misprint, 5/8" is in earlier T150 and the T160 tool kits.
As for 60-4523, what's missing from the '74 toolkit if you cross-reference with earlier and T160 toolkits is 11/16"AF and anything to undo the rear wheel nuts, so I reckon this is it.
Re: T150V Tool Kit [Re: kettle738] #572472
11/16/14 1:45 pm
11/16/14 1:45 pm
Thank you for that.........looking through my Britool spanner collection........I had a few more than I realised, I think I should have all I need.
Mick.........kettle738
Re: T150V Tool Kit [Re: kettle738] #572983
11/19/14 6:45 pm
11/19/14 6:45 pm
British Columbia Canada
Tony Schofield Offline
I measured my 60-3350 open ended wrench and it actually is 11/32" x 9/16" and is 4 inches long.
The 60-2647 open end is 3/4" x 15/16" and is 6.25 inches long.
Re: T150V Tool Kit [Re: Tony Schofield] #574060
11/26/14 2:46 pm
11/26/14 2:46 pm
Thank you for the information, it's simple stuff, but I didn't know so it's very much appreciated.
Mick.
