jetpoweredmonkey
jetpoweredmonkey
Sacramento, CA
208 registered members (1xfatboy), 1,824 guests, and 555 spiders.
Gus1956, Henry74, Benny, Lou Quirch, Mark Masa
10045 Registered Users
Lannis 152
kommando 112
480,882 mail-order LSR
Topics65,768
Posts635,817
Members10,045
Ariel Arrow two-stroke #56358
08/16/07 8:59 am
08/16/07 8:59 am
Angus Campbell Offline OP
Help! My Ariel Arrow 250 twin 2-stroke 1964 has developed a serious problem. It starts OK then runs fine for about 2 minutes then cuts out. Won't start again until cold then same thing happens again. Not fuel, probably electrics. although I have swapped over the coils, points and condensors so it should still have one side working. Has anyone got a probable cause/solution for thi fault? I really don't want to change to electronic ignition if I don't have to.
Re: Ariel Arrow two-stroke #56359
08/16/07 9:15 am
08/16/07 9:15 am
beltdriveman Offline
Have you tried, as soon as it stops, checking with a voltmeter to see if volts are reaching the points???It could be a dicky igniinion switch or crappy earth connection or something equally as silly.
Re: Ariel Arrow two-stroke #56360
08/16/07 5:35 pm
08/16/07 5:35 pm
Halifax, Butt end of Europe
andrewinpopayan Offline
Calm down
When you say "cuts out" does it cut out like you switched the ignition off or does it fart and splutter to a halt?
99% of carb problems are electrical.
1959 3TA
BMW R1150 Oilhead
Re: Ariel Arrow two-stroke #56361
08/16/07 6:40 pm
08/16/07 6:40 pm
somewhere in the UK
Mike Muir Offline
Mike Muir  Offline
somewhere in the UK
Andrew has a thought there, might have a blockage in the fuel line and it is using what is in the float chamber for those 2 minutes! Once the motor is stopped the chamber refills and the bike will restart easily.
Mike, home is where we moor it.
Re: Ariel Arrow two-stroke #56362
08/16/07 7:24 pm
08/16/07 7:24 pm
I can't remember if it's the ARROW or LEADER that has twin carbs. As a general measure, if a motor cuts like the ignition switch has been switched off it's USUALLY an electrical fault, If it farts and starts missing before dying, then is COULD be fuel.
Does it still have 6 volt Joe "Darkness" Lucas electrics and all the original wiring? Harness used to get pinched and cut where it passes thru the false tank to the steering head.
When was the last time that little gas tank was wrestled from under the seat and given a really good clean out?. All the filters, taps and lines.
I believe it has a single Monobloc, Don't go pull it off, monoblocks are easy to clean out "in situ" without provoking more problems.
More tests and information are needed. Owners who posses a multimeter AND can use it are generally easy to help with electrics.
1959 3TA
BMW R1150 Oilhead
Re: Ariel Arrow two-stroke #56363
08/16/07 8:17 pm
08/16/07 8:17 pm
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
Could be a fuel tank vent blockage, leave the filler cap off next time you run it to eliminate this possibility.
1969 TR6R
Re: Ariel Arrow two-stroke #56364
08/18/07 3:38 pm
08/18/07 3:38 pm
The Valley of the Sun,Arizona,...
CommandoRoadster Offline
Two strokes with small pistons like to do the old stick & release trick. Engine heats,piston siezes.Engine cools,piston releases.
Just some more beef for the stew.
Cheers!
Bruce
Re: Ariel Arrow two-stroke #56365
08/18/07 6:10 pm
08/18/07 6:10 pm
Like the "stone soup"? Why don't people reply and give up the final findings?
1959 3TA
BMW R1150 Oilhead
Re: Ariel Arrow two-stroke #56366
08/18/07 6:28 pm
08/18/07 6:28 pm
It would be nice,wouldn't it Andy? Even if it's just to tell us we're bluddy idjits,and we can ram it where the sun don't shine!
And yes,probably just like stone soup.
Cheers!
Bruce
Re: Ariel Arrow two-stroke #56367
08/20/07 3:52 am
08/20/07 3:52 am
Flint,Mich
norbsa48503 Offline
norbsa48503  Offline
Flint,Mich
Got a Puch 250 twinkle 69 1/2 model kid that sold it says "no spark". Pulled the exhaust and find them near plugged off with carbon and oil mix. Tripled the cost of the bike just getting this squared up. This bike had only 1900 miles showing I would be checking that. Hey we can always talk among ourselves think of the reading Angus is saving.
norbsa
1960 TR6
1963 Super Rocket
1965 650 Star
1966 441
1968 Thunderbolt
1969 Twinkle 250
1972 Fastback
1974 Roadster
1970 S.S
Way too many BSA's not named
http://decentcycles.com
Re: Ariel Arrow two-stroke #56368
08/20/07 12:22 pm
08/20/07 12:22 pm
2 strokes seem to enjoy a good thrashing, loosens up the crud in the pipes/silencers, leave a huge cloud of smoke behing them after a couple of miles of WOT. That Puch has probably been bimbled around town and over oiled if it's a petroiler.
I'da knocked off the real solid bits of crud, then found a 20 miles of freeway at 3AM to "evaporate / smoke up" the residue left in the pipes, unseen by the the envirogeeks. bigt
I never found anything that got carbon out of pipes and silencers as good as oxygen eek . Get the pipes off and using an oxy-acetyline set get a ring of carbon glowing red, then turn off the acetyline and open up the oxygen (plays hell with chrome though)
1959 3TA
BMW R1150 Oilhead
Re: Ariel Arrow two-stroke #56369
08/22/07 6:16 am
08/22/07 6:16 am
Back when I was about 15,a friends dad had a twingle stuck back in the end of his shed.It looked like probably an early 60s model,but I never knew for sure.The thing hadn't run for 10 or 15 years,at least.One time when we didn't have anything better to do,we dragged it out,and started checking it out. His dad said that it had two cylinders,but only one piston. We couldn't figure out how that could be possible,so we decided to tear the top end off,for a look-see.
Just to see if it were siezed,I guess,my friend gave it a kick,and it started!First kick,old gas,no choke,no throttle.In fact the throttle was stuck closed,and we couldn't even rev it. It just sat there and idled...ping-ping-pop-ping-pop- pop-ping-pop... like it would go on all night.
After about 10 minutes of this,we started looking for some way to shut it off.We couldn't find any kind of switch anywhere,and after shocking the crap out of ourselves trying to pull the plug wire off,one of us got the bright idea to put it in gear,and dump the clutch.
Eventually,we did pull the top end,and saw that,in fact,it had two pistons,but only one combustion chamber,and one crank throw,with the front rod,I think,forked off the rear. Well,you know how they are.
Weird machine,but it worked.
Cheers!
Bruce
Re: Ariel Arrow two-stroke #56370
08/22/07 2:05 pm
08/22/07 2:05 pm
Flint,Mich
norbsa48503 Offline
norbsa48503  Offline
Flint,Mich
Yes, Twingles have built in rev limiter. The intake gases go into the side of the jug through a complex pathway coming out at the back of the back piston that piston feeds the front piston. This solved the low end torque and idle problems and protected them from misuse(over revs).
norbsa
1960 TR6
1963 Super Rocket
1965 650 Star
1966 441
1968 Thunderbolt
1969 Twinkle 250
1972 Fastback
1974 Roadster
1970 S.S
