maylar
maylar
Connecticut
223 registered members (21inGoldie), 2,455 guests, and 569 spiders.
10071 Registered Users
koan58 83
NickL 76
502,493 mail-order LSR
Topics66,012
Posts638,899
Members10,071
Blown fuse *UPDATE* #559168
08/20/14 2:54 pm
08/20/14 2:54 pm
JubeePrince Offline OP
Hi all -
Went for a ride the other day and got about 2 miles down the road when my fuse blew. Put another in and pfffft. (fuse is wired on (-) side, (+)ground system)
Got a tow back home and put lightbulb in place of the fuse and began disconnecting things. Jiggled some wires around under the seat and the light bulb went out (or so I thought, I think I just nudged the alligator clip on the bulb). I was leaving town that night, so I put the fuse back in and left town for three or four days. When I got home battery was down to 2 - 3VDC.
Re-charged the battery, turned on the parking lamp: pfft, fuse blows. Put the light bulb back in the fuse holder and started disconnecting things...found when I disconnected the black wire (-) on the single-phase Sparx regulator the light bulb went out. Checked the wiring on the regulator, no chafing, etc....
I have tested the alternator with the 1ohm 100W resistor wired to MM. Got 10.0VAC at around 3000RPM.
I connected the main and dip contacts of my headlight together (45W + 35W = 80W) and wired the bulb to the black and red wires on the regulator . Light at idle, gets brighter with revs.
Hook the regulator (black and red) back into the harness and start the bike, MM shows 14VDC on the battery at 3000 rpm.
Turn off bike, pull the fuse and I still have 12+ volts at the fuse terminal with everything turned off. confused
Based on the data from my tests, the alternator and regulator seem to be working OK, but my battery is draining (current across the fuse terminals) unless I remove the black wire (-) of the regulator OR both yellow wires from the alternator leads.
One other thing: with the red and black wires plugged into the harness, I can turn off the bulb in the fuse holder if I disconnect the two yellow wires from the alternator leads. Regardless of which alternator lead I use (two: single-phase), if I leave one of the yellow leads plugged in, one yellow wire registers ~9.6VDC across the fuse terminals, the other yellow wire registers a lower voltage (~2.3VDC) and then that number begins to CLIMB in 10ths of a volt! I stopped watching it after it got to around 4VDC....
I now have the regulator wired back into the bike, and able to start bike, turn on lights and no blown fuse, BUT I'm still showing voltage across the fuse terminals with everything turned off.
Did I miss anything? Anyone have any ideas? I HATE intermittent electrical problems mad
Thanks in advance,
Re: Blown fuse [Re: JubeePrince] #559191
08/20/14 5:26 pm
08/20/14 5:26 pm
Data update:
Put ammeter across fuse terminals:
everything off: 0A
Parking Lamp (includes LED tailight): 1.7A
Dip Beam (incl. PL and TL): 4.6A
Main Beam (as above) 5.15A
Ign (BB MKIII): .15A
with everything off, I'm getting 0 Amps, but I record 10.25VDC across the same fuse terminal?
Have everything hooked up, everything turned off, fuse in place and monitoring the battery every hour or so and see if the voltage starts to drop again.....
Re: Blown fuse [Re: JubeePrince] #559200
08/20/14 6:13 pm
08/20/14 6:13 pm
New Zealand
Excalibur Online content
Excalibur  Online Content
New Zealand
I'd suspect a bad rectifier as a first thought.
Re: Blown fuse [Re: JubeePrince] #559288
08/21/14 8:50 am
08/21/14 8:50 am
Thanks, thought that too, but if that was the case, wouldn't the light bulb test not work?
I'm beginning to wonder if I have a bad coil(s) in the stator resulting in an occasional surge of amps across the system. Is that possible? All my tests appear to show the alternator and regulator are working properly, unless I'm not interpreting the numbers correctly?
Re: Blown fuse [Re: JubeePrince] #559390
08/21/14 7:30 pm
08/21/14 7:30 pm
El Dorado, California
Roadwarrior Online content
Private Sponsor
Roadwarrior  Online Content
Private Sponsor
I had one similar last year that drove me nuts. All the tests I knew came out fine but I kept blowing fuses. I only cured it when I replaced the stator and the regulator.
73 Triumph T140 Main Ride
70 Bonnie
67 BSA West Coast Hornet
56 Chevy
Who are the brain police?
