Kalen Fitch
Kalen Fitch
Ridgway, PA USA
21 registered members (Alan_nc), 168 guests, and 107 spiders.
locobeta, Walt, DennisMartin, Dwight V, urbanghost
10387 Registered Users
NickL 98
Triless 88
reverb 82
Rohan 80
Mori55 79
DavidP 72
btour 66
690,451 mail-order LSR
Topics68,045
Posts662,094
Members10,387
premier carbs #569229
10/26/14 11:36 pm
10/26/14 11:36 pm
SEATTLE WA
SEATTLE GS Offline OP
SEATTLE WA
do these carbs come jetted for Norton with the Norton only needle and spray tube?
Re: premier carbs [Re: SEATTLE GS] #569235
10/27/14 1:30 am
10/27/14 1:30 am
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
A standard AMAL Premier 930 Carb will not. You must specify when ordering what application you will be using the carbs on. Norton 750 930/30A & 930/31A. Norton 850 932/35A & 932/36A
Re: premier carbs [Re: SEATTLE GS] #569256
10/27/14 7:26 am
10/27/14 7:26 am
kommando Offline
kommando  Offline
There should be 2 850 specs, pre black plastic airbox eg MK1 and MK2 and the black airbox type for MK2A and MK3. The stepped spray tube was in the Black plastic airbox with a smaller main jet to match the black cap silencers, by fitting reverse cone silencers you need the larger main jets.
Re: premier carbs [Re: kommando] #569266
10/27/14 10:11 am
10/27/14 10:11 am
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
According to the available information including the AMAL (Burlen) spec. list, all 850 932 carbs (5 variants) had the 928/107 stepped spray tubes and matching 928/104 4-ID ring needles.
An early 850 press release printed in the April 1973 copy of Motorcycle Sport also mentions that the 'new' model (which can only refer to 850 Mk1 at that time) has: "cutaway spray tubes".
If any 850 carbs originally had the standard 622/074 flat-topped spray tubes and 622/124 2-ID ring needles, then neither of those parts appear in either the 850 Mk1 parts list or Mk2/Mk2A parts supplement.
Re: premier carbs [Re: SEATTLE GS] #569288
10/27/14 1:23 pm
10/27/14 1:23 pm
kommando Offline
kommando  Offline
The 850 carb specs are
73-74 850 (with reversed cones)932/29-30 260 25 3.5 2
73-74 850 (with black caps)932/31-32 230 25 3.5 2 or 3
74 850 932/35-36 260 25 3.5 3
74 850 932/33-34 220 25 3.5 2
75 850 932/33-34 230 25 3.5 1 or 2
As for the stepped cutaways never having a MK1 or MK2 850 it may have been a all 850 change but
http://www.inoanorton.com/docs/TheNortonCarburetor.pdf
refers to Both 30 mm (type 930) and 32 mm. (type 932) bores were used at times on both the 750 and 850 motors. In addition, two types of spray tubes were fitted over the years. This is the brass tube which projects up into the center of the bore. Later 850's had a notch cut off the inside surface of this tube.
So does
later 850's
mean all 850's or Black air box 850's, the parts books LAB refers to would suggest all 850's
Re: premier carbs [Re: kommando] #569295
10/27/14 2:30 pm
10/27/14 2:30 pm
Norfolk, UK
Norfolk, UK
That sentence is slightly misleading or wrongly worded, as it tends to suggest 930 and 932 carbs were used on both the 750 and 850 models when as far as we know only the 932s were fitted to 850 models although 750 models did use both sizes, and 932s fitted to 750s (932/19&20 and 932/26&27) are not the subject of the discussion here.
Unfortunately, the INOA list doesn't include the relevant spray tube and needle information for each individual build spec., whereas the AMAL list supplied by Burlen does, and 932/29-36 are all listed as having the 928/107 stepped spray tubes and 928/104 needles.
So does
later 850's
It is often thought that only the black airbox 850'A' models (and 850 Mk3) had the stepped spray tubes, however the available information doesn't seem to support that.
In addition to the AMAL build list and the absence of any flat topped spray tube and 2-ID needle being listed in the '73 and '74 parts books, the factory manual for '73 750 & 850 has no information relating to the black airbox 'A' model, however only the stepped 928/107 spray tube and /104 needle are listed in the carb specifications for '850' along with '260 main jet', etc..
http://www.classicbike.biz/Norton/Repair/70up_Commando/70upCommando.pdf
Re: premier carbs [Re: SEATTLE GS] #569311
10/27/14 4:59 pm
10/27/14 4:59 pm
Hamilton, Mass. USA
Dave Comeau Offline
Crew Chief
Dave Comeau  Offline
Crew Chief
Hamilton, Mass. USA
Can't say I have ever seen an 850 without stepped spray tube except for guys using the generic 300/301 replacements. I surmised that the original requirement for the stepped tube was primarily due to the more free flow balanced exhaust...
Well if you replace with 750 style pipes then a straight spray tube would make sense...
dynodave
BSA 3 1961-1963
Ducati 3 1992-2002
Norton many 1951-1975
Re: premier carbs [Re: SEATTLE GS] #569360
10/28/14 12:13 am
10/28/14 12:13 am
SEATTLE WA
SEATTLE WA
A FEW MORE DETAILS...This concerns a MK3 WITHOUT the airbox. Just K&N
earlier reverse cone muffs, not stock black caps.
The carbs that arrived at my door step came with
#3 slides
straight tube spray tube
2-ring needles
Excellent for a Bonneville but ??? for a Norton.
Send them back? If nothing else the slides seem too rich. What is the jetting for a 1974 850?
