umjwh
umjwh
Lowell, Ind
38 registered members (Andy Higham), 235 guests, and 392 spiders.
blayde54, Davenz13, Sean65, Rerock, pkuzyk
10477 Registered Users
NickL 83
franko 75
Triless 61
748,064 mail-order LSR
Topics68,836
Posts670,477
Members10,477
Mikuni Tuning on a Trident #567966
10/16/14 4:10 pm
10/16/14 4:10 pm
Florida
gzrglyde Offline OP
gzrglyde  Offline OP
Florida
Does anyone have a good method for tuning Mikuni carbs on a trident? The "directions" that come with the new carb kit (from MAP) is not very good. I seem to be having issues with the air/fuel adjustments.
Re: Mikuni Tuning on a Trident [Re: gzrglyde] #568006
10/16/14 8:22 pm
10/16/14 8:22 pm
SEATTLE WA
SEATTLE GS Offline
SEATTLE GS  Offline
SEATTLE WA
what are the MAP jets? and carb size
Re: Mikuni Tuning on a Trident [Re: gzrglyde] #568033
10/16/14 11:26 pm
10/16/14 11:26 pm
Panama City Florida
gcooperlll Offline
gcooperlll  Offline
Panama City Florida
I would find a smart engineer, buy him a large bottle of exotic rum and borrow his colortune.
Cooper
Re: Mikuni Tuning on a Trident [Re: gzrglyde] #572699
11/17/14 8:39 pm
11/17/14 8:39 pm
kevin roberts Offline
get a uni syn as well. the two together are unbeatable
Re: Mikuni Tuning on a Trident [Re: kevin roberts] #572736
11/17/14 11:07 pm
11/17/14 11:07 pm
shel Offline
shel  Offline
I bought one second hand but have never used it manly because I'm not sure how.
I understand that this tool is used to sync carbs but all the instructions I've read describe using the throttle stop screws to adjust, this is fine to get all carbs in sync at idle but what about above idle?
Re: Mikuni Tuning on a Trident [Re: shel] #572881
11/19/14 2:08 am
11/19/14 2:08 am
Not that difficult with a triple. Raise the 'idle' using the throttle-stop bolt on the manifold, then adjust individual carbs with the adjuster on top of the manifold.
It gets tricky with twins. I tighten the tension screw on the throttle until it will stay in position at higher throttle openings and adjust the cables. After that I adjust the idle-stop screws. You will need to adjust the screw on the back of the UniSyn so the little bead is in the center at each throttle setting.
That said, this will only get your throttles synched, won't affect the mixture. Good luck with the Mikunis. I've had mine for a couple of years and finally got the set up right. At least you are starting with what MAP thinks is close.
BTW: I have the same question about the ColorTune. How the heck are you supposed to run down the road at WOT, or even half throttle, and peer down to see what color your combustion is?
Re: Mikuni Tuning on a Trident [Re: gzrglyde] #572894
11/19/14 5:22 am
11/19/14 5:22 am
You don't, it does not have the heat transfer properties of a proper spark plug and your engine will overheat, it can only be used with the bike stationary.
Here are the instructions in colour.
http://www.carbtune.co.uk/Images/Colour%20Chart%201.jpg
http://www.carbtune.co.uk/Images/Colour%20Chart%202.jpg
http://www.carbtune.co.uk/Images/Colour%20Chart%203.jpg
http://www.carbtune.co.uk/Images/Colour%20Chart%204.jpg
Re: Mikuni Tuning on a Trident [Re: gzrglyde] #573042
11/20/14 3:22 am
11/20/14 3:22 am
Just as I suspected, too much money for a gizmo which will tell me what my ears have already revealed.
Re: Mikuni Tuning on a Trident [Re: gzrglyde] #573134
11/20/14 7:27 pm
11/20/14 7:27 pm
shel Offline
shel  Offline
I was out in the garage last night and I was looking at my uni syn and it seems the adjuster screw is missing so it's not much good if I can't find a replacement.
I also bought a colortune a couple years ago but haven't used it yet. My Bonnie has Mikunis on it and once dialed in don't require a lot of attention and my Trident has ran well since first start up so I haven't messed with the carbs much.
Both bikes will get a good going over in the spring, I may play with the carb tuner toys then.
Re: Mikuni Tuning on a Trident [Re: shel] #573165
11/21/14 12:31 am
11/21/14 12:31 am
the unisyn and colortune both work only for setting final idle mixture up to 1500 rpm or so on a twin or triple. if you're not idling your bike then they won't do anything important for you.
shel, i'm not sure what adjuster screw you're talking about. on the unisyn, you set the idle as best you can using the mixture and throttle stop screws, then set the unisyn on the carb and screw in the venturi wheel until the floating bead lines up with one of the lines in the tube. then you set it on the other cylinder and mess with the carb screws until the bead sits at the same height. if the bike's idling too high, turn down both throttle stops and balance again. all it does is balance the carbs, but it does it very precisely.
the colortune is also just a fine adjustment for idle. try to ride with it and it will blow out the middle.
you don't need them to tune a bike, just like you don't need feeler gauges to set the valves. but they make it quick and exact, and let me do a better job.
Re: Mikuni Tuning on a Trident [Re: kevin roberts] #573166
11/21/14 12:38 am
11/21/14 12:38 am
if you're tuning the mikunis at higher rpms and loads, then the old pointer-tape-on-the-throttle and plug chops are what i do. i,ve run 32 mm mikunis on my triumph for ages, and they respond well to tuning
Re: Mikuni Tuning on a Trident [Re: shel] #573260
11/21/14 6:24 pm
11/21/14 6:24 pm
My bad, there is no adjuster screw as such. To adjust the opening you screw the dome-shaped thing in the center in or out.
Re: Mikuni Tuning on a Trident [Re: gzrglyde] #573262
11/21/14 6:36 pm
11/21/14 6:36 pm
shel Offline
shel  Offline
On the cross bar piece across the top the center is threaded so I thought something was missing. I'll have a closer look at it next time I'm out there.
I plan on playing around with the uni syn and colortune when it warms up.