Re: Blown fuse [Re: JubeePrince] #559396
08/21/14 8:03 pm
08/21/14 8:03 pm
New Zealand
New Zealand
Intermittent electrical gremlins can be a major pain as you say. In review of the previous posts, it still appears to point to the rectifier. Is the zener built in on your Sparx box?
Sometimes the only way to sort issues is to swap in known good parts. This is awkward because unless the fault can be reproduced at will, it can take time.
Either which way I look at it, a rectifier should not draw current from the battery, neither should the zener.
Re: Blown fuse [Re: JubeePrince] #559421
08/21/14 10:19 pm
08/21/14 10:19 pm
Maine
MikeinBiddeford Offline
Private sponsor
Private sponsor
Maine
Is it a solid reading across the fuse terminals or does the digital multi meter wander a bit? I don't know why, but digital meters make up numbers unless they have a real connection on their leads.
Please do not believe anything I write. I am a hack but I like to guess the right answers.
Re: Blown fuse [Re: JubeePrince] #559422
08/21/14 10:22 pm
08/21/14 10:22 pm
Bob - in the thread I reference below from three years ago, I replaced the regulator first (thanks again, John H!) but it turned out to be the stator.
I sent the old regulator to John and he was going to bench test it, but not sure what the results were. Hard to believe that a damaged stator like the one I had was still able to put out 8.7VAC at 3000RPM, but the damaged stator must have done something to blow the fuse....excess voltage? Amps?
Excal: It's a solid-state, Sparx single-phase regulator, so yes, it rectifies and the excess voltage is released as heat like a zener.
Here's my post from almost three years ago. Eerily similar.
http://www.britbike.com/forums/ubbthread...true#Post388555
EXACT same issue!
In my defense, I have not touched the primary or the stator I replaced in that three year span....my alternator test from three years ago was 8.7VAC @ 3000RPM. My current test gave me 10.0VAC at 3000RPM.
I think I'm going to have a look in the primary tomorrow and see if anything is amiss. If stator looks good, perhaps I'll try and replace the regulator...
Re: Blown fuse [Re: NickL] #559424
08/21/14 10:32 pm
08/21/14 10:32 pm
Originally Posted By: NickL
The stator may have gone to earth, that would cause the problem.
I'm with you Nick....see the previous thread I referenced in my last post....my old stator bit the dust on the coil in the 4 o'clock position causing that exact problem.
Is there a quick and dirty test with a MM to see if the stator has gone 'to earth'?
Re: Blown fuse [Re: JubeePrince] #559432
08/21/14 11:17 pm
08/21/14 11:17 pm
Hi Nick -
Excuse my electrical ignorance, but are you saying one probe on the/a stator wire and the other probe to a known ground point on the bike?
Re: Blown fuse [Re: NickL] #559440
08/22/14 12:20 am
08/22/14 12:20 am
The measured resistance of the stator winding end to end will be very small <1 ohm.
I get .2 ohm
So any reading between a stator wire and chassis means there is a fault.
At first I was getting lots of different readings with probe on (+) battery terminal, ground point under the seat and (+) terminal on a coil. Nothing over 5 meg ohms though.
Using the better of the two multimeters, I was able to get .4 ohms
Not sure if the variable readings were from my fingers holding the probe to the stator lead, so I used an alligator clip on that lead and could get no reading, not even a fraction of an ohm from the three ground points using two different meters.
Thanks for sticking with this!
Re: Blown fuse [Re: JubeePrince] #559441
08/22/14 12:30 am
08/22/14 12:30 am
Just re-read your post re: < 5 meg ohms....
Looks like I have a faulty stator!
Re: Blown fuse [Re: NickL] #559447
08/22/14 1:30 am
08/22/14 1:30 am
Have you disconnected the 2 stator leads?
Yes
If you have and you get a reading of <5megs between either/both of them to ground,,,YES you have a faulty stator or you are touching the leads and measuring YOURSELF.
Can't get any reading....no movenment on the analog meter either. Not touching the leads with my hands or fingers.
There should be no connection at all between the stator and chassis with the stator disconnected from the regulator.
Correct. If there was, it would measure as resistance, right?
Two digital and one analog meter. Getting same results (approx.) with all of them. I'll be the first to admit it, I'm an electrical dunce.
Re: Blown fuse [Re: JubeePrince] #559491
08/22/14 7:53 am
08/22/14 7:53 am
Thanks Nick!
Going to visually inspect the stator today just to confirm.....
Appreciate all the help and patience!