Re: premier carbs [Re: SEATTLE GS] #569378
10/28/14 5:44 am
10/28/14 5:44 am
kommando Offline
kommando  Offline
Main/pilot/slide/needle postion
260 for reverse cone, 220 for blackcap silencer
Re: premier carbs [Re: SEATTLE GS] #569381
10/28/14 6:03 am
10/28/14 6:03 am
Norfolk, UK
Norfolk, UK
#3 slides
2-ring needles
Sounds like you've may have been sent a pair of generic 932 300/301 carbs?
Do they have the necessary machined flats to fit a Commando?
What size are the main jets?
The slides could possibly be too rich, the spray tubes and needles can be changed if necessary.
Re: premier carbs [Re: SEATTLE GS] #569454
10/28/14 3:54 pm
10/28/14 3:54 pm
SEATTLE WA
SEATTLE WA
the carbs have not been shaved so they are generic but sold with the idea that they have been jetted for Norton. Main jet is 260.
Anybody have a factory manual for an 74 Commando? What are the jetting specs?
Re: premier carbs [Re: SEATTLE GS] #569456
10/28/14 4:00 pm
10/28/14 4:00 pm
Norfolk, UK
Norfolk, UK
There is no '74 factory manual, the specs. for '74 are as kommando posted previously.
Re: premier carbs [Re: SEATTLE GS] #569570
10/29/14 11:00 am
10/29/14 11:00 am
California, US
Peter_Joe Offline
Peter_Joe  Offline
California, US
Here is a page from my Norton 850 Commando Mark 2/2A Riders manual (p/n 065321)that lists the carburetor settings. As a matter of fact this is the only place in the whole rider's manual that the Mark 2 or 2A is even printed. Everywhere else in the manual it just refers to the 'special noise control models' or the 'not-special noise control models'.
Re: premier carbs [Re: SEATTLE GS] #569648
10/29/14 9:45 pm
10/29/14 9:45 pm
SEATTLE WA
SEATTLE WA
Thanks for the info.
Re: premier carbs [Re: SEATTLE GS] #569708
10/30/14 3:03 pm
10/30/14 3:03 pm
Western North Carolina
johnhannah Offline
johnhannah  Offline
We installed a set of AMAL Premier carbs on a 73 850 Commando and a 72 750 Commando Combat this summer. Both use 932s but are set up differently.The 850 carbs arrived with a 3.5 slide, pilot RJ17, NJET 106 and main jet 260.These had the proper stepped cutaway spray nozzle.With the clip on the needle in the middle and the pilot mixture screw out 1 turn they are perfect. The Combat setup came with a 3.0 slide and 230 main jet. We had trouble with excessive popping on idle till Len figured out the problem after looking at the original carbs. The original carbs had the blank casting for the slide adjustment screw on the inboard side of the carbs notched to allow a close fit on a Commando. On the Combat motor the carbs were touching and not allowing a proper seal with the manifold. A bit of minor machining on the bodies and all was fine. No more popping and they adjusted properly.These carbs transformed both bikes and a steady 1000 rpm idle is excellent.
Re: premier carbs [Re: SEATTLE GS] #569728
10/30/14 5:57 pm
10/30/14 5:57 pm
Belgium
7
79x100 Offline
79x100  Offline
Belgium
All standard Commando carbs originally had the unused boss machined off and non-specific replacements need a file taking to them.
Do the Premiers for Commandos have the small holes drilled where the tickler tubes insert...and what was it for anyway ?
'39 WD16H
'75 850 Commando
Re: premier carbs [Re: SEATTLE GS] #569731
10/30/14 6:37 pm
10/30/14 6:37 pm
John Healy Offline
John Healy  Offline
Vent!
Re: premier carbs [Re: 79x100] #569733
10/30/14 7:22 pm
10/30/14 7:22 pm
Norfolk, UK
Norfolk, UK
I think AMAL dispensed with the vent holes when they started fitting the extended 'waterproof' ticklers, so from around 1973?
Re: premier carbs [Re: L.A.B.] #569741
10/30/14 7:53 pm
10/30/14 7:53 pm
Belgium
7
79x100 Offline
79x100  Offline
Belgium
I don't know. I thought that the 932 R33 (and L34 ? but I can't see that one) were original to my Mk3 and that they always had 'waterproof' ticklers. What puzzles me is that the hole seems to be completely closed by the tickler tube so I can't imagine where any breather function arises.
'39 WD16H
'75 850 Commando
Re: premier carbs [Re: 79x100] #569747
10/30/14 8:26 pm
10/30/14 8:26 pm
Norfolk, UK
Norfolk, UK
With the waterproof ticklers, the vent isn't needed because the float chamber vents through the tube. With short ticklers I think there's a chance the tip of the rider's finger can close off the drilling when the tickler is pressed fully down which would result in an airlock if it wasn't for the vent.
Edit: Looking at various period photos it seems AMAL continued to drill the vent hole until around 1976-'77 possibly because it appears that Triumph didn't adopt the waterproof ticklers until then? The 'believed original' 930s fitted to my '78 T140V don't have the vent holes.
Re: premier carbs [Re: L.A.B.] #569847
10/31/14 4:12 pm
10/31/14 4:12 pm
Belgium
7
79x100 Offline
79x100  Offline
Belgium
Thanks, L.A.B. That all makes sense. I enjoy these odd differences even if I can't always see the point of them...I wonder who first coined the term 'waterproof' for the shrouded ticklers ('cause they ain't !)
'39 WD16H
'75 850 Commando
Moderated by  Dave Comeau
