kllrjo
kllrjo
sunny tampa fla
35 registered members (AML), 286 guests, and 419 spiders.
10294 Registered Users
Stuart 99
Lannis 68
Mori55 67
639,578 mail-order LSR
Topics67,412
Posts654,559
Members10,294
A65 Oil feed tube #567839
10/15/14 8:56 pm
10/15/14 8:56 pm
Central NJ
Vetterdog Offline OP
Central NJ
Still plugging away at my 67 A65 project, I am looking for an oil feed tube for the cylinder head. The original one broke, and I made it much much worse trying to save it. I have the fittings that attach to the head, but not the tube itself, and, most importantly, the cone-shaped bit at the end that fits into the fitting. I tried fabbing one out of 3/8" brake line and a compression ring but the ring is just a hair too small and wants to come through the nut. I am going to try 1/4" copper tubing next, unless I can find the proper bits. Anyone have, or know where I can get one? Thanks as always, Dave
vdog
66 6T
67 A65L
72 T100R
Re: A65 Oil feed tube [Re: Vetterdog] #567854
10/16/14 12:02 am
10/16/14 12:02 am
Mark Z Offline
Mark Z  Offline
I was able to source those bits. I don't remember where, but I usually call British Cycle Supply first for stuff like that.
Re: A65 Oil feed tube [Re: Vetterdog] #567907
10/16/14 10:00 am
10/16/14 10:00 am
Norway
Ola Offline
Ola  Offline
Norway
3/16" copper tubing and a flaring tool will work out fine. Alternatively you can drill out a bolt that fits (5/16 BSF?), and brace them together.
(Doug Hele, 1919 - 2001)
Re: A65 Oil feed tube [Re: Ola] #567926
10/16/14 12:12 pm
10/16/14 12:12 pm
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
I see this oil feed
Adaper nut offered
on fleabay and other places
Re: A65 Oil feed tube [Re: Vetterdog] #567927
10/16/14 12:23 pm
10/16/14 12:23 pm
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
Most of the usual suspects (supply houses) in the US will carry the tube with the brazed on ferrule #68-0927 and ferrule tube nut (if needed) #29-2089.
Re: A65 Oil feed tube [Re: quinten] #567944
10/16/14 2:20 pm
10/16/14 2:20 pm
Originally Posted By: quinten
I see this oil feed
Adaper nut offered
I think the poster is asking for the length of pipe which screws onto this.
SRM sell these, but I can't see no reason why any of your local vendors can't get hold of this part.
Re: A65 Oil feed tube [Re: Vetterdog] #568012
10/16/14 8:52 pm
10/16/14 8:52 pm
Mark Z Offline
Mark Z  Offline
Vdog, are you aware that British Cycle Supply, although based in Nova Scotia, has a warehouse in New Jersey? For you that means one-day service, if the parts are in stock in Jersey. Give 'em a call.
Re: A65 Oil feed tube [Re: Vetterdog] #568014
10/16/14 8:59 pm
10/16/14 8:59 pm
Tridentman Offline
Tridentman  Offline
The warehouse is in Hackensack NJ.
If you call the Sales Office in Canada at 9.00 a.m. you can pick it up at Hackensack at about 2 p.m.
Same day service and no shipping costs.
It works--I live about 4 miles from the warehouse and use their service frequently.
Re: A65 Oil feed tube [Re: Vetterdog] #568023
10/16/14 10:04 pm
10/16/14 10:04 pm
Central NJ
Central NJ
I do in fact need the tube, not the fitting shown above. Presently I have it rigged with a length of 1/4" copper tubing and a ferrule, but it seems a bit precarious since the tubing is too big to insert too far into the fitting so the ferrule is right at the end of the tubing. Not sure how secure it is. Seems like it might be OK for a little while, but I don't trust it. Couldn't find my flaring tool, so it's just sitting on the end.
I have spoken to Wayne at BCS a number of times over the years, and since they're in Jerz, I usually get my parts in a day or two. Didn't see this bit on their website, so I guess I'll make a list and give them a call. Thanks again, to all.
vdog
66 6T
67 A65L
72 T100R
Re: A65 Oil feed tube [Re: Vetterdog] #568061
10/17/14 7:18 am
10/17/14 7:18 am
Mark Parker Offline
Mark Parker  Offline
Someone made some silver coated copper or brass ones of those, it looked like steel pipe and perfect till it broke. Its pretty obvious when it breaks because of the large quantity of oil it pumps all over the motor. So if you get a new piece make sure it's steel. Possibly you could use a piece of steel pipe with brass olive and nut. A section of an old diesel injector pipe might work if its the right size. When mine broke I was a long way from home and I just took the broken bit off and jammed the hose over the threaded section and put a hose clamp on.