Re: Blown fuse [Re: JubeePrince] #559536
08/22/14 11:49 am
08/22/14 11:49 am
Think I found the source of the intermittent electrical fault:
Cracks in the potting material all the way around the stator and coils. It looks like it's burned/scorched a bit...before I removed it, I took a feeler gauge (.008") and checked all six coils while spinnning the engine/rotor. It was *tight*, but no binding or movement of the feeler gauge...
This is a Wassell brand stator (3 years old). Is a tight .008" clearance not enough? What can I do with the new stator to ensure enough clearance? Use a Dremel tool? Brake hone on a drill? Drum sander?
Thanks in advance,
Re: Blown fuse [Re: JubeePrince] #559540
08/22/14 12:24 pm
08/22/14 12:24 pm
Bishop, Calif.
desco Online content
desco  Online Content
Bishop, Calif.
I've gone through 3 or 4 Wassel stators in 3 or 4 years. I have tried all of the above including haveing a machine shop turn the rotor. This time I have .009 all the way round.
Mine actually melt.
If someone knows a manufacturer other than Wassel please let us know.
Re: Blown fuse [Re: desco] #559583
08/22/14 3:37 pm
08/22/14 3:37 pm
Finland (Europe)
Jouko Offline
Jouko  Offline
Finland (Europe)
Sparx is another alternative - made in China. I purchased a three phase Sparx stator 3 yrs ago and it still works eek. Former (Wassell?) stator ceased charging after 4 years of service, there was a shortcut between the coil(s) and stator frame but only when the stator was in place and the nuts were tightened. When removed it seemed to be OK. Unfortunately it seems the Far East electrics are not necessarily very long living. Original Lucas RM19 and RM21 items are however still available.
Re: Blown fuse [Re: JubeePrince] #559607
08/22/14 5:41 pm
08/22/14 5:41 pm
I went to the local Triumph shop here, (Deer Park Cycle) and Jack had an Emgo-labeled stator that also had Wassell on the back of it. It was stamped 10A as opposed to my busted one that is stamped 16A. It also had a couple of spots on the potting material that looked like defects/air bubbles from the molding/encapsualtion process...I was not impressed.
I have ordered the UK version (see: more expensive than Emgo) of the RM21 (not Lucas) from BCS, should be here Monday. When I was talking to Wayne at BCS, he was reading me some literature from the Emgo 3-phase unit (mine is single-phase). In the installation instructions, they (Emgo) recommend .008" as the *barest* minimum clearance and state a well-working clearance of .013". We'll see what I get!
Have the plants that make these items started using different material? Not as tolerant of heat (either from friction or oil) than in the past?
I'd love to hear John Healy's thoughts on this....
Re: Blown fuse [Re: JubeePrince] #559613
08/22/14 6:20 pm
08/22/14 6:20 pm
New Zealand
New Zealand
Good find! I suppose if a stator were to be intermittently shorting to ground, it could create some kind of weird power spiking. AC current is somewhat of a different animal and shorting via a ground return path... crazy
Wassell used to have a most shocking reputation in the 70's and it doesn't appear to have improved. I still remember some of the derogatory names it was called! mad
Re: Blown fuse [Re: JubeePrince] #559614
08/22/14 6:25 pm
08/22/14 6:25 pm
Pacific northwest
quinten Online confused
quinten  Online Confused
Pacific northwest
Emgo , sparxs and nos Lucas ... nos old stock does show up on fleabay , but its buyer beware ...
Dont over look used Lucas stators , obviously ohm check , but also check for rub marks on the stator's interior . rubbing comprises the integrity of the dielectric in the metal armature stack , which is there to minimize eddy currents . When working correctly , each metal slice has its own little eddy instead of the whole stack having one big eddy .
Eddy currents in practical terms is just heat that is not doing some useful work , some of the induced current from the spinning rotor ends up as heat in the coils of copper and heat in the metal armature . , so no rubbing between parts is better than some rubbing but even a compromised armature stack does not necessarily mean failure . Just less output and more heat .
... we only hear about the failures
Re: Blown fuse [Re: quinten] #559630
08/22/14 7:54 pm
08/22/14 7:54 pm
Illinois, USA
TR6Ray Online content
TR6Ray  Online Content
Illinois, USA
Jubee, sorry to hear of your repeated trouble after only three years. Can you tell us about how many miles were run up in that time period?
Re: Blown fuse [Re: JubeePrince] #559685
08/23/14 3:46 am
08/23/14 3:46 am
Stuart Online content
Stuart  Online Content
Hi Steve,
One thing I can't see suggested so far is to check the concentricity of the rotor - it's all very well to check for clearance between stator and rotor when the latter isn't moving but, if the rotor's wobbling about when it's spinning, checking when it isn't won't necessarily pick up the problem. frown Given the type of touching your pictures appear to show, I'd be removing the rotor, fitting it in something like a lathe and spinning it with a dial gauge on it.
The other thought is the bike has a main bearing problem ... sick
This I'm curious about. Aiu John Healy's previous posts on the subject, what was the last 'Lucas' British manufacturing unit will turn out new versions of old Lucas parts branded 'LAP' (Lucas Aftermarket Parts?); they do this after one or other of the major parts wholesalers has fronted-up a load of money. Is it one of these stators you're buying - approximately twice (at least here in GB) the price of Sparx or Wassell? If not, I can suggest one British retailer who can definitely supply you with one of these LAP stators.
Risking blowing my own trumpet, I've pointed out on several occasions that Wassell, Emgo, Uncle Tom Cobbley and all don't provide any rpm figures to go with these Amp ones ... Of the two two-wire, single-phase stators Lucas made and supplied to the British motorcycle makers from about 1970 to 1978, Lucas rated the RM21 for 10.5A @ 5,000 rpm and the RM23 for 14.5A @ 5,000 rpm - no "16A", "20A", "RM27", etc. that are being bandied about by on-line retailers. frown
Reminds me of the old saying, "If you can't blind 'em with science, baffle 'em with bullshit" ...
Lucas used to recommend between 0.008" and 0.012". The larger the air gap, the lower the the stator output ...
Re: Blown fuse [Re: JubeePrince] #559724
08/23/14 10:05 am
08/23/14 10:05 am
Thanks Ex, as my father likes to say "even a blind hog finds an acorn every once in a while!"
Ray - I don't track mileage too carefully except for oil changes, but I'd think somewhere around 2,000 miles...
Nick - when I checked clearance(s) before I removed it it was a *tight* .008". probably more like .00790 - .00795". No binding, but there was contact between the stator/gauge/rotor, unless contact between all three would be considered binding!
Stuart - I'm curious too. We'll see what unit I get on Monday, I'll post some pics if it's not immediately apparent. As I stated earlier, I checked all six coil positions while spinning the rotor when it was installed and before I removed it. At this point, based on the the feedback I'm getting and the tolerances I measured before dismounting, I'm leaning towards too tight a clearance and over-heating.
This is a one-family, two-owner bike, so knowing the complete history of the bike and rotor makes me believe it is sound. I replaced the original rotor back in 2011 because I had removed the rotor and stator to do some primary work and didn't check clearances upon reassembly. whistle But...checking the rotor for run-out may be a good idea if for nothing else but piece of mind.
I know I could have a thou or so shaved off the rotor, but short of that, is there anything I can do to remove some potting material from the inside of the stator? Everything I've read so far says that's a no-no. Removing a bit of resin/potting material (stator) seems easier than removing a bit of metal (rotor).
Thanks all,
Re: Blown fuse [Re: JubeePrince] #559754
08/23/14 1:36 pm
08/23/14 1:36 pm
Hi Steve,
http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=556413&page=all and scroll down to post #556413 (on 03 August 2014 18:14 GMT) by "Magnetoman".
Re: Blown fuse [Re: Stuart] #559773
08/23/14 3:00 pm
08/23/14 3:00 pm
Pacific northwest
Pacific northwest
For comparison ,Look at an un-potted Lucas stator , you 'may' be able to safely , carfully, remove a 'small' amount of potting from between the copper coils . But as the stator-coils mag.-Wire runs from coil-stack to coil-stack and there is no telling whether those wires are just below the potting surface , (closest to the rotor) or at the base of the coil-stack , its risky .... If you have home xray equipment ?
Do not file the steel lamimated stator core , it will compromise performance . How much ? Thats hard to say . It could be limited to localized heating in the filed area or worse , or worse over time .
There is a reason the stator core is made out of a stack of insulated plates and not a single piece . It is to control eddy current heating in the core . By filing the laminated coil , the burrs produced may join the plates designed to be isolated from each other . Filing will not kill the stator , at least not immediately , but the core will run hotter , why risk adding heat to a component already at a risk of overheating .
Page Time: 0.469s Queries: 16 (0.056s) Memory: 1.2226 MB (Peak: 1.5919 MB) Zlib disabled. Server Time: 2018-02-20 07:12:57 UTC
